csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. Mar 12, 2014 at 8:42 AM
    #121
    Is one more sturdier than the other as far as longevity? Wasn't sure if the nite shades would help it stay longer prior to being scratched up/removed...if that makes sense.
  2. Mar 12, 2014 at 9:05 AM
    #122
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Na should both be the same to that respect. I will try scratch tests before I peal it off
  3. Mar 12, 2014 at 3:57 PM
    #123
    JonasSacredTundra
    JonasSacredTundra New Member
    On my 08 I used VHT had good success, I can't remember coats then wet sand and little buff, lasts long and looks great.
  4. Mar 12, 2014 at 5:59 PM
    #124
    csuviper
    Broomfield, CO
    I used the VHT and then clearcoats on my 07 taco. The VHT was spotty and looked like it was cracking. Weird. It's an option if the others don't work. Also thinking of just getting them tinted.
    T-Rex266 likes this.
  5. Mar 12, 2014 at 8:43 PM
    #125
    csuviper
    Broomfield, CO
    4 thick coats plastidip smoke-way too light
    2 light coats plastidip black and 2 heavy coats glossifier- maybe a little light but can see specs and transparency is already limited
    9enetyhy_23cee8d65db07402324cb9b185d0928bf0d43b0d.jpgzunumy6u_dea9eca70f80b48b97311b6695d8d37ed8fe09ea.jpg
  6. Mar 12, 2014 at 9:39 PM
    #126
    csuviper
    Broomfield, CO
    Alright, VHT Nite-Shades it is.
    Def must have done something wrong the last time I used it.
    Question I have is do you need to put clear coat layers over the top and wax, or leave it with just nite-shades???
  7. Mar 13, 2014 at 12:10 PM
    #127
    csuviper
    Broomfield, CO
  8. Mar 13, 2014 at 3:57 PM
    #128
    JonasSacredTundra
    I didn't put clear on it, I wet sanded after VHT and then buff wax. You could put a coat or two of clear and would just last longer I imagine.
  9. Mar 14, 2014 at 2:09 PM
    #129
    csuviper
    Broomfield, CO
  10. Mar 14, 2014 at 2:11 PM
    #130
  11. Mar 14, 2014 at 5:56 PM
    #131
    csuviper
    Broomfield, CO
  12. Mar 17, 2014 at 8:59 AM
    #132
    csuviper
    Broomfield, CO
    Spent a little time this weekend installing the Toytec Ultimate Lift. Had some help from @Sean266.
    Ancient1 and ColoradoTJ like this.
  13. Mar 17, 2014 at 9:08 AM
    #133
    Yessir!!!
  14. Mar 17, 2014 at 5:02 PM
    #134
    csuviper
    Broomfield, CO
    Here she is with the new lift and tires
  15. Mar 17, 2014 at 7:57 PM
    #135
    So purrrttyyy
  16. Mar 17, 2014 at 10:20 PM
    #136
    Beer'd_n_yotas
    Beer'd_n_yotas New Member
    2013 Super White Tundra
    Plasti-dipped and lowered!
    Looks good! Are you at +2.5" up front now?
  17. Mar 18, 2014 at 8:52 AM
    #137
    csuviper
    Broomfield, CO
    I will check dimensions tonight to find out. I want to be at 3" so i will adjust the coilovers if needed to get to 3".
  18. Mar 18, 2014 at 5:38 PM
    #138
    bakersTRD
    bakersTRD New Member
    Rich
    Latrobe, Pa
    2012 Barcelona Red Tundra DC 4x4
    Weather Tech floor mats, Trifecta bed cover, BedRug bedliner, factory bug shield, side steps, Rock Warrior shift knob, Pro Comp Prorunner SS leveling kit and rear shocks
    Looks good. You'll have to let us know how it rides.
  19. Mar 18, 2014 at 6:35 PM
    #139
    csuviper
    Broomfield, CO
    The ride is freaking amazing. So much better than the stock shocks and coils with leveling spacer. Leans a little in the corners and absorbs the bumps well.
  20. Mar 24, 2014 at 7:43 PM
    #140
    csuviper
    Broomfield, CO
    Got an alignment today and now I rub in reverse when close to full turn. Think it's related?
  21. Mar 24, 2014 at 8:43 PM
    #141
    Mine does that on occasion-- just depends on that angle, slope, etc.
    Doubt it's alignment related
  22. Mar 25, 2014 at 12:04 AM
    #142
    Beer'd_n_yotas
    It's possible that pre alignment your tires were just missing from rubbing but now that they are "strait" it rubs. I'm thinkin the real culprit is them big ole tires! :D Have you figured out where it's rubbing?
  23. Mar 25, 2014 at 5:16 AM
    #143
    csuviper
    Broomfield, CO
    I honestly had zero rubbing backing out of my driveway before the alignments. Now it rubs every time. Looks like it's rubbing on the front plastic and a little on the cab mount. Going to do some chopping this weekend.
  24. Mar 25, 2014 at 6:15 AM
    #144
    csuviper
    Broomfield, CO
    Keep debating if I should put 1.25" wheel spacers on. The tires fit without contact with the spindle or upper control arm but it's very close. The main reason I'm thinking that I might put them on is for looks. I like the wider stance.
    Here is the current look:
    I have the wheel spacers but they are not returnable if I put them on.
  25. Mar 25, 2014 at 8:19 AM
    #145
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    man that looks great! do you know what the offset is for those rims? there is a member on tundratalk that swears there is a relationship with tire rub and alignment. he says he has been doing it for 30 year, so maybe have another shop check? they would look good too sticking out further, but I would hate to have a spacer on my wheel.
  26. Mar 25, 2014 at 9:42 AM
    #146
    csuviper
    Broomfield, CO
    17x8 RW Wheels - Offset: +50mm, Backspacing: 6.5"
    TruckyTruck likes this.
  27. Mar 25, 2014 at 3:58 PM
    #147
    JonasSacredTundra
    DO IT!!! Stance stance!
  28. Mar 25, 2014 at 10:19 PM
    #148
    csuviper
    Broomfield, CO
    Alright I spent some time in the garage tonight:
    Installed 1.25" wheel spacers
    Before
    After
    Installed plasidipped black center caps and rock rings
    Before
    After
    Installed Tundras.com vinyl sticker
  29. Mar 26, 2014 at 1:58 AM
    #149
    Beer'd_n_yotas
  30. Mar 26, 2014 at 7:28 AM
    #150
    csuviper
    Broomfield, CO
    Oh yea, I rub.
