2017 factory speaker sizes?
Discussion in 'Audio & Video' started by drake22, Mar 8, 2018.
  1. Mar 8, 2018 at 6:52 AM
    drake22
    drake22 [OP] New Member
    2017 SR5 Crewmax
    I added (2) JL 10's and a JL 500w amp. Some music sounds great, and other sounds so boomy is terrible. I'd like to replace the factory speakers but keep getting conflicting reports of what size the current factory speakers are...
    Will JK C1 6x9's fit in the front dor and 6.5's in the rear door?
    Can I get by without running an additional amp?
  2. Mar 8, 2018 at 7:23 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Most people put 6.5's in all the doors, this would be your best bet especially since you've already got some thump.
    You will want an amp to power the door speakers.
    GNTundra likes this.
  3. Mar 14, 2018 at 6:58 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Look at Crutchfield they have best info on vehicle specific speakers that I have found. Also they include adapters and wire harness. I am looking at JBLs but Kickers in same price range handle more power. Fronts are bigger than rear for OEMs anyway.
  4. Apr 4, 2018 at 2:34 PM
    Privett10
    Privett10 New Member
    Benjamin
    2017 Black CM TRD OR Tundra
    5% Tint, Tonneau Cover, Window Visors!
    Any modification to doing this?
  5. Apr 13, 2018 at 11:50 AM
    Jrmysell
    Jrmysell New Member
    2014 DC 4X4 TSS SR5
    I've been looking at Crutchfield. I do have a question about the dash speakers. It shows only 1 fits and it's about $700 for a set. You know any others that will fit or are stock dash speakers ok?
  6. Apr 13, 2018 at 11:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    Nope, just speaker adapters.
  7. Apr 13, 2018 at 11:53 AM
    Danimal86
    Daniel
    Sacramento, CA
    Not really worth it to mess with the dash speakers. Most people install a set of components with tweeters in the sail panels, and either remove the dash speakers, or leave them alone.
  8. May 8, 2018 at 4:20 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Can you put the tweeters in the dash?
  9. May 8, 2018 at 4:34 PM
    Check out *********.com
  10. May 8, 2018 at 5:41 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I have. I think I am going the less expensive option.
    Just adding front and rear speakers with an amp just shy of $450.00
    Polk Audio front components and rear with kicker Key amp.
    Crutchfield state the 6.5" do not fit the rear doors. Just looking for folks who have installed rear 6.5
  11. May 8, 2018 at 5:42 PM
    Gotcha
  12. May 8, 2018 at 6:40 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Would you replace the dash speakers with your tweeters with your components set or put them in the sail piece?
    Thanks
  13. May 8, 2018 at 6:54 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Definitely do components with tweeters in sails. I got the Infinity Kappa 60CSX when Crutchfield had on sale. I still have factory speakers hooked up in dash. Will probably just leave them. Tweeters fit easily about 1" from bottom of sail. Crutchfield is place to get speakers. They provide adapters and PNP harness for speakers. You will need the adapters in order to clear the support bar in door. Factory speakers have very thin magnets. Aftermarkets will have a much deeper magnet.
  14. May 9, 2018 at 8:49 PM
    Jrmysell
    Jrmysell New Member
    2014 DC 4X4 TSS SR5
    According to Crutchfield the Kicker KS components will fit in the front door, but I've read a couple threads on here where people say they can't get them to fit. Is it just the bracket that Crutchfield supplies that lets it fit or based on the specs does it just look like it'll fit, but it really won't when I try to install them?
  15. May 10, 2018 at 3:23 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    You need the adapter so the larger magnets in speakers clear the brace in the door. If you can compare the depth to the Infinity Kappa 60CSX that I have. They fit fine with adapter. Factory speakers have a very thin magnet
  16. May 10, 2018 at 4:37 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    New doors speakers aren't going to solve the issue of your subs sounding boomy, you have to solve the issue of the poor headunit signal either with a sound processor or new head unit
  17. May 10, 2018 at 7:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    Just put the tweeters in the sail panel and disconnect the dash ones. If you aren't comfortable cutting a hole in your existing sail panel, you can buy the limited ones that are made for tweeters. If i remember, i think i paid $40 for them.
    6.5's will fit in the front and the back with speaker adapters. I used the ones from tech12volts. I cant remember if i took a picture of the rear door speakers, but check my build log for some pics (link in my signature).
  18. May 10, 2018 at 8:06 AM
    Beerdude77
    My component 6.5's speakers from Tech12 came with the Toyota sail panels for the tweeters...
    040Tundra likes this.
  19. May 10, 2018 at 8:12 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
