Help with wheels and tires
Discussion in 'Wheels & Tires' started by SouthshoreYota, Apr 15, 2018.
  1. Apr 15, 2018 at 8:36 AM
    SouthshoreYota
    SouthshoreYota [OP] New Member
    Jordan
    Ontario
    2001 Toyota Tundra X2
    3” supreme suspension leveling kit 2” supreme suspension wheel spacers Home fabbed bumper Complete frame swap Complete exhaust swap to 3” stainless
    I’ve just picked up a new (used) set of tires and am looking for some rims to match, JEGS sells a good cheap pair of steelies and by my calculations they shouldn’t have a problem fitting but I’m no tire guy! So the specs for the tire are 32/11.5/R15 and the rims in question are a 15-10” with a 4” backspace and -38 offset, I also have 2” spacers and a 3” leveling kit on the truck!
    If anyone is a tire and wheel guy and could help me out that would be great!
  2. Apr 17, 2018 at 9:12 AM
    05newb
    05newb New Member
    '05 SR5 Access Cab-2wd-4.0L
    K&N intake, Removed badges
    I was looking at 15” rims for mine as well last year and came to my own conclusion they won’t fit around the brake calipers. Even though companies make 15s in our lug pattern, when I looked at my factory 16s I had about a half inch between the calipers and inside of the wheel. According to my calculations, a 15” ain’t goin on.
  3. Apr 17, 2018 at 10:13 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    15's wont work. 16 or bigger.
  4. Apr 17, 2018 at 12:29 PM
    SouthshoreYota
    Jordan
    Ontario
    So even with the -37 offset and 2” spacers it won’t fit? In my head it seemed like the rim would be pushed far enough out to avoid touching?
  5. Apr 17, 2018 at 2:13 PM
    05newb
    05newb New Member
    Not the way I imagine it. A section of the rim has to go over the brake assembly and 15s won’t allow it.
    mudslinger79 likes this.
  6. Apr 17, 2018 at 2:37 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Plus it looks like that wheel is a 6 lug, our trucks are 5 lug.
  7. Apr 17, 2018 at 2:53 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    Hes talking about a first gen tundra. They're 6 lug.
    mlucas555[QUOTED] likes this.
  8. Apr 17, 2018 at 2:54 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    There's a guy in Hawaii that has 38 inch Baja claws on 15x10 rims on a first gen tundra. BUT!!!! Hes solid axle swapped.
  9. Apr 17, 2018 at 3:40 PM
    SouthshoreYota
    Jordan
    Ontario
    Thanks for all the help guys! And yes I was talking about my first Gen and it’s a 6 bolt! Looks like I’ll have to re think my setup but I’m glad y’all saved me before I committed!
