Issue with driving at slow speed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Prime2016, May 7, 2018.
  1. May 7, 2018 at 11:07 AM
    Prime2016
    Prime2016 [OP] New Member
    Deerfield Beach, FL
    2016 Tundra SR5
    Hey everyone,
    I have a 2016 Tundra SR5 Double Cab 4.6L. First time truck owner and it's great, don't think I ever want to go back to a car, I use it for recreation and commute. However, immediately after I bought it, I started running into intermittent issues at slow speeds. Either leaving my driveway, taking off from a red light or stop sign, and even slow riding the parking lot, I felt like when I pressed on the gas it acted almost as if it were in neutral and would only rev loud and not move forward much until it finally shifted into gear. It didn't feel normal and it definitely didn't feel like that when I was test driving it along with other 4.6L double cabs. I took it to the dealership and they told me it was perfectly fine and no error codes came up from diagnosing. I told myself OK maybe this is just normal for a V8 truck - I didn't know. But it kept doing it after I took it home - so frustrating.
    After some research, I did an "idle-relearn" which seems to have fixed it for the moment - haven't driven it enough to feel completely comfortable about it yet, but it seems to drive like the other 4.6 double cabs I test drove before purchase. I was thinking maybe the previous owner hauled heavy loads on a daily basis and the truck was used to that style of driving? Any one else run into this? If you have, do you know what the root of the problem was/is and did you do anything to resolve yet?
  2. May 7, 2018 at 11:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    That doesn't sound normal. I would take a toyota tech with you on a test drive and get it to act up.
    Prime2016[OP] likes this.
  3. May 7, 2018 at 11:31 AM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Did you put gas at a shady place? Some times if you get watered down gas it’ll give a degraded combustaion vs normal gas and can cause your gas to pull and act funny
  4. May 7, 2018 at 11:44 AM
    n2deep
    n2deep Pavement Princess
    Mine only does that from a cold start. If i start mine and immediately shift into gear mine does something similar. Now i let it idle down about 20 sec before I shift and never have an issue. Its like the transmission needs to circulate some fluid before you shift. Maybe have the transmission serviced.
  5. May 7, 2018 at 11:50 AM
    Take to another Toyota dealer, get a 2nd opinion??? Bad gas??? still under warranty???
  6. May 7, 2018 at 1:09 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    I haven't, but maybe the previous owner has. I bought it with 18k miles and I've put on about 4k so far. I stick to the top tier brands in my area which is Chevron, Shell, and Mobil. Thanks for that info though... That's interesting but not completely surprising that a gas station would do that.
  7. May 7, 2018 at 1:24 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    2013 Bdl Cab 4.6 (68K on the odo) and I've experienced the same thing when pulling away at slow speed or shifting into D after backing out of a parking spot. After resetting the computer (unhooking the battery for 2 hours) I've not noticed it since.
  8. May 7, 2018 at 1:42 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    Yeah, still have all the factory warranties. Basic warranty will expire soon though, 36 months/36,000 miles. Will go to another Toyota dealership if it happens again at the level it was before i did the idle-relearn. It's possible the previous owner put bad gas in it.
  9. May 7, 2018 at 1:44 PM
    Hope it gets resolved quick
    Prime2016[QUOTED][OP] likes this.
  10. May 7, 2018 at 2:03 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    n2deep: yes! I noticed that happening so I began to let it warm up and it was doing it much less but the issue didn't completely go away. I assumed newer vehicles didn't have to go thru a warm-up process after starting but it appears I am wrong. I owned a 2006 corolla before this and never had to warm it up, but I also do live in South Florida
    bvia: That's amazing. I unhooked my battery for about 30 minutes, not sure if that was enough time. It feels better, but not 100% sold yet due to my time behind the wheel since that.
  11. May 7, 2018 at 5:00 PM
    OceanSkyWolf
    2017 MGM CM
    Keeps up posted on your findings cause my mother in law and Gma experienced this same issue last week and we ran the gas out and it went away, when driving got through atelast all the rpms.
  12. May 7, 2018 at 5:51 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    Will do and glad to hear they got rid of it!
  13. May 24, 2018 at 5:43 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    UPDATE: 24-May-2018
    Well the truck went back to sounding like annoying vacuum cleaner while driving at slow speeds (0-20mph). Sounds like too much gas being used for the amount of force being provided via the gas pedal.
    Sometimes it wouldn't make the sound but that was only when I had it warming up for a whopping time of 45 seconds to a minute and a half. I could tell this is the right time before taking off because the RPMs would suddenly dip to 800-900 from 1100-1200 and the the engine calmed. Anytime I drove off before any one of those factors the truck wasn't complying.. So thinking that even 45 seconds was probably a ridiculous amount of time to warm up, I unhooked the battery again, this time for three hours - and just as last time it started driving beautifully. It didn't have that vacuum cleaner sound and it purred deep and clean while smoothly shifting.
    A day later it started doing it again, it sounds like my shop-vac is under the hood during this process.
    Not sure what to do...I was really hoping unhooking the battery was going to solve my problem.
    A) Try emptying out the gas tank completely? I have already run it down to "4 miles until empty" then refilled.
    B) Take it a different location Toyota dealer for second opinion?
    C) Is this a lemon and should I trade now to get the most value?
    D) OTHER - I'm all ears
    Thanks everyone for all the help before and in advance.
    OceanSkyWolf[QUOTED] likes this.
  14. May 24, 2018 at 5:56 PM
    OceanSkyWolf
    2017 MGM CM
    Thanks for the update! Sorry to hear it’s still there.
    A) looks like it’s not a gas issue
    B) doesn’t hurt getting 2nd options
    C) wouldn’t say it’s a lemon just yet
    D) try checking fuel filter, fuel pump. I mean it’s a 2016 you shouldn’t see any issues with needing to swap out parts. What’s the mileage? Check your EGR valve maybe it’s clogged or dirty. Maybe go to autozone and pick up a fuel additive/cleaner. But first things first check your fuel filter and egr should be simple to check those first and go from there
  15. May 24, 2018 at 6:01 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like the clutch fan is staying engaged.
    Sunnier and Prime2016[OP] like this.
  16. May 24, 2018 at 6:29 PM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    Thanks, super helpful info! My mileage is about 23k now. This sounds like it can be a DIY project? I'll YouTube that to see if I can get any luck, plus look into the fuel additive/cleaner. I have no warning lights on the dash, and according to Toyota there's no error codes so "nothing's wrong". In your opinion, do you think they would still service or more importantly replace these parts for me @ no cost, i.e. powertrain warranty service without proof of requiring repairs? I guess I could just ask them and see what they say too.
  17. May 24, 2018 at 6:44 PM
    Blueknights75
    Ron
    Clayton, NC
    I personally do not suggest adding any type of fuel additive or cleaner. Did this one time to my previous truck and had to replace fuel pump and charcoal canister after about 2 days. Maybe just coincidence but I don’t think so. Take it to another Toyota dealer and tell them to fix it. Tell them that you are leaving it there until they correct the issue. Keep us posted.....
    Prime2016[OP] and OceanSkyWolf like this.
  18. May 24, 2018 at 7:51 PM
    OceanSkyWolf
    2017 MGM CM
    Your ECM will set codes but will never set the check engine light, you light will only set if it repeats. I know with GM/Ford that’s how the ECM works. Maybe the tech at Toyota can share with you the codes that have not set yet. They can also get you your trucks current condition, all the sensors that record data... not sure if they will share this with you but won’t hurt to ask. I’m able to get all this info for Ford/FCA/GM but no Toyota since we don’t supply the ECM yet for them, we only provide the safety sense equipment for now.
    Anyways would first take to another dealership to get a second opinion.
  19. May 24, 2018 at 7:53 PM
    OceanSkyWolf
    2017 MGM CM
    There is also a thread in here where you can ask true Toyota mechanic would also ask there as well
  20. May 24, 2018 at 7:53 PM
    OceanSkyWolf
    2017 MGM CM
  21. May 24, 2018 at 10:38 PM
    909engineer
    909engineer New Member
    2017 Silver SR5 CM
    ^^^^This!
    15whtrd[QUOTED] likes this.
  22. May 25, 2018 at 7:03 AM
    spn4125
    spn4125 New Member
    I think my 2016 does the same thing. When the truck is cold it almost feels like the transmission is slipping at slow speeds especially shifting between 1st and 2nd gear. The engine will rev up a little bit before engaging during on the gas off the gas maneuvering like in a parking lot, but only when cold. It also has a small delay when shifting into D after start up. Out of habit I always wait 30 secs. and let the engine idle down before moving. I bought the truck used with 27k miles and didn't notice this for first few weeks of ownership. I'm due for a service and will mention it when I bring it in, I'm still under bumper to bumper. Will first try the relearn procedure.
  23. May 25, 2018 at 8:29 AM
    Prime2016
    Deerfield Beach, FL
    2016 Tundra SR5
    Yes, this sounds so familiar. However, this happens when my truck is completely warmed up as well. My issue happens even immediately after spending three hours of highway driving. I re-posted this in the "Ask the Toyota mechanic" thread, I'll keep you all posted.
    I'm curious if that relearn procedure will work for you, it worked for only just a limited time for me.
  24. May 25, 2018 at 8:51 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    this. ^
  25. May 25, 2018 at 11:11 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Along with having the check the viscous fan hub, request that they check the transmission fluid level. You would have to leave it at the shop long enough for the transmission to cool to the right temperature range.
    You might want to go to a different dealer though, anyone who says that there can’t be an issue if there are no fault codes /warning lights has just proved that they are blatantly ignorant.
    OceanSkyWolf and Prime2016[OP] like this.
