Removing Door Panels
Discussion in '2nd Gen Tundras (2007-2013)' started by Ronmat4X2, May 20, 2018.
  1. May 20, 2018 at 12:59 PM
    Ronmat4X2
    Ronmat4X2 [OP] New Member
    2007 4X2 TRD
    Well first door is drivers door, every time i open it there is 2 popping noises and was wondering where to start removing this inside door panel. OK 2nd door is my passenger side rear door
    it will not open from the inside, when i pull on the inside handle you tell that its not
    connected to anything its too free compared to the other passenger door. any help would be appreciated.
    Thanks
    ron
  2. May 20, 2018 at 1:42 PM
    Ronmat4X2
    2007 4X2 TRD
    Thanks, the 3rd time i watched i figured out the truck had doors on it!!!
    831Tun, Trooper2 and Pudge like this.
  3. May 20, 2018 at 1:44 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    For popping could be loose linkage, check 2 bolts with 10 mm (think) socket, black piece in pic, door side. Tightening mine stopped popping. The bolts loosen and cause noise. Can check all doors.20180520_153955.jpg
    Pudge likes this.
  4. May 20, 2018 at 2:24 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This is a really good point, never would have thought of that
    Trooper2[QUOTED] likes this.
  5. May 20, 2018 at 2:29 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Make sure you don’t have the child safety lock engaged.
    Once you remove door panel you will find two cables at the top of panel.
    Make sure both are seated into the clips used for unlocking the door, and the lock clip is also firmly snapped in so the cable is not free moving.
    Hope this helps...
  6. May 20, 2018 at 2:31 PM
    I had to do it on my front passenger side on my 09 Taco. Tighten up the two 10mm's and good to go.
  7. May 20, 2018 at 3:27 PM
    Ronmat4X2
    2007 4X2 TRD
    Checked those 2 but not it, sounds like inside
  8. May 20, 2018 at 3:32 PM
    Ronmat4X2
    2007 4X2 TRD
    Hey thanks for the heads up about the CHILD safety lock, that was the rear door issue.LOL
    glad the rear door was simple.
    Les7311 and aRabidLunatic like this.
  9. May 20, 2018 at 5:15 PM
    Les7311
    Now for the popping sounds.
    The panel sits flush against the door frame.
    Run finger along the panel and frame. One of the snaps could have come loose. If that’s the case, press panel in hard.
    the snaps could be loose by the speakers.....
