How many of you are running replacement steering kits w/ your lift?
Discussion in 'Suspension' started by joem1cha3l, Jul 23, 2017.
  1. Jul 23, 2017 at 3:41 AM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Considering cranking my coils up to 3.5" up front and adding 1.75" shackles in the rear. I havent heard much about a steering kit until recently and it pretty much doubles the budget for an additional 1" of height. Thoughts? My truck is strictly a pavement queen.
  2. Jul 23, 2017 at 3:50 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Mine has 3.5 inch lift in the front (OME 614). I have a set of SPC UCAs, but I do not have a replacement steering kit. I haven't had any problems.
    Mountun Goat likes this.
  3. Jul 23, 2017 at 10:16 AM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    What is a steering kit?
  4. Jul 23, 2017 at 2:42 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  5. Apr 20, 2018 at 10:33 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Any of you pros tell me what these are ?? Looking to do a few more mods these days.. making another list of Shit to get soon.. 0DD5908A-0DED-41AB-BA2E-B8BE3D81C5BF.jpgFFABB846-73B2-4166-A524-259DB54C8AEB.jpg
    froggy78 and dcsleeper408 like this.
  6. Apr 20, 2018 at 10:39 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    1st pic sway bar end link
    2nd pic outer tie rod
  7. Apr 20, 2018 at 10:41 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ok cool.. thanx brother.. so... wtf do those do??? And are aftermarket ones any better???
    dcsleeper408[QUOTED] likes this.
  8. Apr 20, 2018 at 10:43 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Messed up both BDS ends after a few hundred miles. Replaced with CB steering ends and haven't had a problem with them. Also using polyurethane rack bushings.
    Jsena likes this.
  9. Apr 20, 2018 at 10:45 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You replaced both of the pictures above??
  10. Apr 20, 2018 at 11:02 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    the sway endlink is an extended version in the pic.. for the big lift.
    the tie rod end looks stock or oem replacement. you can do CB steering kit. good for moderate to big lifts depending what size.
    don't need to upgrade both.
    you can remove the sway. #mpggainz
  11. Apr 20, 2018 at 11:06 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Will the CB Kit replace both??
    And I can remove one? I don’t need it?
  12. Apr 20, 2018 at 11:13 AM
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    The CB kit is only for the steering ends. The other links can be removed with the sway. But, youre 7 inches in the air. I'm not sure how it will perform without it around turns.
    831Tun, joonbug and TheBeast like this.
  13. Apr 20, 2018 at 11:15 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Y’all to Coachbuilder about the steering kit he offers for your setup.
    The endlink you can get away with not upgrading. You can even remove it if you want to. The truck will roll a little more on road but more benefits off road.
    I think bds sells the extended sway bar end links.
    joonbug, 831Tun and Jsena[QUOTED] like this.
  14. Apr 20, 2018 at 11:20 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Okay cool.. so basically the top part can be replaced and the one at the bottom of the truck doesn’t really need to be?
  15. Apr 20, 2018 at 11:23 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    yeah you should be fine. any picture of your current setup?
  16. Apr 20, 2018 at 11:29 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    THat was my truck.. took it when I left this morning..
  17. Apr 20, 2018 at 11:30 AM
    TheBeast
    TheBeast The Beach
    I would keep the front sway bar on a 7 inch lift
    froggy78, 831Tun, Jsena and 1 other person like this.
  18. Apr 20, 2018 at 11:32 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    yeah you already got an extended endlink already. just leave that as is.
    talk to david at coachbuilder about a steering kit for your setup.
    joonbug, Jsena[QUOTED] and froggy78 like this.
  19. Apr 20, 2018 at 11:54 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    No, was talking about both steering ends, my bad. As of right now the truck is fine w/o the front sway bar and 7" lift but the Tundra is currently getting the shocks re-valved along with other work, will see if I need to put the front bar back on early May.
    Jsena[QUOTED] likes this.
  20. Apr 20, 2018 at 12:06 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Camburg too, I think.
  21. Apr 20, 2018 at 12:14 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You don't need it and it can interfere with the spring perch if you have a lot of caster. I'm running it and it gets quite noisy when it gets dirty. I just learned today, from @1UPPER, that boots are available for the heims. I'd highly recommend the boots for you're neck of the woods. Super quality product and sure looks BA though :D
    joonbug, dcsleeper408 and Jsena like this.
  22. Apr 20, 2018 at 12:15 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I don't see any ABS sensor guards?
  23. Apr 20, 2018 at 12:18 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Sensor guard... lol I don’t know where that is or what it is :rofl::rofl:
    dcsleeper408 likes this.
  24. Apr 20, 2018 at 12:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    In post #5, last pic at the bottom, you circled the tie rod. Look at the wire beneath it. That wire goes to you ABS brake sensor. If a rock hits it, it can be an expensive repair. For $70 you can get cool, functional guards from SDHQ. I'd recommend them for EVERYONE, cheap insurance.
  25. Apr 20, 2018 at 12:25 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ohkay cool. I see it.. is it like a clip? Easy to snap on and call it a day?? I’ll order that right now
    831Tun[QUOTED] and dcsleeper408 like this.
  26. Apr 20, 2018 at 12:32 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    dont forget to use your forum discount!!
  27. Apr 20, 2018 at 12:33 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Hell yeah... im poor.. I need every cent :spending::amen:
    831Tun and dcsleeper408[QUOTED] like this.
  28. Apr 20, 2018 at 12:35 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    nope, it's a bolt in. super easy. should take you 10 min to do all 4 corners.
  29. Apr 20, 2018 at 12:51 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    1UPPER, dcsleeper408 and 831Tun like this.
  30. Apr 20, 2018 at 12:55 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's the only disappointing thing about 'em. 10 min and done,,,,What? That's it? Now I know how my wife feels...:anonymous:
    joonbug, KevinK, GodlessPro and 4 others like this.
