Tires - Speed and Shifting Impacts
Discussion in 'Wheels & Tires' started by 4Runner, May 29, 2018.
  1. May 29, 2018 at 3:03 PM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Since installing my new Rays in Nitto Ridge Grapplers 295/70/18 I noticed 2 things. My actual speed is around 3mph faster than my speedometer at 60. That was expected and it’s my understanding I need to install the hypertec unit to correct. Is that what everyone else is using? On the shifting, I’m not certain but I feel like my truck is shifting at different points and downshifting more noticeable since installing the new rims/tires? Is this expected? Thanks for any info.
    Heatonrx likes this.
  2. May 29, 2018 at 3:13 PM
    Vizsla
    Vizsla pretend2send
    Whatch your speed on gps, mine was only off 2 mph, not worth correcting imo. Did you disconnect the battery after the upgrade?, this creates a re-learn. I don’t think it’s absolutely necessary, as the transmission is always adapting, but might get you back to happy faster.
    Les7311 and TheBeast like this.
  3. May 29, 2018 at 3:16 PM
    koditten
    Kirk
    Midland of the Mitten
    Are you sure it isn't the other way. My actual speed is slower than what speedo says.
    Run the Waze app and see your true speed.
    TheBeast likes this.
  4. May 29, 2018 at 3:25 PM
    4Runner
    Columbia, SC
    I’m using my Uniden radar detector gps speed and it was perfectly in sync with the speedo before rims/tires. I’m pretty steady at 3mph off at 40, 50, and 60. Then it widens from there. Narrows from 0 to 40. Yes, my actual speed is higher than my reported speedo speed.
    Shifting - I’ll keep monitoring.
  5. May 29, 2018 at 3:32 PM
    TheBeast
    TheBeast The Beach
    truck looking good.... it's all that matters :)
  6. May 29, 2018 at 3:50 PM
    Vizsla
    Vizsla pretend2send
    I should of added if a re-learn was done, the transmission does downshift very noticeably for a bit. Truck does look great!
  7. May 29, 2018 at 4:04 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    In theory I think the difference in speed should be the same percentage as the circumference difference from stock. This seems to be accurate based on a speed app I used to determine true mph.
    I didn’t bother correcting it. And, the odo is showing less than what I’m actually accumulating, that’s good for resale no? lol
  8. May 29, 2018 at 6:11 PM
    4Runner
    Columbia, SC
    My OCD is kicking in is all....my computer is reporting worse gas mileage than I’m really getting.
  9. May 29, 2018 at 6:19 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Normal because you are actually travelling more miles than odometer registers
    JoshuaA likes this.
  10. May 29, 2018 at 6:29 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Listen to this guy. He is wisdom.
    TheBeast[QUOTED] and Prostar 190 like this.
  11. May 29, 2018 at 6:33 PM
    Your truck is looking good what more do you want. Lol
  12. May 29, 2018 at 7:29 PM
    4Runner
    Columbia, SC
    So pretty much everyone just leaves it as is and it sounds like the shifting will adjust overtime. I can live with that.
