TPMS
Discussion in 'Wheels & Tires' started by jewsNbrews, Apr 24, 2018.
  1. Apr 24, 2018 at 7:24 PM
    jewsNbrews
    jewsNbrews [OP] SSEM #8 level 3, RGBA #5 lab tested lab approved
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    So Les Schwab's messed up my wheels. Got to wait for the correct ones to come in. They had already taken out the TPMS sensors and place with new wheels and tires. They didn't put them back in. I was ok with this because it's only a few days and will be replaced again. However the truck didn't register that they weren't in. No light came on like I thought it would. It did come on this winter when tires were low. Should this be a concern?
  2. Apr 24, 2018 at 11:37 PM
    TTund16
    TTund16 New Member
    Maybe since they are all missing, the car thinks that you don't have the TPMS functionality. Just a wild guess ...
    See if you can get them and bring them back in the car range and see if that triggers the ecu!
    Btw, i have had few bad experiences with Les Schwab and avoid them. In old days they used to be good!
  3. Apr 25, 2018 at 8:37 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Customer service was great, friendly, they just seem incompetent. Told numerous times the wheels I wanted and even corrected him. Then it was a fight to put anything other than stock size tires on saying they won't fit. I did my research I know what will fit put it on! Ok end rant. It's just my first frustrating experience with them. Never had a problem before. Giving them the benefit of the doubt.
