4.7 engine
Discussion in '2nd Gen Tundras (2007-2013)' started by chop123, Mar 20, 2018.
  1. Mar 20, 2018 at 7:29 AM
    chop123
    chop123 [OP] New Member
    clifton
    2007 dark green tundra sr5
    I know most of you guys seem to have the 5.7 engine,but I have a 2007 sr5 4.7 with now a 114,000 miles on it what problems have you guys with that engine had? I have had the timing belt changed at 92,000 is there anything I need to be looking out for,i think it calls for plug replacement at 120,000.I purchased it with 82,000 on it,records said that the air pumps had been done.At this time it is running fine no problems.I did take it to Toyota dealer to get transmission fluid checked at 100,000 and they said it was fine and to not worry about flushing it and to leave it alone since it was working fine.I just want to know if there is anything I need to worry about,this will be my last vehicle for a while.My wife is up next for a new car she has 2000 sr5 4runner with 300,000 on it runs good,dash lights and radio lights don't work and back bumper is rusting out,tough as nails.Thanks
  2. Mar 20, 2018 at 7:37 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    The 4.7 is a great engine. The only thing I ever did to mine was replace water pump and timing belt at 100k.
    The main problem associated with it is the secondary air pump failure. The valve gets stuck shut or open during cold temps and throws a code. Since this feature is only used to control emissions under a cold start, it isn't necessary and can be bypassed with a simple module if that problem comes up.
    Other than that the 4.7's were pretty bulletproof. Keep up with regular maintenance and it should last you a very long time.
  3. Mar 22, 2018 at 12:08 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    4.7??? time to pull that junk out and get a real motor...:thumbsup::D you need a 376cu 700+HP 6.2L V8:yes:...I hope you credit card has a high limit :spending:https://www.a2speed.com/p-2931-hellcat-crate-engine-for-sale.aspx
  4. Mar 22, 2018 at 1:09 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    My 06 with the 4.7L has just a bit over 190,000 miles on it. I change the oil every 5k. Today, I did the T-belt/water pump. Original belt. No cracks, no stress Mark's. Looked great. Only did it because of the mileage. Look up the million mile tundra. It had a 4.7 in it.
    15whtrd likes this.
  5. May 4, 2018 at 1:35 PM
    Punisher17
    Punisher17 New Member
    I had a code for bank 2 sensor 2 on my 07 4.7. Ended up spending 500 and replaced all 4 sensors with OEM parts. Never had a problem since. Very easy to do and piece of mind all 4 are replaced new. And a huge fraction of the price a mechanic would do it for.
    mudslinger79 likes this.
  6. May 4, 2018 at 7:48 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    I also had to replace sensors in mine but , that's about it. I had a 2001 with the 4.7. You have a great engine. Sold mine at 309,000 miles and still had plenty of power. Yours is just now broke in. Keep your throttle body cleaned out and with regular oil and filter changes your engine should last for many miles. The only downside with the 4.7 is the starter placement.
  7. May 15, 2018 at 9:14 AM
    ivbyiv
    ivbyiv New Member
    Rust
  8. May 15, 2018 at 9:21 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I was going to say to look at the million mile tundra. The report on that truck was unbelievable after that many miles and it still checked out with high QC marks. I have the 4.7L in mine also, and haven't had any problems. 132k miles on it, I replace the water pump, timing belt and serpentine belt at 100k, plugs at 125k, and had the transmission fluid changed at probably 120k also. I did have the AIP stuff replaced under warranty. Stay on top of the regular maintenance and you should be good!!
  9. May 15, 2018 at 9:24 AM
    ivbyiv
    ivbyiv New Member
    Rust
    I should clarify that while I am still searching for a truck and waiting for funds to become available, I am definitely considering the 4.7, as it is a proven engine.
  10. May 15, 2018 at 9:28 AM
    Isn't the 07 and up a 4.6L and a 4.7L for 2006 and below.?
    15whtrd likes this.
  11. May 15, 2018 at 9:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I think they offered the 4.7 L in the second generation tundra just for 2007. Then the 4.6 L became the new deal.
  12. May 15, 2018 at 9:41 AM
    I always found it somewhat confusing. It seems the 2010 and up got the 4.6L's.
    Casper421 and 15whtrd[QUOTED] like this.
  13. May 15, 2018 at 9:57 AM
    parker44
    parker44 New Member
    I believe 4.7L was changed over in 2010. My 2008 has the 4.7L also, and I think they made them for 2009 as well.
  14. May 15, 2018 at 2:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I think I was mistaken. But I knew that they put the 4.7 L in the second gen that’s for sure.
  15. May 15, 2018 at 2:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Is it a diffetent engine? Or same but .1 Liter smaller? :notsure:
  16. May 15, 2018 at 2:22 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    It is a completely different engine, it is the UR series (4.6l) motor vs a UZ series (4.7l).
  17. May 15, 2018 at 2:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes and no timing belt on the 4.6 L as well as more horsepower. That’s all I know about it LOL are they dimensionally the same? Could you theoretically drop a 4.6 L in a first Gen tundra?
  18. May 18, 2018 at 5:12 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    39 more hp, maintenance free chain drive cams and hydraulic valve actuators (like the 5.7). It appears as though the 4.6 is only offered in the Tundra. Too bad it isn't available in the Taco and 4 Runner.
    15whtrd[QUOTED] likes this.
  19. Jul 3, 2018 at 5:01 PM
    Brian3UR
    Brian3UR New Member
    2013 Silver Sky DC 4x4
    Drop in K/N filter with TRD airflow accelerator BullyDog GT Tuner 2.5" Suspension leveling kit TRD rear sway bar Line-X bedliner Charcoal Filter (in air box) delete Deleted screen in throttle body gasket Coolant to throttle body bypass LED lighting inside bed and under hood Center console from 2007 Tundra with LED light for cup holder Small amplifier and subwoofer to enhance factory radio BAMuffler TRD Dual Replacement system (on order) LED headlights, fog lights, brake, tail and interior lights Side mirror glass with turn signal indicators (from Platinum model)
    It is a completely different engine.
  20. Jul 3, 2018 at 7:41 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    the 4.6L is a de stroked ( less stroke ) 5.7 L . It is used in the Lexus Gx 460 ( Prado) and some other Lexus I think . The 4runner had one year of the 4.7 L I love my 4.6L
    Brian3UR likes this.
