Onboard shower/rinse system
Discussion in 'Recovery & Gear' started by calitundra1224, Sep 27, 2017.
  1. Sep 27, 2017 at 11:30 AM
    calitundra1224
    calitundra1224 [OP] New Member
    ADRIAN
    2017 Tundra TRD 4x4
    Bilsteins, methods, BFG KO2
    WaterPORT is a rugged 3.3 shower/rinse system specifically designed for Toyota Trucks. The system self pressurizes of your home garden hose. The user has the ability to manually fill the system and pressurize with a bike pump or compressor when a garden hose is unavailable. The tank heats up in the sun and is made from food grade plastic. We are offering 15% off on the website, use code "showeroff"
    ColoradoTJ likes this.
  2. Nov 27, 2017 at 4:46 AM
    zackbremer
    zackbremer New Member
    Da Z
    what happens when u go somewhere cold?
  3. Nov 27, 2017 at 5:13 AM
    Ice cubes for your whiskey!
    Prostar 190 likes this.
  4. Nov 27, 2017 at 5:14 AM
  5. Nov 27, 2017 at 5:16 AM
    zackbremer
    Da Z
    i was thinking more like cracked plastic lol..if only there was a way to wire a 12v heater element to this...id be all over it
  6. Nov 27, 2017 at 5:25 AM
    Sunnier likes this.
  7. Nov 27, 2017 at 5:27 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Awesome product! Calitundra is a good dude as well!
    1UPPER and speckmon like this.
  8. Dec 23, 2017 at 6:35 AM
    Digodell
    Digodell New Member
    Shane
    I have had one of these for about six months now, very happy with the product. Use it more than expected. Primarily use it while hunting to rinse the dogs, clean birds etc... very well built the 3.3 gallons is enough for two days for me. I purchased a longer expandable hose which works great.
    bthatch49 likes this.
  9. Dec 23, 2017 at 11:33 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Should add a heating element with a timer that plugs into 12v like the rinsekit company did.. with a cap on truck be nice to still get warm water when it's cold..
  10. Apr 16, 2018 at 6:58 PM
    Dadx4
    Dadx4 New Member
    Looks pretty awesome. But I was looking for something bigger. I'm thinking of a 4 day camping trip, family of 6. Dishes and showers. I wish they made this system with a bigger tank.
  11. May 11, 2018 at 7:13 AM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Tried using the promo code, no bueano.
  12. May 26, 2018 at 12:21 PM
    Stig
    Stig New Member
    You can build your own with a 12v pump for about the same price and have 26 gallons available and not worry about pressurizing the tank. If you have a Northern Tool around you, they have sprayer tanks in 26 gallon and 13 for about $50. They are thick plastic and do not bulge when full. Just not food grade so don't drink it. A sureflow 12v pump is less than $100 on Amazon.
    There are multiple ways to heat the water too. Usually with a tankless water heater and LP tank (eccotemp L5 for example) or heat exchanger connected to the heater/coolant hoses. Or you can go even cheaper and just pressurize the Northern Tool tank in the same manner as the bicycle pump.
    The water port looks like a nice option as something you just order and quickly install without doing much work. I'll admit I had to make multiple trips to Lowes until I had all the fittings I needed but in the end I have 26 gallons of hot water.
    Sunnier, 1UPPER and nowayout like this.
  13. May 26, 2018 at 12:33 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Did you ever do a write up on the parts you used for your DIY water storage project?
