Hazy headlighs
Discussion in 'Detailing' started by gilgawrath, May 10, 2018.
  1. May 10, 2018 at 4:51 AM
    gilgawrath
    gilgawrath [OP] New Member
    2012 Tundra TSS 4.6
    Good morning everyone. My headlight are starting to get hazy, what are some of the products you’ve used to get rid of the haziness? I have already used Meguiars plastic polish on them a couple of times but it’s still pretty bad. I’ve looked on here at other posts and couldn’t find a name of any particular product just before and after photos.
  2. May 10, 2018 at 5:16 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    gilgawrath[OP] likes this.
  3. May 10, 2018 at 5:17 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    gilgawrath[OP], rons23 and 4x4_Angel like this.
  4. May 10, 2018 at 5:45 AM
    Trooper2
    JR
    If your product is only a polish it will not fix the haze. These kits have a sanding disc and compound included which will take care of or the haze, then polish to protect.
  5. May 10, 2018 at 6:26 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2 on the heavy duty kit. The wet sanding is what takes the deep grime and haze off. Good call Trooper. :thumbsup:
  6. May 10, 2018 at 6:32 AM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
  7. May 10, 2018 at 7:44 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Has anyone ever tried using bug spray? youtube it.
  8. May 10, 2018 at 7:48 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I sand (if needed)
    Heavy Compound-mf pad
    Light compound-light pad
    Polish-polish pad
    Sealant
    Wax
    The best way to protect it after buffing them out is actually getting them clear coated.
    Sealant and wax only hold up for so long. Especially if you park outside.
  9. May 10, 2018 at 8:30 AM
    bvia
    bvia New Member
    None
    The Sylvania kit has a wipe-on, self leveling UV final clear coat included in the kit.
    B
  10. May 10, 2018 at 8:33 AM
    rons23
    Ron
    Kill Devil Hills
    Mark that's a thought. Also I put lamin-x on my fogs, and need to do my headlights.
    https://www.lamin-x.com/
  11. May 10, 2018 at 8:35 AM
    rons23
    Ron
    Kill Devil Hills
    Daniel that's a temporary fix. It really works good on a glass headlight. Better off getting a kit. :cool:
  12. May 10, 2018 at 9:19 AM
    TheBeast
    TheBeast The Beach
    +1 on what the other guys say :)
    chemical guys also has a kit for restoring lights.
  13. May 10, 2018 at 10:21 PM
    Punisher17
    Punisher17 New Member
    Toothpaste was on hack my life TV show. And or bug spray my gf has used and says it works good and is quick and easy wipe on. I've used the 3M sanding kit and don't reccomend it. Just buy new replacement headlights. The kit I found after sanding and polishing the plastic then yellowed again in a few months to the point you can't see as well again and looks gross
    driverdog and gilgawrath[OP] like this.
  14. May 11, 2018 at 6:39 AM
    gilgawrath
    2012 Tundra TSS 4.6
    I really appreciate everyone thoughts and recommendations on here, one of my main concerns is how long do they last before you have to go back and do it again. I have been watching several you tube videos on using everything from WD-40 to the heavy duty sanding kits and from what I’ve can tell they don’t last long, maybe a year at the most. It almost seems like I should purchase a whole new set of headlights. What I’m going to do is try the Sylvania kit on one light and the Meguiars on the other, I’ll report back once I get everything done.
  15. May 11, 2018 at 7:04 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    My headlights are yello and hazy. We have a scratch and dent guy that will redo them with wet sanding and a heavy clear coat. I cant say what's what on longevity with the way he does them because it's mainly on used cars. But, they look damn good when finished. I, however, think I'm going to just bit the bullet and buy the replacement lens for my truck with the black chrome inner housing. They look REALLY good to me.
  16. May 11, 2018 at 7:06 AM
    mudslinger79
    Christopher
    Williamsburg, Va
    These here. I'm also going to pick up a Hikari LED conversion kit.
  17. May 11, 2018 at 8:43 AM
    bvia
    bvia New Member
    None
    Good friend did the Sylvania kit on his 1st gen Tundra 5 years ago and his are still crystal clear. Just finished doing the wife's '05 Mazda 3 headlights and will be doing my 2nd gen tundra next. A piece of advice is once you've coated the headlight with the UV clear protector, do NOT touch it again for at least 4 hours. Then you can reapply if necessary. Also I used a black foam wedge brush which gave a thicker coat that the lint-free towel method described in the instruction and included in the kit, but be careful to not get runs. It is a wet UV clear coat so you may want to try it on a piece of plastic first to get the feel for it...
    B
    Trooper2 and mudslinger79 like this.
  18. May 11, 2018 at 11:23 AM
    Trooper2
    JR
    Good info, THX!
  19. May 11, 2018 at 11:42 AM
    15whtrd
    15whtrd Mr. Blonde
    To save myself the headache of having to restore headlights. The second they start looking slightly hazy, I polish them. After each wash I put a coat of wax on them. Fine cut Maguires polish works great. As well as the basic scratch out stuff in the yellow bottle. If they aren’t too bad this stuff works great.
    Stay on top of stuff like this and it will save you from a large amount of effort in one shot.
  20. May 11, 2018 at 1:39 PM
    bvia
    bvia New Member
    None
    The issue with the hazing is not just the physical scratches but also the break down of the UV coating on the lenses. Honestly the Sylvania kit is ridiculously easy for the outcome and if I hadn't seen it and then done it myself I wouldn't have believed it. Having said that Instead of using the kit's included 3M sandpaper, I used my Micro Mesh clothes (made for polishing aircraft "glass") in the following order 4000,6000,8000, 12,000 and then Meg's clear plastic polish and then began the Sylvania's process of using the solvent, rinse, solvent and then clear UV coating. I know I sound like I've got stock in the stuff, but I'm just an end user and after decades of using all the other methods, this one won for me, hands down.
    hth,
    B
    driverdog likes this.
  21. May 12, 2018 at 4:53 PM
    lilharv321
    lilharv321 New Member
    Black Wolf likes this.
  22. May 13, 2018 at 5:08 AM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    Consumer Reports rates the Sylvania kit the highest. I have used it a few times and it makes your lenses crystal clear. However, after a year or two , you may need to do it again. It takes a couple of hours to do the job right.
  23. May 19, 2018 at 8:42 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Blown away by the sylvania kit. I’ve tried several different ones. This kit is amazing. The pics are from my 08 mazda 3. It lives outside in Yuma, AZ. Spent 7 years outside in El Centro, CA. Anyone familiar w area knows 110-120 is normal for summer. I wish I’d have taken a before pic. My car had some bad cataracts. Super hazy. AFCB033F-FE31-44A9-993A-E14741185A6D.jpg58BE6014-2BA5-4187-8A67-B45A7090B3C5.jpg
    Gonna do the wife’s Camry later. Will do before and after pics.
    15whtrd and Trooper2 like this.
  24. May 19, 2018 at 4:14 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    2013 Camry, 98000 miles. 9FA8C0C7-D22D-4291-9FB9-8C8EC9DF0454.jpg05079F5E-E285-4FE9-9D01-974F079AFA02.jpg
    driverdog, Trooper2 and 15whtrd like this.
