Sway bars
Discussion in 'Suspension' started by Stevie442, Apr 22, 2018.
  1. Apr 22, 2018 at 9:41 AM
    Stevie442
    Stevie442 [OP] New Member
    2016 Tundra 1794
    Stock
    just installed new TRD sway bars on my 2016 Tundra,how much lift can I now install and still use these sway bars? I’m thinking of going 3/2 maybe 4”.
  2. Apr 22, 2018 at 10:03 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Do you actually offroad or just want the lift for looks? Do you tow a lot?
    T-Rex266 likes this.
  3. Apr 22, 2018 at 10:27 AM
    Stevie442
    2016 Tundra 1794
    Stock
    Not a hardcore off-roader but I do hunt and fish so I will take down a beatin path or trail
  4. Apr 22, 2018 at 12:21 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    No problem with your sways at that height.
  5. Apr 22, 2018 at 12:58 PM
    Stevie442
    2016 Tundra 1794
    Stock
    At what height lift does it become a problem?
  6. Apr 22, 2018 at 1:05 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I personally got some nasty noise when the front went quickly to full droop quickly (hitting a speed bump fast) when I was close to 4" of lift. Removing the sway helped a lot but didn't completely eliminate the noise. So, IMO around 4" front you might consider longer end links.
    I've SEEN on the forum, not done myself, a stock rear sway on 6"
