Say you wanted to level your truck......
Discussion in 'Suspension' started by cfred70, Jun 8, 2018.
  1. Jun 8, 2018 at 12:24 PM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    Not looking for a lift, just would like a little more levelness to the truck. My truck is a pavement princess, it gets about 10k miles a year, probably won't put much bigger tires on, maybe a 275/70/18 so would really like to just do something that is reasonable price wise.
    I've looked at the rough country spacer kit, which looks really nice on their website pics, but I also know alot of people on here are against spacers. I've also looked at just putting bilstein 5100's on the front....I'm not very knowledgeable on this stuff so looking for any advice.
    I don't want to lift because I still have little ones that are in carseats, but would like a little more aggressive stance.
    Any advice....
  2. Jun 8, 2018 at 12:37 PM
    Afkouki
    Afkouki New Member
    2006 Natural White Limited
    Following...
  3. Jun 8, 2018 at 12:43 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Don't hesitate to explore the site a little bit, you'll see a lot of good info.
    I have always ran stock suspension so I'm no expert, but if I were in your shoes I would do the 5100's.
    GNTundra, Law323 and joonbug like this.
  4. Jun 8, 2018 at 12:44 PM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    There's nothing wrong with spacers if you use accordingly.
  5. Jun 8, 2018 at 12:46 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I leveled my tacoma with 5100s and I hated the way it rode after a few weeks, preloading the springs will result in a rougher ride. Not sure if shims or top plate spacers will do the same, but I think those limit down travel, which could make it ride rough as well. If you aren't afraid of spending money I'd get a coilover that gives and inch or 2 of lift or is adjustable and call it done. Buy once cry once.
    4x4_Angel and jewsNbrews like this.
  6. Jun 8, 2018 at 12:53 PM
    Old Man EMU, Eibach, 6112's, Radflo or even an in-coil spacer. Your stance will change with more aggressive tires/wheels too.
    Law323, 4x4_Angel, jewsNbrews and 2 others like this.
  7. Jun 8, 2018 at 12:56 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  8. Jun 8, 2018 at 1:03 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    5100 all around. Or 6112/5160 like I just did last month.
    MotoTundra likes this.
  9. Jun 8, 2018 at 1:08 PM
    cfred70
    Craig
    Ohio
    What is the difference between the 5100 and the 6112/5160 set up?
  10. Jun 8, 2018 at 1:10 PM
    Borgs
    Borgs New Member
    PA
    Price and beef.
    GNTundra likes this.
  11. Jun 8, 2018 at 1:10 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Lower the rear so it matches the front, I used an SOS Performance kit on my '07
    GNTundra and Pudge like this.
  12. Jun 8, 2018 at 6:19 PM
    Pudge
    CT
    I like this idea. I've always lifted trucks but i think if i did any suspension changes on tbis one I'd lower it, front and back
    GNTundra and Rex Kramer[QUOTED] like this.
  13. Jun 8, 2018 at 6:56 PM
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    The 3/1 spacer + block leveling kits are generally ok for a pavement princess. I destroyed my stock shocks with a 3/1 kit because I was romping around trying to keep up with some of these long travel maniacs on rough terrain :rofl:I had no problems with it for the first few months when I wasn't trying to destroy my front shocks; ie driving to/from work & occasional dirt roads on the way to shooting
    The spacers reduce the amount of travel your front suspension has before it either bottoms out (upward motion is stopped; usually using the shock body itself) or maxes out the downward range of motion of your UCA's/tie rods/etc.
    joonbug and 4x4_Angel like this.
  14. Jun 8, 2018 at 7:05 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    You can do 275/70/18 stock, if you want to pick the front up a little then just get you some 5100's on the middle setting. You can match the rears with 5100's or leave your stocks but for the price of a full set I'd go 5100 on all corners. I'm really waiting 6112's on the 1.9" setting with 5100 in the rear but the 6112's are hard to come by at the moment.
  15. Jun 9, 2018 at 11:39 AM
    cfred70
    Craig
    Ohio
    What's the downfall of the spacer idea like Rough country for $189 https://www.roughcountry.com/toyota-suspension-lift-kit-872c.html
    I understand it's not great for offroading as it loads up your shocks, but if my truck doesn't leave the pavement, will a kit like this be better looking than just putting 5100's in the front?
  16. Jun 9, 2018 at 11:42 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I thought about spacer lifts but went overkill instead and got radflos with UCA
    zcarpenter92 and 4x4_Angel like this.
  17. Jun 9, 2018 at 11:54 AM
    cfred70
    Craig
    Ohio
    I'm basically looking for the best way to get a little more aggressive stance without breaking the bank. If I was offroading/trail riding I'd understand spending the money....just hard to justify a more expensive route for my glorified minivan lol. I just don't like that nose down look....wasn't sure if 5100's would be good doing just the front, or going with a $200 spacer lift
    4x4_Angel likes this.
  18. Jun 12, 2018 at 4:00 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    I would get in touch with someone at Toytec.They have lots of lift/level options.They have the best customer service in the biz.
    T-Rex266 and 4x4_Angel like this.
  19. Jun 12, 2018 at 4:03 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Agreed! Love the guys at @Toytec Lifts! Some of the best customer service around!
    They will answer your questions....just tell them what you are looking for. I have a leveling lift from them and i have a little one still in a car seat/booster seat.
    T-Rex266 likes this.
  20. Jun 12, 2018 at 5:13 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    +1 on 5100’s, in coil spacers, and 6112’s even radflos (but those may be a little overkill for a PP)
    Talk with someone from @Toytec Lifts . They’ll set you on the right path.
  21. Jul 5, 2018 at 8:46 PM
    dawgfan706
    dawgfan706 New Member
    This might be a dumb question, but if I bought the 6112/5100 setup or the old man emu 612 kit from Toytec should I be buying UCAs as well?
  22. Jul 5, 2018 at 8:54 PM
    ninjajay
    Spoolston, TX
    cutting it close for the OME's, not needed for the 6112's, but nice to have for both
  23. Jul 5, 2018 at 9:11 PM
    Since you already have the front end dissembled I would. Never know if you change ur mind on lifts down the road.
  24. Sep 7, 2018 at 3:13 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
