3rd Gen Lowering and flares options:
Discussion in '2.5 Gen Tundras (2014-2021)' started by SprinterAE86, May 20, 2018.
  1. May 20, 2018 at 5:27 PM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Hi there!
    I was reading up on some products out there about available lowering kits. Most of them are a little bit more drastic than others. Like the TRD, you lose the payload capability once you install the kit. I want to lower/level the vehicle about 1-2" and increase the payload at the same time.
    As for the fender flares, I really like the Honey D. But I do not like the idea of drilling holes and cutting parts. I have not seen the 2" version to compare with all the 4" that's being posted.
    Air design was the next option, but I have to see it on a on an oem height atleast to make a sound judgement call.
    The truck will be my DD, work and tow vehicle.
    Phase 1 (in the works)
    Leer topper (should be in by next week)
    Install an 80/20 skeleton to reinforce topper
    Install 4 linear actuators to lift the topper
    Install rails on both cab and topper to accept legs for crossbars/platform
    Upfit the inside of the bed/topper
    Phase 2
    Add rear suspension leveler (air spring, jounce style spring, roadmaster active or Torklift)
    Phase 3
    18x9 wheels -12
    285.65.18
    Color match fender flares (Honey D 2" to be modified for no drill installation)
    LED upgrades
    Phase 4
    https://phoenixandroidradios.com/pr...-navigation-radio-for-toyota-tundra-2014-2017
    Any input and pointing me to the right direction will be a great help!
    Thanks!
    Fuumanstu likes this.
