Shims for MX4 rail installation
Discussion in 'Tonneau Covers, Caps and Shells' started by southpoint, Jun 1, 2018.
  1. Jun 1, 2018 at 12:46 PM
    southpoint
    southpoint [OP] New Member
    2017 4x4 DC SR5 MGM
    Anyone else had to use shims for the MX4 rails attaching to the bed caps on a 2017 Tundra? The rails will be nowhere near level without them.
    Looks like I need to call Bak for them. Never saw a mention of it until I got everything out ready to install. I guess I could fashion some but I assume they have them since they mention it in the install sheet.
  2. Jun 1, 2018 at 12:57 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    When I installed mine last month, the shims were already attached to the rails... they are just theses little hard foam like pads spaced along where the rails meet the inside of the bed
  3. Jun 1, 2018 at 1:33 PM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    Mine did not come with the shims. I installed without and dont have any problems. Everything lined up fine and latches work perfect. Dont think the shims would hurt though.
  4. Jun 1, 2018 at 2:10 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    No need for shims on my g2
  5. Jun 1, 2018 at 2:46 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    I don’t have my MX4 anymore. Sold it. But I recall from the install instructions our gen Tundra didn’t need the shims, it wasn’t in the specs.
