Anybody else made a "grabber pole"????
Discussion in 'General Tundra Discussion' started by Aron9000, May 28, 2018.
  1. May 28, 2018 at 1:19 AM
    Aron9000
    Aron9000 [OP] New Member
    Aaron
    Been thinking about this problem I have with my new to me 2011 Tundra. Its kind of a PITA to load/unload certain sized objects out of the bed. Lighter stuff that would ride better up against the cab, like bags of trash, a nasty ass metal varmit trap, I have to hop into the bed to get it out of there.
    I do miss my small 2004 Tacoma, 2wd/reg cab truck in that regard, you could reach right over the bed to load/unload stuff. For my short ass 5'6" self, it was the perfect hobbit sized truck lol. Not a lot of room in the cab, but then again I'm a small guy so it never bothered me, I had a tool box on it to act as a trunk as well.
    Anyways, I've come across some inspiration with that shepard's hook my bird feeder hangs from. Why don't I have something like that in my truck??? You know, keep it in the floor of the cab under the rear seat, take it out to pull crap out of the bed that I can't reach.
    Anybody else use something similar, fabbed up something like this, what are your suggestions??? I had a worn out broom, but the handle wasn't long enough to reach to the back of the bed, it was only like 4 or 5' long.
    4x4_Angel and Black Wolf like this.
  2. May 28, 2018 at 1:36 AM
    Wally World, under 30.00
    NewImprovedRon, JH5370 and 4x4_Angel like this.
  3. May 28, 2018 at 1:51 AM
    Aron9000
    Aaron
    Your link sucks. Takes me to Wal-Mart's home page.
    Also my granny did have one of those "grabber" poles, but it would be too short for this application. It was like 3' long, for short elderly people trying reach something they dropped on the floor.
    4x4_Angel likes this.
  4. May 28, 2018 at 2:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  5. May 28, 2018 at 2:41 AM
    Sunnier
    Sunny
    San Diego, CA
  6. May 28, 2018 at 2:43 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    This is one reason, I like Wheel to Wheel nerf bars, instead of Cab Length.:thumbsup:
  7. May 28, 2018 at 2:43 AM
    koditten
    Kirk
    Midland of the Mitten
  8. May 28, 2018 at 6:01 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I have a "live Show Stick" available at Tractor Supply or any farm store,
    koditten likes this.
  9. May 28, 2018 at 6:03 AM
    koditten
    Kirk
    That would work grabbing stuff from the sides, but I need something long enough to reach the front from the back. My soft topper sides don't get rolled up until warm weather.
  10. May 28, 2018 at 6:06 AM
    I keep my grandkids around to do that for me.
  11. May 28, 2018 at 6:12 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I didn't have this issue until i put the leveling lift and big tires on my truck.....now i definitely have to climb in the bed
  12. May 28, 2018 at 6:33 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I've used a boat hook for years. Works great 90% of the time. Some things are not easily hooked and dragged.
    Notachickmagnet likes this.
  13. May 28, 2018 at 8:11 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    20180528_100743.jpg This came with my Access tonneau cover, it comes in very handy.
  14. May 28, 2018 at 10:03 AM
    Pinstripe
    Pinstripe New Member
    2015 Tundra SR5
    DayStar leveling kit, BFG AT KO2s
  15. May 28, 2018 at 7:20 PM
    Notachickmagnet
    Notachickmagnet New Member
    I had a black metal floor lamp that I hated looked like a Shepard hook...took it apart, worked perfect. Till someone stole it !!
  16. May 28, 2018 at 7:25 PM
    Best top corner bed step half the price of the amp research bed step
    4x4_Angel[QUOTED] likes this.
  17. May 28, 2018 at 7:29 PM
  18. May 28, 2018 at 7:31 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I carry a 2' stepladder
  19. May 28, 2018 at 8:15 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I am nearly unable to crawl into my truck with my fused back and knee replacement. Solution 1 was the Decked system and side opening cap:
    The deck allows me to reach everything from the sides and the drawers extend the gear out.
    Solution 2 is a combination of hooks and picker/grabbers. Some are home made some you buy. I can take some pictures tomorrow if you want
    1UPPER, JH5370 and 4x4_Angel like this.
  20. May 28, 2018 at 9:21 PM
    4x4_Angel
    Bree
    Funky Town, Texas
  21. May 28, 2018 at 9:57 PM
    :thumbsup:
  22. May 29, 2018 at 5:09 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I wedge a black stained wood divider into the existing grooves and added a magnetic LED light under the cover. I know this doesn’t solve when I remove it to use the whole bed but most of the time I only use the last 1/4 and nothing slides back.
    4x4_Angel, WarEagle Tundra and 1UPPER like this.
  23. May 29, 2018 at 7:22 PM
    Aron9000
    Aaron
    I've thought about that before as well. Right now I have some ugly black rusty nerf bars on my truck. Going to take them off and see if I miss them.
    Kind of afraid I'm going to scratch the paint lifting stuff into the bed like that though.
    Also thanks for the reply guys, might go to the boat store and buy the boat pole.
  24. Feb 19, 2020 at 4:25 AM
    Slayer
    Slayer Member
    Slayer
    I'm old & with a beat up body.. so this was a necessity for me.
    I took a 4' collapsing painters pole & made up a hook that screws into it at the end.
    only 2' long when collapsed.
    then made mounts for my super-strut bed rail.
    can also screw on different attachments for different needs
    ..Slayer
    15whtrd, NewImprovedRon and 2manytoys like this.
  25. Feb 19, 2020 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    I would think a hockey stick could work pretty good too.
