Left Rear King Shock
Discussion in 'Suspension' started by OCxCEMENT, May 25, 2018.
  1. May 25, 2018 at 10:19 PM
    OCxCEMENT
    OCxCEMENT [OP] HI :)
    Orange County, CA
    2018 Tundra Crew Max Cement TRD-Off-Road 4x4
    Does anyone have this issue with it hitting the mount? If you look closely toward the right on the edge there is a spot with paint missing near the outlet to the reservoir...I did a quick search but did not notice any related threads. However, other than notching it any ideas on solutions?030E25BE-0F4F-453F-BBCE-96F510463531.jpg
  2. May 25, 2018 at 10:37 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Ive seen this on the tacoma forum with Icon shocks.
    Im thinking notching be the only way to fix it.
    ColoradoTJ and OCxCEMENT[OP] like this.
  3. May 25, 2018 at 10:38 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Put a washer (1/8"-1/4" thick) under the mount between the shock. Do it on the other side too.
  4. May 25, 2018 at 11:12 PM
    Baja Mike
    South Bay, Ca.
    Also, can you rotate the shock body itself? Is there enough slack in the hose to the reservoir to do that?
    15whtrd likes this.
  5. May 26, 2018 at 5:08 AM
    Vizsla
    Vizsla 2 = 2.5
    Yes it’s common, look closely at the mount. There is usually a ghost line where it should of been trimmed/cut when made, compare with passenger side. Not all are like that but many are, here is mine before and after trimming. See the line?
    FBDFB5CE-1BE2-4695-B713-BFF5DF19EA27.jpg 7A5786E1-3289-4934-B3F4-128D062810A4.jpg
  6. May 26, 2018 at 5:20 AM
    Trim the mount.
    Careful when shimming shocks. If you do, cycle the suspension and make sure the bump stop is engaging before the shock bottoms out. Great way to screw up a shock or bend/snap off a mount (usually on the axle).
    dcsleeper408 and OCxCEMENT[OP] like this.
  7. May 26, 2018 at 10:17 AM
    OCxCEMENT
    Orange County, CA
    Yes, I have tried it. I got it to move a little but I ran out of room with the reservoir mount. I'll either shim or notch it I suppose.
  8. May 26, 2018 at 10:17 AM
    OCxCEMENT
    Orange County, CA
    Thank you all for all the input!
  9. May 26, 2018 at 10:24 AM
    OCxCEMENT
    Orange County, CA
    Yeah I see the fine line there. Did you Dremel or use a grinding wheel?
  10. May 26, 2018 at 10:30 AM
    Vizsla
    Vizsla 2 = 2.5
    Cut off wheel on a small air grinder.
    OCxCEMENT[QUOTED][OP] likes this.
  11. May 27, 2018 at 9:38 AM
    aztundraguy
    aztundraguy New Member
    2017 Tundra CM TRD Offroad
    6112/5160,Icon Billet UAC,Diff Drop,Billet .250 shim Lean Correction, CB Bump Stop Extensions, 275/70r18 w/ 18x9 +12 offset
    OCxCEMENT[OP] likes this.
