RIP Pro...Long Live the Limited
Discussion in '2.5 Gen Builds (2014-2021)' started by GodlessPro, Sep 25, 2017.
  1. May 22, 2018 at 12:36 PM
    #361
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Matt needs to do pinstripe mod again. At least it’s free. Not much labor too.
  2. May 22, 2018 at 12:58 PM
    #362
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    Glad you found something and can start making it your own, but can imagine it's a tough transition. That sucks about the valuation, at least they worked with you a little. Ran into the same problem when my 2002tii BMW got totaled, they kept trying to value it as a standard 2002 and I eventually got them to use a different type of blue book valuation -- not sure what it was called exactly but it was essentially a blue book designed for collectible/rare vehicles. I'm sure the challenge with the Pros is that they are being valued at resale for rarity but are still so new that there isn't a long term valuation difference for them to base things off of. Now I'm curious to call my insurance and see how they are valuing my truck.
    Keep me posted if I can help you with any mods and will keep an eye out for stuff. Nice that you can at least get the skids and sliders. Budbuilt got back to me about their 38 gallon skid -- apparently it's also flat and suffers from low hanging nut syndrome but they will weld on ramps to the leading edge for you if you want.
  3. May 22, 2018 at 2:51 PM
    #363
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Or it's the most expensive mod... :anonymous:
    Depends on if you go Stage 1 or Stage 42.
  4. May 22, 2018 at 3:22 PM
    #364
    Tundra4us
    Tundra4us New Member
    "D"
    Oh man sorry to hear and see the destruction of your pro! Main thing is your OK. Good luck on your re-build, there are too many choices out there! If I recall, SCS should be getting a container soon
  5. May 22, 2018 at 4:17 PM
    #365
    GodlessPro
    GodlessPro [OP] Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I went and rescued my sliders and custom fuel skid. The sliders could use some love, so I'm going to call a local powdercoat shop to see what they will charge to strip and recoat.
    One last time.
  6. May 22, 2018 at 4:21 PM
    #366
    GodlessPro
    Matthew
    NorCal
    SCS put me on the notification list for the next shipment. If I can find a good deal, I might go with Method NV instead.
  7. May 22, 2018 at 4:26 PM
    #367
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Your pro looks good! All the tires are holding air!
  8. May 22, 2018 at 4:39 PM
    #368
    GodlessPro
    Matthew
    NorCal
    The flat one had been swapped.
    831Tun, Black Wolf, joonbug and 2 others like this.
  9. May 22, 2018 at 4:41 PM
    #369
    TheBeast
    TheBeast The Beach
  10. May 22, 2018 at 5:14 PM
    #370
    GodlessPro
    Matthew
    NorCal
    I'm not going to, but if anyone is interested let me know and I can give you the name of where I think it is going to be auctioned off.
    Do you know of a good powdercoat shop around here? I found one that looked promising on yelp, but would rather have a direct recommendation.
  11. May 22, 2018 at 7:55 PM
    #371
    Cemented
    Manuel
    2017 Cement TRD Pro
    I don’t unfortunately, haven’t had to get any done around here.
    831Tun, joonbug and dcsleeper408 like this.
  12. May 23, 2018 at 7:50 AM
    #372
    Cemented
    Manuel
    2017 Cement TRD Pro
    Is it just me or does the Cement color look slightly different between the two?
  13. May 23, 2018 at 8:43 AM
    #373
    GodlessPro
    Matthew
    NorCal
    I was thinking the same thing, but it is probably just lighting and dirt.
    Cemented[QUOTED] likes this.
  14. May 23, 2018 at 8:47 AM
    #374
    It is a bit odd but maybe the way the sun is hitting it as mentioned.
    GodlessPro[OP] likes this.
  15. May 23, 2018 at 9:48 AM
    #375
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    the pro was Sement.. the limited is semen.
  16. May 23, 2018 at 9:51 AM
    #376
    GodlessPro
    Matthew
    NorCal
    :argue:
    joonbug and dcsleeper408[QUOTED] like this.
  17. May 23, 2018 at 9:52 AM
    #377
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    sorry forgot to add the silent T..
    so the limited is Semen(T) with a silent T. As silent as possible.
  18. May 23, 2018 at 10:01 AM
    Well that sure does explain it!
  19. May 23, 2018 at 2:19 PM
    #379
    GodlessPro
    Matthew
    NorCal
    I had to drive to Sunnyvale today which meant I was on the road before the sun was up. Wow, the '18 headlights are incredible compared to the '17. I can actually see in the dark now.
  20. May 23, 2018 at 2:34 PM
    #380
    BlueBottle
    '16 Platinum 4x4
    See fine print
  21. May 23, 2018 at 2:44 PM
    #381
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :woot: Something positive!!!
  22. May 23, 2018 at 4:58 PM
    #382
    TheBeast
    TheBeast The Beach
    " I crashed a 17 so I could get the new LED lights on my truck " :)
    Pudge, TRD15559, 16TRD and 4 others like this.
  23. May 23, 2018 at 10:08 PM
    #383
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I contemplated this while at the dealer today helping a friend get a tacoma. The platinum was calling my name.
  24. May 23, 2018 at 10:15 PM
    #384
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    The 2018 LED headlights are so much better. I was shocked how much better I could see at night once I installed them on my truck.
  25. May 25, 2018 at 4:33 PM
    #385
    GodlessPro
    Matthew
    NorCal
    Today was an expensive day:
    MCM 3.0 Mid Travel Kit
    RCI Skids
    Color Matched Grill and Mirror Caps
    SCS Ray10's (still waiting for the invoice on these)
    Thanks to the BASTRDS for helping me make some difficult decisions.
  26. May 25, 2018 at 4:40 PM
    #386
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You're new truck is already causing me envy. I can't wait to see it all done. I think it's gonna be better than the last one and certainly better than mine:thumbsup:
  27. May 25, 2018 at 4:42 PM
    #387
    TheBeast
    TheBeast The Beach
  28. May 25, 2018 at 4:42 PM
    #388
    TheBeast
    TheBeast The Beach
    you going with the same tires again ?
    GodlessPro[OP] and dcsleeper408 like this.
  29. May 25, 2018 at 4:55 PM
    #389
    Vizsla
    Vizsla 2 = 2.5
    Very nice!, sometimes a do over is good. I like my 18 more every day, lots of improvements(tire pressure is nice for me). I’m removing my front cement bumper corners this week(painted oe chrome), they are not perfect but nice with just 2 little chips that are under the lip that goes up behind the valance. I can’t imagine any issue with my replacements(just black plastic ones), if so, and interested, they are yours for the ride.
  30. May 25, 2018 at 5:09 PM
    #390
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And I think the 18’s have tire pressures displayed on the dash. I want that.
