OME BP-51 Suspension systems IN STOCK
Discussion in 'Suspension' started by Toytec Lifts, May 30, 2018.
  1. May 30, 2018 at 11:43 AM
    Toytec Lifts
    Toytec Lifts [OP] New Member
    Denver, CO.
    That is right guys, the newly released BP-51 suspension system for the 07+ Tundra's are now IN STOCK here at Toytec!
    Bring race technology to your adventures with OME’s BP-51 Suspension kit, featuring revolutionary patent pending technology developed to deliver unparalleled on and off-road performance.
    These bolt-on, big bore, position sensitive internal bypass shock absorbers have been developed and tested to provide exceptional ride comfort around town with significant amounts of end-zone damping for exceptional chassis control and handling off road.
    BP-51 shock absorbers provide greater levels of damping at each end of the stroke based on position and velocity of the piston. This provides a comfortable and compliant ride during normal driving, improved control over challenging terrain and prevents harsh topping/bottoming out through bumpy roads. Damping performance is easily adjustable across a wide range in both rebound and compression, allowing the driver to customize the vehicle’s ride performance for road conditions, vehicle load scenarios and personal preference.
    The body, reservoir and components are all made from aircraft grade (6061 T6) aluminum, with a type 3, 40 micron hard anodized finish, ensuring exceptional heat dissipation and resistance to corrosion and stone
    damage.
    Designed, developed, tested and manufactured entirely in-house by ARB’s team of Old Man Emu engineers to guarantee the highest possible quality, all BP-51 shock absorbers come with a 3-year/37,000 mile warranty
    Check it out HERE
    [​IMG][​IMG][​IMG][​IMG]
  2. May 30, 2018 at 11:47 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I assume both front and rears are 2.5’s?
  3. May 31, 2018 at 10:32 AM
    fjrohrs
    fjrohrs New Member
    Curious if the diameters of the shocks are the same as well. Thanks!
  4. May 31, 2018 at 11:03 AM
    I'll see if I can locate the diameter specs!
  5. May 31, 2018 at 11:21 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
  6. May 31, 2018 at 12:04 PM
    xtyfighterx
    Ty
    North Idaho
    Someone buy my fox stuff so I can fund these
  7. Jun 2, 2018 at 6:55 AM
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    badass!
  8. Jun 2, 2018 at 7:39 AM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    So much want for these! Best looking setup out there.
    @xtyfighterx pm me if you are interested in selling your Fox setup.
    TheBeast likes this.
  9. Jun 2, 2018 at 8:35 AM
    I'm almost ready to work at Chippendale's to earn enough to get them........................................ :laser: :cookiemonster:
  10. Jun 2, 2018 at 9:00 AM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    can someone in the know explain what this does better that the other mid travel stuff that is out there (fox, king, ads, icon ect...). obviously it comes with springs that the rear shocks are tuned for so thats a plus. no upper control arms needed?
    and i am by no means saying this kit isnt legit just curious what the advantages/disadvantages are.
    thanks
    goffredo and zcarpenter92 like this.
  11. Jun 2, 2018 at 9:16 AM
  12. Jun 2, 2018 at 10:57 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    thanks for the read. now to wait for the real word results
  13. Jun 2, 2018 at 12:19 PM
    There are quite a few real world results. Several TacomaWorld members run with them among numerous other Taco owners. There's not much real world results out on the Tundra setup. They have only been out less than a WEEK. What are you expecting???? LOL..... Check out TacomaWorld.com.
    zcarpenter92 and T-Rex266 like this.
  14. Jun 2, 2018 at 2:56 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I’d also be curious about valving.
  15. Jun 2, 2018 at 4:45 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    i understand they have only been out a week, not expecting anything right now. i also understand that they work great on tacomas, but as we all know just because one thing works great for one vehicle doesnt mean its going to do the same on the next. again im sure this is an excellent set up. just waiting to see how they work on our truck
    Boudin and Black Wolf like this.
  16. Jun 2, 2018 at 6:35 PM
    PhilActual
    PhilActual New Member
    Phil
    2018 Doublecab SR5 5.7 4x4
    SDHQ ABS guards, Hondo Garage/Ram phone/GPS mounts, 275/65r18 duratracs
    Are these rebuildable? If so how much is the kit and can most shops perform the task?
    zcarpenter92 likes this.
  17. Jun 3, 2018 at 10:05 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I believe that they are, haven’t looked at the site on price yet myself. That’d probably be a question for @Toytec Lifts
  18. Jun 3, 2018 at 10:14 AM
    Adjustable both ways and internal bypass. 3yr/36000 warranty...Who has that warranty? Any reasonably proficient shop should have no issues with them. Although the OME design engineers I think dabbled in rocket science on these..:thumbsup:
    Can be used with stock UCA's per ARB. We are only talking about 2" to 2.5" lift.
  19. Jun 3, 2018 at 6:17 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    HighDesertSurfer and Black Wolf like this.
  20. Jun 3, 2018 at 6:35 PM
    PhilActual
    Phil
    Great! More suspension to consider! These look like what I want!
    Black Wolf likes this.
  21. Jun 5, 2018 at 8:47 AM
    Theonlyway
    Theonlyway New Member
    User
    any suspdension i order has 4 year unlimited mile warranty :)
  22. Jun 5, 2018 at 8:52 AM
    Any????
    Theonlyway[QUOTED] likes this.
  23. Jun 5, 2018 at 9:02 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    These set-up has been available for Land Cruisers, Tacomas, etc. for years. I gave up on them offering the kit for Tundras. You could read about the 'real world' performance of these kits on other forums. The response seems to be overwhelmingly positive.
    Toytec Lifts[OP] and Black Wolf like this.
  24. Aug 20, 2018 at 5:33 PM
    DallasTundra
    DallasTundra New Member
    2014 Tundra CrewMax SR5 4X4 5.7L Silver Sky
    2" MotoFab leveling Kit, 2Crave NX-5 wheels(5X150 +15 offset to fill in fender flares space), 275/60R20XL Nitto Terra Grappler G2 Tires, VLEDs Triton V3 Switchbacks, TRS Morimoto XB LED Fog Lights, CCI Chrome Grille, 2019 LED Headlights, Extang Solid Fold, Texas Edition, Leather, Nav, JBL, OEM Flares, Husky WeatherBeaters.
    How’s the ride comfort on the road for long hauls? Better than OEMs I hope.
  25. Aug 21, 2018 at 6:58 AM
    Toytec Lifts
    Denver, CO.
    Night and day difference!
    -David
  26. Sep 4, 2018 at 5:17 AM
    fjrohrs
    fjrohrs New Member
    With all of the hype around new 3.0 shocks I’m curious if we were able to determine if these were 2.5s? Thanks!
  27. Sep 4, 2018 at 5:31 AM
    Stewie
    Stewie New Member
    2016 Crew Max
  28. Sep 7, 2018 at 3:50 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    These look AWESOME! I wish I could afford these! Anyone want to adopt me??? lol
  29. Jan 18, 2019 at 6:40 AM
    CorpsmanUp
    CorpsmanUp Professional Plugger of holes.
    2018 Tundra SR5 Double cab 4x4
    Tyger side steps
    @Toytec Lifts Has anyone been able to find out if these BP-51s are able to be rebuilt? These are in my wishlist on the site, just wanna make sure I dont have to spend another $3500 once these get worn, thanks!
  30. Jan 18, 2019 at 8:34 AM
    Toytec Lifts
    Denver, CO.
    Yes, but you have to send them to ARB for rebuild.
    CorpsmanUp[QUOTED] likes this.
