Million dollar question
Discussion in 'Wheels & Tires' started by Heatonrx, May 16, 2018.
  1. May 16, 2018 at 9:50 AM
    Heatonrx
    Heatonrx [OP] New Member
    I know since I’ve look there are so many posts on wheel size. I’ve seen this set up and people say it works. Others shoot it down and say you’d need a cmc. Who thinks I won’t ? 18x9 +1 offset . 295/70r18 Nitto Ridge Grapplers with a 3/1.5 Eibach w/shackle. This will be on my 2018 CM and I want flares. Safe choice is +20 offset. What’s everyone think?
  2. May 16, 2018 at 9:53 AM
  3. May 16, 2018 at 9:54 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I came in here thinking it was an offer to sleep with you for a million dollars. Leaving disappointed . . .
  4. May 16, 2018 at 8:23 PM
    Heatonrx
    No advice?
  5. May 16, 2018 at 8:26 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    A lot depends on your UCAs. All the trucks are slightly different so there's no sure answer. +1 offset You're VERY likely to have rubbing issues.
    Sunnier and JoshuaA like this.
  6. May 16, 2018 at 8:39 PM
    Such a money slut. Your wife know about this?
  7. May 16, 2018 at 8:48 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I second this because I'm on same tires +18, just needed liner pushed in and mudflap removed, the angle of +1 will likely catch the cab. As said, you won't know OP until after alignment.
    831Tun[QUOTED] likes this.
  8. May 16, 2018 at 9:12 PM
    Sunnier
    Sunny
    San Diego, CA
    Same. <sigh>
    She knows. She was his excuse to see that movie.
  9. May 17, 2018 at 2:22 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    :rofl::rofl::rofl:
  10. May 17, 2018 at 4:18 AM
    TXMiamiFan
    Jose
    She handles the money
  11. May 17, 2018 at 4:20 AM
    AgentOfWrath
    AgentOfWrath New Member
    Tampa Florida
    2015 Tundra Crewmax 4X4
    Flowmasters | 4 Inch Lift | Linex | Diamonback HD Cover | 40 Inch LED Light Bar \ Rock Lights
  12. May 17, 2018 at 4:34 AM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Every truck is different
    But in all likelihood you will need a chop
  13. May 17, 2018 at 4:52 AM
    Heatonrx
    Anyone run a +18 or +20 with flares? Why do Methods come 18 and Fuel 20 but other specs the same? Maybe I should dump the flares.
  14. May 17, 2018 at 5:49 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    it's early enough still. i'll play.
    my method NVs are +18. i have bushwackers. edge of tire meets edge of flare. front bumper has been removed and an aggressive body mount chop has been done.
  15. May 17, 2018 at 5:52 AM
    Heatonrx
    Got a pic?
  16. May 17, 2018 at 5:59 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    @Heatonrx follow the lead of this guy. Occasionally he knows what he’s talking about, and if he’s done a CMC then odds are he truly needed it with his setup.
    Here’s his build thread to search
    https://www.tundras.com/threads/crewmax-overlander.14888/
  17. May 17, 2018 at 6:34 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    occasionally being the key word... :goingcrazy: :bananadance:
    there might be some in the build thread. i don't have anything handy at the moment.
  18. May 17, 2018 at 7:01 AM
    94slowbra
    john
    new orleans
    2016 TRD pro
    My methods are +25 with a 295 70 18 and I have a chop. With another inch of offset I'd be willing to bet it's needed
