CrewMax Overlander
Discussion in '2.5 Gen Builds (2014-2021)' started by smslavin, Jul 21, 2017.
  1. Apr 25, 2018 at 4:17 PM
    #271
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    It’s clean. I know where everything is and I even have a little spot to work...
  2. Apr 25, 2018 at 4:22 PM
    #272
  3. Apr 25, 2018 at 4:35 PM
    #273
    smslavin
    Hudson Valley
    Some stuff
    i do what i can with a 1945 garage. not everyone can have a shiny new one. :boink: :bananadead:
    i am thinking about trying to finish it out though. through up some insulation and drywall along with more light.
    itsdchz and zcarpenter92 like this.
  4. Apr 26, 2018 at 10:31 AM
    #274
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    Love this bumper!!!. Been looking for something like this. Added to the wanted MOD list.
  5. Apr 26, 2018 at 10:35 AM
    #275
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    These sliders do look good and are local. Not too expensive either. Just curious what you changed on them @smslavin ...
  6. Apr 26, 2018 at 10:38 AM
    #276
    smslavin
    Hudson Valley
    Some stuff
    actually, i didn't change anything. i had thought about it but i spent some, no, a lot of time, finessing the alignment. they fit in there in just fine now with no issues.
    JDL17CM4x4[QUOTED] likes this.
  7. May 5, 2018 at 2:14 PM
    #277
    smslavin
    Hudson Valley
    Some stuff
    well, that wasn’t necessary to keep on the truck...
    GodlessPro likes this.
  8. May 6, 2018 at 11:16 AM
    #278
    smslavin
    Hudson Valley
    Some stuff
    Let’s do this.
    9210F750-CA5E-4296-BEC5-2AAFAFE11787.jpg 53E6B908-450A-44BF-A5A4-675BE4403FD9.jpg
  9. May 6, 2018 at 12:19 PM
    #279
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    That doesn’t look like a cheap project! Full sound system and sound deadening material right?
    smslavin[QUOTED][OP] likes this.
  10. May 6, 2018 at 4:18 PM
    #280
    Jelly as fuck! :jellydance: must. hear.
  11. May 6, 2018 at 7:48 PM
    #281
    smslavin
    Hudson Valley
    Some stuff
    Holy crap. That was a job but didn’t quite finish. Sound deadner is in. New speakers. All the wiring. I just have to connect it all. Having a few fitment issues with the box from tech12volts so I need to give James a call tomorrow. Might not have time to connect it all until later this week.
    T-Rex266 likes this.
  12. May 7, 2018 at 8:16 AM
    #282
    JDL17CM4x4
    Daniel
    Riverside, CA
    More to Come ...
    Now that's one hell of a project.
  13. May 8, 2018 at 7:08 PM
    #283
    smslavin
    Hudson Valley
    Some stuff
    Little bit a work done tonight on the stereo.
    Tomorrow evening I’m going to wire up the harnesses, get the FiX connected and run the remote wire to the amp. Then I need to mount the new tweeters in the rear doors and connect the power. Hoping to be done by the end of the week.
  14. May 8, 2018 at 10:07 PM
    #284
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    I appreciate how detailed your thread is a long with the amount of good quality and tasteful parts you’ve installed on your own. Looking forward to joining you on the overland Tundra journey. Trading in my 2017 Tacoma DCSB for a 2018 SR5 Crewmax Cement. Didn’t quite complete all of what I wanted on the Tacoma however already put 45k miles on it since August last year. Looking forward to seeing what you do next. Thanks for all the good info.
    smslavin[OP] likes this.
  15. May 9, 2018 at 6:22 AM
    #285
    smslavin
    Hudson Valley
    Some stuff
    more than happy to help. you're going to love the new truck.
  16. May 11, 2018 at 4:29 PM
    #286
    smslavin
    Hudson Valley
    Some stuff
    And... we’re live. Holy. Crap. So. Excited.
    I still need to run the DRC switch and tune it but, wow. Sounds amazeballs.
  17. May 11, 2018 at 4:48 PM
    #287
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    That's BADASS!!!:headbang:
  18. May 22, 2018 at 7:43 PM
    #288
    smslavin
    Hudson Valley
    Some stuff
    With a little guidance from @SoCalDave, a little trimming and one or two obscenities, the compressor is finally mounted.
    It got dark so I’ll have to wire it tomorrow. At least I retrieved the wrench I dropped into the engine bay.... :anonymous:
  19. May 27, 2018 at 11:51 PM
    #289
    bcpnick
    bcpnick New Member
    Utah
    2018 Tundra TRD Sport DC
    Just read through this whole thread and my mind is pretty well blown. Thank you.
  20. May 28, 2018 at 5:05 AM
    #290
    smslavin
    Hudson Valley
    Some stuff
    You’re welcome. :cheers:
  21. May 28, 2018 at 11:41 AM
    #291
    smslavin
    Hudson Valley
    Some stuff
    And the truck now has air...
    Need another project now. Everything I had stock piled in the garage is now installed. Might be time to start working on the HAM and/or dual battery...
  22. May 28, 2018 at 11:43 AM
    #292
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Have you thought about running lines and adding fittings to the Front and Rear bumper? Would keep you from having to pop the hood and give you air at the bed. Good for filling up bike tires, blowing out the bed, etc.
    zcarpenter92 and T-Rex266 like this.
  23. May 28, 2018 at 12:04 PM
    #293
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Do the HAM install next. Selfish on my part, I'm trying to decide if I want to do the same thing on my new truck that I did last time or try something different.
  24. May 28, 2018 at 3:48 PM
    #294
    smslavin
    Hudson Valley
    Some stuff
    i have. i'm not sure what parts and pieces i'd need to put that together so, i need to do a little research. plus, if i'm doing that, i might as well cut out the stock spare and mount a 5 gallon air can in there...
    hah. yea, i'll probably do the HAM. my youngest daughter has been on me about getting that installed as she wants to connect to the ISS and chat with the astronauts. i'll be getting a yaesu ftm-400. thinking about mounting the 'brain' in the center console with a few cut outs for ventilation. i don't use all of that space anyway. faceplate will go on the overhead console and replace the 'map' clip. i haven't taken it apart yet so i'm not totally sure how it'll work. NMO mount for the antenna in the roof. going to pick up two antennas. a comet ssb-1 for tighter trails since it's short and flexible. plus a comet ssb-5 for when i've got a little more space and need the extra range.
    i ran the power cables across the front. you can go down in between the headlight and the plastic liner. then, if you pull the grill off, you'll see a cross bar that runs in front of the radiator at the bumper level. i've got a few other bundles running across there so i followed those with some new zip ties. on the driver side, go between the liner and the light and the battery is right there.
    for the switch cable, that's quite a bit longer. i went up to the firewall then inside the drop down cover below the wipers. across the engine bay, out the other side and right to the switch pro. plenty of length.
    on the switch pro, i have the compressor wired to switch 8. however, you do not need the 30 amp circuit, so you can just wire one connection.
    let me know if you need some pictures or further explanation.
    GodlessPro[QUOTED] likes this.
  25. May 28, 2018 at 4:15 PM
    #295
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    I'll echo everyone else and say I'm jealous of your truck, and appreciative of the detailed writeups. One thing nobody else touched on, though, was a tiny line from your original post: "as well as a backcountry mobile photo studio. I've got some plans for my photography business that I don't see a lot of people doing are being willing to do."
    Care to elaborate on what your backcountry photo studio entails? Hauling a portable darkroom around to places off the pavement is why I bought my Tundra, so I'm curious about what you're up to! Especially since it affords you the ability to outfit your rig so nicely!
    KevinK and smslavin[OP] like this.
  26. May 28, 2018 at 7:11 PM
    #296
    smslavin
    Hudson Valley
    Some stuff
    you sir, get more kudos than i can possibly give right now. 4x5 or 8x10? and you're developing tintypes in the field?!? :bowdown:
    the chemicals needed for that aren't exactly the nicest things to lug around. especially in the back of a truck bouncing through the desert. i would jump at a chance to meet you somewhere and just watch you do your thing.
    i can't elaborate too much right now but, i'm in the process of convincing my first client to take a chance on the idea.
    NomadicFrog[QUOTED] likes this.
  27. May 28, 2018 at 7:26 PM
    #297
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Not sure how I never saw your build until recently, but awesome job!
  28. May 28, 2018 at 7:46 PM
    #298
    smslavin
    Hudson Valley
    Some stuff
    i'm just stealthy... :spy:
    Cfincke[QUOTED] likes this.
  29. May 28, 2018 at 7:53 PM
    #299
    NomadicFrog
    Mark
    Flagstaff, Arizona
    Ha! Well, it isn't like it's nitro glycerin...not quite as combustible anyhow. Although I have considered rigging up something like a nitro transport of old to cushion the collodion - not for safety's sake, but to reduce shaking up sediment. I was having a bunch of trouble after bouncing out to Toroweap, so I stashed my collodion by the overlook for the next day.
    I have both 4x5 and 8x10 cameras, but my portable setup isn't really big enough for 8x10...so far. Need to work on making a bigger box now that I have the Tundra. (I had been working out of either my Ford Focus hatchback or my fiancée's ancient Ford Escape.)
    Unfortunately I started an actual 9-5 job recently and don't get out as much as I would like, but I will let you know when I head north again. (When I think of "getting out there" it's to southeast Utah near the Colorado border. Also want to head back to Dinosaur National Monument and other Colorado locations slightly closer to you.)
    I'm definitely interested to hear what you're up to, photographically, when you feel ok lifting your self-imposed embargo. :)
  30. May 28, 2018 at 9:09 PM
    #300
    Sand Sailor
    Sand Sailor New Member
    Garrett
    2018 TRD SPORT
    TRD Dual exhaust
    Wow what a insane build. You are a wiring and electrical wizard. Thank you for sharing all of your work.
