Any body running king 2.5 s on the rear?
Discussion in 'Suspension' started by 250rdave, May 6, 2018.
  1. May 6, 2018 at 3:07 PM
    250rdave
    250rdave [OP] like I told the guy on ABC DANGER IS MY BUSINESS
    surprise az
    2014 blue trd dbl cab
    Borla cat back Airraid cai raptor grill pro comp at sport
    I am looking for a good photo of the rear resi mounted.I know its a pretty straight forward install.No instructions were in the box and I was wondering if any one drilled holes in their frame for the resi holders?:confused:
  2. May 6, 2018 at 5:01 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Pull the plastic clip off, then pull back your liner and you will see it is pretty straightforward. Bolt it on, then put the supplied plastic clip back on to secure liner.
    ColoradoTJ likes this.
  3. May 6, 2018 at 6:44 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  4. May 6, 2018 at 8:32 PM
    250rdave
    surprise az
    Thank you for the info.
  5. May 6, 2018 at 9:57 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Here’s a photo of mine. Not the best photo sorry but Zero drilling required for install. If I remember correctly it bolts into existing holes.
    Dilsky likes this.
  6. May 7, 2018 at 8:20 PM
    250rdave
    surprise az
    Thank you for the help
