Leveling kit on top of extended 6" Rc strut
Discussion in 'Suspension' started by Edgarherrera11, Apr 19, 2018.
  1. Apr 19, 2018 at 9:59 AM
    Edgarherrera11
    Edgarherrera11 [OP] New Member
    Edgar
    2011 black tundra
    6" rough country
    I have a 2011 tundra 2wd with 6" Rc lift. Im thinking to stack the 6" extended struts with 1.5" leveling kit on top to get more lift... yall think that will be good to do????
  2. Apr 19, 2018 at 9:59 AM
    Do not stack lifts.
  3. Apr 19, 2018 at 10:16 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    This.
  4. Apr 19, 2018 at 10:18 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  5. Apr 19, 2018 at 10:29 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
  6. Apr 19, 2018 at 10:35 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    YOLO!!!!
    Edgarherrera11[OP] and monaco730 like this.
  7. Apr 19, 2018 at 10:40 AM
    AgentOfWrath
    AgentOfWrath New Member
    Tampa Florida
    2015 Tundra Crewmax 4X4
    Flowmasters | 4 Inch Lift | Linex | Diamonback HD Cover | 40 Inch LED Light Bar \ Rock Lights
    yeah bad idea.
  8. Apr 19, 2018 at 10:52 AM
    SnowroxKT
    SnowroxKT New Member
    Kyle
    Alaska
    Don't ever stack lifts. bad idea.
  9. Apr 19, 2018 at 11:51 AM
    Welcome from Texas, let's see your ride,
    That sounds like a no bueno idea, @Les7311 has the RC extended struts on his ride
    Les7311 likes this.
  10. Apr 19, 2018 at 12:09 PM
    Edgarherrera11
    Edgar
    2011 black tundra
    6" rough country
    Or how do i get more lift in the front??
  11. Apr 19, 2018 at 12:57 PM
    AgentOfWrath
    Tampa Florida
    Work more overtime at work :):benchpress:
    Once you pass about a 4 in lift, your changing a lot of things and the $$$ goes up dramatically.
    I use to have a jeep/heep aka money pit and once you crossed over past 35 inch tires, you needed bigger brakes/driveshafts/etc. The list is long....
    Getting bigger cost a lot of money and you have to upgrade everything past OEM. You can do it cheap but your going to tear up a lot of things and end up spending a lot more in the end , than doing it the right way the first time.
    Les7311 and Edgarherrera11[OP] like this.
  12. Apr 19, 2018 at 2:45 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You can get some shims from coachbuilder get about 1" with out any alignment and CV problems
    Edgarherrera11[OP] likes this.
