6112/5160 on today: Before and After
Discussion in 'Suspension' started by Borgs, May 14, 2018.
  1. May 14, 2018 at 8:00 PM
    Borgs
    Borgs [OP] New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Got them on today; 3rd setting.
    Before:
    After:
    As I understood, it is supposed to be level at the 3rd setting. It looks like it has a slight bro lean which I am not thrilled about. Rides nice, but I really notice the extra 2 inches up front - didn’t think I would.
  2. May 14, 2018 at 8:12 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Looks good :thumbsup: get some miles on em and they'll settle down, mine did.
    Borgs[OP] likes this.
  3. May 14, 2018 at 8:18 PM
    Borgs
    PA
    Thanks man. That’s what I heard.
    Casper3[QUOTED] likes this.
  4. May 14, 2018 at 10:45 PM
  5. May 15, 2018 at 2:02 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    They will settle down , but not sure it will be enough to take some of that squat out. I am @ top setting on mine, but went with a 1 " tapered block in the rear. This left me with a slight rake.
    Chucho, equin, jewsNbrews and 2 others like this.
  6. May 15, 2018 at 3:30 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Nice!! Where'd you find them? They seemed to be backordered everywhere I look.
  7. May 15, 2018 at 3:54 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    @Borgs your truck looks amazing! :jellydance:
  8. May 15, 2018 at 3:58 AM
    Nice. Get some ToyTec shackles and bushings. You can get 1" or 1.5" rear lift depending on setting. Icon AAL is another option too.
  9. May 15, 2018 at 4:03 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    @Borgs looks good. I'm sure it was worth the wait.
    MotoTundra likes this.
  10. May 15, 2018 at 4:35 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    A set of shackles on the rear, or add a leaf, will lift your rear 1.5 to 2 inches. Much better option than the block.
    As an added note measure from center of wheel to the top of fender well. This will tell you how much you are off front to back. Also measure L and R front to see if you are lower on driver side might need to add a shim to account for Tundra lean.
    TheBeast likes this.
  11. May 15, 2018 at 5:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    You should verify that it’s not on the top setting. I have the 6112/5160 and have no lean at all. In fact if anything maybe a slight forward rake.
    Edit.. I am on the 1.9 inch setting.
  12. May 15, 2018 at 6:27 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    1.9in will be the perfect level (one below top notch). I believe the top setting actually puts you just a hair nose high. Not so much it looks bad, but it does measure high.
    My 6112s at 1.9 have been "settling" for months, and my front is maybe a centimeter lower than the rear. With stuff in the bed, it drops to dead level.
    If its a huge deal to you... 1) take off the 6112s and adjust, or 2) blocks/shackles in the rear to gain an inch.
    Black Wolf likes this.
  13. May 15, 2018 at 6:38 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Nice truck! Measure it, could be near equal ground to the top of all 4 fenders, however, the roof line and windows give the illusion of Cali lean.
    Cheap easy fix are Toytec adjustable shackles (bronze bracket below on the left).
    Or Coachbuilder non-adjustable shackles, comes in varying sizes.
  14. May 15, 2018 at 9:04 AM
    Borgs
    PA
    Indeed
  15. May 15, 2018 at 9:06 AM
    Borgs
    PA
    I believe I got the last set in stock at 4wheelparts. They came missing a bushing and washer — but Bilstein sent me them.
  16. May 15, 2018 at 9:12 AM
    Borgs
    PA
    Mind taking a pic of the front assembly when you get a chance? I think I am on the 3rd setting but it doesn’t hurt to verify!
    This looks like the 3rd to me, no?
    Stormtrooper81 and JoshuaA like this.
  17. May 15, 2018 at 9:15 AM
    Borgs
    PA
    I am going to do some measuring. Not too much level ground around here to get dialed in. I may go this route. How easy to install?
  18. May 15, 2018 at 9:25 AM
    Mike's Custom Toys
    Mike's Custom Toys New Member
    Looks great Congrats on the last set of 6112's in the country.
    MotoTundra, rons23, Hondoman and 2 others like this.
  19. May 15, 2018 at 9:26 AM
    Borgs
    PA
    Literally!
  20. May 15, 2018 at 9:31 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Not sure, my buddy a mechanic installed a few things for me in his shop. I recommend paying a bit extra and replacing the stock poly bushings that go in the shackles, improves ride.
    Borgs[QUOTED][OP] likes this.
  21. May 15, 2018 at 10:23 AM
    MistrRoboto
    Virginia Beach, VA
    I can't believe the 6112 supply is so low! Any reason other than folks realizing its a great option for the money?
  22. May 15, 2018 at 10:36 AM
    Mike's Custom Toys
    Bilstein makes millions on factory installed products and thousands on aftermarket shocks. So they don't care too much on keeping up on demand. Over the years we have seen this happen over and over on their 5100's. The will pump out 1,000 sets and not put out another production run for 6 months. Its sad but has happened too many times for it to be a one time inventory shortfall.
    gs3hien and Stormtrooper81 like this.
  23. May 15, 2018 at 10:41 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    shackle would be my choice. 6112s are not adjustable without disassembling. My truck is level set at 1.9" but looks like it has some rake.
  24. May 15, 2018 at 10:53 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Yes you are on the 3rd setting. Mine are on the top setting. Photo for verification purposes.20180302_175938_1520041609206_001.jpg
    Stormtrooper81, equin and rons23 like this.
  25. May 15, 2018 at 11:09 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Sure, I will take a few pics myself. It looks like you are on the third. I’ll try to take a street pic of my truck as well. Give me until this evening.
  26. May 15, 2018 at 11:21 AM
    MistrRoboto
    Virginia Beach, VA
    My bad dude! I thought I read you say you were on the top setting. Once those things settle for a few days, you will be perfection. I wouldn't touch the rear for now.
  27. May 15, 2018 at 12:53 PM
    Borgs
    PA
    Perfect! Thanks so much!
  28. May 15, 2018 at 12:55 PM
    Borgs
    PA
    No worries.
  29. May 15, 2018 at 3:19 PM
    Borgs
    PA
    So the 6112's will settle more than the 5160's in the back?
  30. May 15, 2018 at 5:00 PM
    MistrRoboto
    Virginia Beach, VA
    The 5160s without blocks or shackles don't provide any lift, so that should stay the same. I jotted down my measurements somewhere, but can't find them... Mine definitely lowered a bit in the front over the first week or two.
