  1. May 31, 2018 at 4:15 PM
    Sunnier
    Sunny
    San Diego, CA
    FLAT :thumbsup:
    Albertaundra[QUOTED] likes this.
  2. May 31, 2018 at 8:47 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Whoops did it again. Just pulled the trigger on the upper rails for the bedslide and the 5 bin package deal. Will throw the pics up when I get it all and have chance to install it.
    I'm hoping the setup will better suit my needs and will look like this when all done.
  3. Jun 1, 2018 at 4:58 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    This is awesome, where did you purchase from? Does it add a lot of weight back there?
    mgm16trdpro[QUOTED] likes this.
  4. Jun 1, 2018 at 5:29 AM
    mgm16trdpro
    Northern NJ
    Tnx. I bought the slide and mounting rails privately for 400. The slide when it was new sells for about 1200. The rest of the setup I bought last night directly from bedslide, the co that obviously makes the bedslide lol. The install kit, basically 4 bolts and anchors was 15, the upper rail retro kit which allows u to mount the 2 upper long bins was 269. The 5 bins, 2 upper, 2 lower all mount on rails, plus the 1 cross bin that lays on slide they have a 5 bin package deal for like 419. The owner gave me a code for 10% off if I bought last night so for it all it was like 630. Anything ordered over 99 qualifies for free shipping.
    I loved my last setup. The only thing was with the bedslide it sits 4 inches up from bed floor. With the DB cross bin being 8 inches deep I would've lost that upper area to store load things toward the front of the cab if I left it. I wanted to have access and be able to load cargo from front to rear so I decided to go this route.
    The bedslide does add weight. It's about 188 lbs and u can feel it back there. However after driving around a few days without the permanent install I decided it's not enough weight and doesn't sacrifice the ride quality enough to keep me from doing. The bins I doubt add much weight at all. It's all in the slide. The extra weight makes my truck feel a little softer in the suspension. Since the weight is evenly distributed across the floor it doesn't impact handling too much. U can feel it's there but it's not bad.
    Sunnier likes this.
  5. Jun 1, 2018 at 5:52 AM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    Install went pretty smooth. The video 12voltsolutions made explains and shows everything you need to do. Install is about an hour. Only one wire to cut and solder. It was to small for my strippers so I used and utility blade. It took me a couple times to program the key. But I’m sure it was operator error. I was getting excited to see it work.
    The biggest pain was when the steering wheel locked up on me removing the 2 screws on the column. You can’t start the truck with it locked. Had to put the key to auxiliary and turn the wheel to the “free side” to unlock it. I’d do that first before you tear the dash apart.
    Everything went back together easily and the unit fits in the kick panel.
  6. Jun 1, 2018 at 7:45 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    New wheels and tires. #thatnewtiresmell
    JJ305, Sunnier, jjstu123 and 26 others like this.
  7. Jun 1, 2018 at 8:01 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Toned down the chrome a little bit.
    Before
    After
  8. Jun 1, 2018 at 9:43 AM
    owb2gp
    owb2gp New Member
    ID
  9. Jun 1, 2018 at 10:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I backed into a concrete pillar in a parking garage.....luckily the hitch reciever sticks out a bit further than everything else and took 100% of the tap.
    I should go buy a lottery ticket.
    Sunnier, 1UPPER, Erichudgins and 5 others like this.
  10. Jun 1, 2018 at 10:54 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Looks sweet!!!
    monaco730[QUOTED] likes this.
  11. Jun 1, 2018 at 11:29 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Will be sweet!
  12. Jun 1, 2018 at 11:34 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I like that. Did you get your parts from Roman?
  13. Jun 1, 2018 at 11:57 AM
    owb2gp
    owb2gp New Member
    ID
    Yes.
    040Tundra[QUOTED] likes this.
  14. Jun 1, 2018 at 12:41 PM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Found a cap for my truck - Only took 1 year of searching:
    Which made me have to do a rush job on the bed rail system to attach cap ( Didn't have time to paint):
    And finally found my BAM Muffler - again 1 year of searching, but who can beat $400.00 for new. :
    Been a great week
  15. Jun 1, 2018 at 12:49 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    sexy
    Sunnier and TXDrifter like this.
  16. Jun 1, 2018 at 4:02 PM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    Looks great! Go inferno!
    monaco730[QUOTED] and 4x4_Angel like this.
  17. Jun 1, 2018 at 4:04 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    Received and installed my Proclip mount and Holder. 01057648-29F6-4693-878A-5F37EF3FDC1D.jpg
    1UPPER, Stroke250, Paulskie and 3 others like this.
  18. Jun 1, 2018 at 7:57 PM
    Donski17
    Donski17 New Member
    Donald
    Jacksonville, FL
    2017 Blazing Blue Tundra 4X4
    I wish I had been so lucky this week... I was backed into while I was in Lowe’s, missed the hitch and bumper and gave me a nice little dent in the tailgate and the need for some paint....
    to brighten my spirits though I installed some NFAB predator pro nerf bars, and my stubby antenna arrived so that’s installed now too. Now just waiting on the plasti dip to dry on the chrome cup holder so I can reinstall that along with the Tufskinz inserts.
  19. Jun 1, 2018 at 8:02 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Let her get lots of compliments at the Sun Fan event :)
  20. Jun 1, 2018 at 8:45 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I put on my new tail lights and swapped out all my lights with VLEDs.20180601_202004.jpg 20180601_210400.jpg 20180601_180801.jpg 20180601_181006.jpg 20180601_210240.jpg
  21. Jun 1, 2018 at 8:59 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sweet! Like it
    Larmand[QUOTED] likes this.
  22. Jun 1, 2018 at 9:02 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Thanks all were fairly simple. I did have a hiccup with a couple, didn't know they were 1 way. So I had to pull and turn them around.
  23. Jun 1, 2018 at 9:20 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    They are nice on the cement. They are the Autosaver88 from Amazon. Basically Winjet knockoffs, but cheaper, better reviews and good fitment. Very easy swap and install, just provide your own reverse lights. This is with the VLEDsSmartSelect_20180601-231908_Gallery.jpg
  24. Jun 1, 2018 at 9:29 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Did you have to solder the wires from the back of the tail light to the truck wiring? Or is it plug and play? I can't tell from the Amazon description vs. conflicting pics...
  25. Jun 1, 2018 at 9:32 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    It was all plug and play! Two stock, light housings, unclip from wiring harness and clip to replacement. The 3rd you use your reverse bulb.
    Sunnier and 040Tundra[QUOTED] like this.
  26. Jun 1, 2018 at 10:16 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Now you have the taillights i want! :angrygirl: so shopping at your place!
  27. Jun 1, 2018 at 10:47 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Get an easy out
  28. Jun 1, 2018 at 11:03 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
  29. Jun 2, 2018 at 4:57 AM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    Blacked out my windows!
  30. Jun 2, 2018 at 5:16 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    4x4_Angel likes this.
