Favorite Pic of Your Truck
Discussion in 'General Tundra Discussion' started by OceanSkyWolf, May 13, 2018.
  1. May 23, 2018 at 11:40 AM
    #151
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Step # 0.5 - Buy a camera :D
  2. May 23, 2018 at 12:37 PM
    #152
    What are your presets at in Lightroom?
    OceanSkyWolf[OP] likes this.
  3. May 23, 2018 at 12:40 PM
    #153
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
  4. May 23, 2018 at 1:49 PM
    #154
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    I have a couple DSLRs, but the one I was posted is an iphone 6s panorama with minor color temperature correction right on the phone. The key is the lighting. It was taken during the golden hour.
  5. May 23, 2018 at 7:09 PM
    #155
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I wish I’d have taken a pic of my Chevy on the tow truck. Damn, had so many opportunities, just never crossed my mind.
    All these tundras look great.
  6. May 23, 2018 at 8:23 PM
    #156
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    I thought this post was about your favorite pictures of your Tundra , not retouched not photoshopped just what you have now or then, the two I posted of my trucks earlier are the original pictures nothing done to them.
  7. May 23, 2018 at 10:50 PM
    #157
    OceanSkyWolf
    OceanSkyWolf [OP] New Member
    2017 MGM CM
    Ehhh yes but the main point was to show off you truck with your fav pic of it. Sooo does it matter if you touch up the pic? No it’s all personal preference. Remember this thread is to show off that bad ass tundra with one pic!!!!!
    JoshuaA, TXMiamiFan and Boerseun like this.
  8. May 23, 2018 at 11:13 PM
    #158
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The first weekend I had it.
    DalTee, ColoradoTJ, OR18TRD and 11 others like this.
  9. May 24, 2018 at 12:06 AM
    #159
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I’m finishing up a 6” Pro Comp Lift installation with King front and rear OEM’s, 20x12’s, and 37x13.5 tires. It looks quite a bit different than it does in this pic.
  10. May 24, 2018 at 4:35 AM
    #160
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  11. May 24, 2018 at 7:02 AM
    #161
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
  12. May 24, 2018 at 8:16 AM
    #162
    Jeff@SR5
    Jeff@SR5 New Member
    Jeff
    Gardner, KS
    2014 Toyota Tundra Crew Max
    LED Cab Lights, Seat Covers, console organizer, color matched hood bulge with platinum grill, plasti dipped in black, Supreme suspensions 3-1 leveling kit, 295/70/18 Copper STT Pros. Chrome covers on handles and mirrors which will be taken off shortly.
  13. May 24, 2018 at 8:36 AM
    #163
    Matty4wd
    Matty4wd Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Some action shots from a hooligan weekend ;)
    024319AF-0FF8-4179-9422-EFA756D9B4BB.jpg 36DBD54C-9D80-4717-8552-9E794AA6FD1A.jpg
    ColoradoTJ, OR18TRD, RLHULK and 12 others like this.
  14. May 24, 2018 at 9:12 AM
    #164
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Ya man truck was parked when I got hit I was inside shopping. It wasn’t to bad pretty minor but still had to tear the bumper apart and replace a bumper end and a forum member here donated a tail light very thankful. So it will be back to it’s old self as soon as all the parts are here.
  15. May 24, 2018 at 1:34 PM
    #165
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Thanks, it's freedom! I agree my image is a little over the top lol, I'm not trying to compete, just sharing.
    Technically speaking even normal jpeg shots done with a smartphone, it's doing basic re-touching in milliseconds. A true unadulterated image file is flat, lacking color, sharpness, contrast etc. And a jpeg from an iPhone X will look much better than a jpeg from a iPhone 3G. How about no portrait mode? No panoramics? No cropping? No simple brightening? etc. Or one could take a snapshot with a Fuji using a built-in film preset, still jpeg, no retouching. I think it's hard to draw the line.
  16. May 24, 2018 at 2:14 PM
    #166
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    I thought the OP asked to post one pic, not two.
    Just saying...:boink:
  17. May 24, 2018 at 2:31 PM
    #167
    OceanSkyWolf
    2017 MGM CM
    :anonymous:
    JoshuaA likes this.
  18. May 24, 2018 at 3:09 PM
    #168
    geno0506
    geno0506 New Member
    Michael
  19. May 24, 2018 at 5:38 PM
    #169
  20. May 25, 2018 at 10:35 AM
    #170
    OceanSkyWolf
    2017 MGM CM
    Which specific one is it? Lol asking for a friend of course..
    JoshuaA likes this.
  21. May 26, 2018 at 6:20 PM
    #171
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    At this point I like this picture the best
  22. May 26, 2018 at 6:28 PM
    #172
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Chillin....
  23. May 26, 2018 at 6:43 PM
    #173
    markdk1108
    markdk1108 New Member
    Mark
    2010 Tundra TRD Rock Warrior Package 5.7 Supercharged
  24. May 26, 2018 at 7:38 PM
    #174
    swede78
    Lars
    westminster co
    Nothing yet
    One pic for each of my beauties
  25. May 26, 2018 at 7:44 PM
    #175
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  26. May 26, 2018 at 11:01 PM
    #176
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  27. May 27, 2018 at 3:18 AM
    #177
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    That’s a Beast!!
    Juddrussell and TheBeast[QUOTED] like this.
  28. May 27, 2018 at 4:58 AM
    #178
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
  29. May 27, 2018 at 7:29 AM
    #179
    OceanSkyWolf
    2017 MGM CM
    :thumbsup::thumbsup:
  30. May 27, 2018 at 1:45 PM
    #180
    JH6124
    JH6124 New Member
    California
    2011 Toyota Tundra Rock Warrior
    King 3.0 coilovers in front King 3.0 3 tube bypasses in rear Camburg UCAs 35” General x3 Grabbers Painted head light Mod Method 17” double standards Smoked tail lights and 3rd brake light. KC Hilite A pillar cube LED lights. Pedal commander
