Drop some knowledge....
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Jan 24, 2017.
  1. Feb 27, 2018 at 8:05 PM
    #1081
    GoCboys
    GoCboys New Member
    2018 MGM CrewMax
    You’ve seen how the birds fly in a V formation and usually one side is longer than the other.
    Know why that is? . . . . There are more birds on that side!
    Thank you, goodnight :)
  2. Feb 27, 2018 at 8:05 PM
    #1082
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Mar 17, 2018 at 9:14 AM
    #1083
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    No 16 seed has EVER lost in the Round of 32!!! #MarchMadness :woot:
    NewImprovedRon likes this.
  4. Mar 17, 2018 at 9:29 AM
    #1084
    Trooper2
    JR
    Houston, TX (Suburban South)
    And for a quick check, -40 C is equal to -40 F. You can check your formula if in question.
    TXMiamiFan likes this.
  5. Mar 17, 2018 at 9:48 AM
    #1085
    Nike21
    Nike21 New Member
    FACT 1: All 50 states are listed across the top of the Lincoln Memorial on the back of the $5 bill.
    FACT 2: You just looked.
  6. Mar 19, 2018 at 3:02 PM
    #1086
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    #2 is wrong...........I don't have $5.
    TXMiamiFan, KevinK and NewImprovedRon like this.
  7. May 14, 2018 at 4:09 PM
    #1087
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    After learning a bunch from Reading 39 pages on this thread, I thought I would share a little knowledge. 1 MOA at 100 yards is 1 inch and 10 inches at 1000 yards. Anyone that hunts with a scoped rifle needs to have a working knowledge of Moa. For the vast majority of all rifle scopes made in America, MOA is the language of scopes. It can certainly save you time and money at the rifle range. It can also help you to understand how to hit that longer shot at three, four, or five hundred yards. Let me give you a simple example. Let's say that you just mounted a scope on your rifle and your scope turret indicates, "1 click = 1/4 inch @ 100 yards". So, you fire three shots and the center of your group is 4 inches low and 3 inches to the right. Rather than burning through a couple of boxes of ammo trying to adjust your group through trial and error, you simply adjust your elevation by 16 clicks up and adjust your windage by 12 clicks to the left. Then fire one shot to confirm your zero and you're finished. You just zeroed your rifle with four rounds instead of 40. Example number two. You consult your drop chart for your 308 Winchester which indicates drop of 15 inches at 300 yards, from a 100-yard zero. How do you adjust your scope? You simply convert the drop in inches to Moa. 15 inches divided by 1 MOA at 300 yards is 5 Moa or 20 clicks. Your rifle is now zeroed for that 300 yard shot. To return to your 100-yard zero, simply come down 20 clicks on your elevation. If you guys are interested in learning more, I will be happy to share. For you more learned Marksman, I acknowledge the 4.6% error in my calculations. I'm just trying to give those interested their first Peek inside the tent. I'm just saying I'm not interested in starting a crap storm. Again, more to come if anyone is interested.
    NewImprovedRon and TXMiamiFan like this.
  8. May 14, 2018 at 4:25 PM
    #1088
    TXMiamiFan
    Jose
    Thanks!
  9. May 14, 2018 at 6:16 PM
    #1089
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    There are 17.77 Mils in a degree.
    It's a Arty thing
  10. May 14, 2018 at 6:42 PM
    #1090
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Ha! Unlike you canon cockers, I was always a MOA guy rather than Milrad. I can do range estimation in my head with MOA but need a calculator for mils. I actually switched to the MOA variant, IPHY to make calculations on the run even easier. Nothing easier for me than inches/minutes×100=range in yards. Wind holds easy also. Distance to target in yards/100×windspeed÷10 for the 308 Winchester.
    And thank you for your service Shoe, no disrespect.
  11. May 14, 2018 at 7:39 PM
    #1091
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    If you drop a full can of Diet Coke and a full can of coke in a bucket full of water. The coke can will sink and the Diet Coke will float
  12. May 14, 2018 at 7:44 PM
    #1092
    War Machine
    War Machine SSEM # 5 3MW
    What’s the closest US state to Africa?
    Maine
  13. May 14, 2018 at 8:01 PM
    #1093
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Another one to add to the list...Venison (deer, elk)! Best for you per oz!!!
    Venison - 1oz
    Protein - 9 gms
    Fat - 0.9 gms
    KevinK[QUOTED] likes this.
