TRD Pro Suspension Problem
Discussion in 'Suspension' started by pinellasjoe, Apr 16, 2018.
  1. Apr 16, 2018 at 2:08 PM
    pinellasjoe
    pinellasjoe [OP] New Member
    Seminole, FL
    2017 TRD Pro
    Has anyone else had a problem with the TRD Pro suspension? When pulling into my driveway the other day I noticed a creak when the front wheel hits the curb/gutter right before my driveway starts. It is at low speed and now I am noticing it on normal slow speed turns on the roadway.
    I have 10,500 miles on my truck and haven’t had a single problem to date.
  2. Apr 16, 2018 at 2:10 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Haven’t noticed anything like that. Did you look for anything that’s off the baseline??
  3. Apr 16, 2018 at 2:17 PM
    Newm
    Newm New Member
    KC
    It's more than likely the front skid plate on your pro. Guys have put a rubber washer between the mounting/screw tabs and the truck to alleviate it I believe. I hope that's it anyway....
  4. Apr 16, 2018 at 2:18 PM
    pinellasjoe
    Seminole, FL
    2017 TRD Pro
    I don’t see anything off. Truck drives normal. Maybe it has always done it and I just happened to start noticing it. I can’t hear the creak if the windows are up.
  5. Apr 16, 2018 at 2:23 PM
    seniramsu
    Nate
    VA
    Nah, I have 14k and never have heard anything like you are describing. I’m more than sure someone with a little more knowledge will chime in.
  6. Apr 16, 2018 at 2:24 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    Like Newm said. It's the skid plate. I had the same problem and first noticed it while turning into the driveway on certain movements. Then I started hearing it more and more. closing thing would be two pans banging together. I crawled under and tried tightening the skid plate and it really didn't help. I just took it into the dealer saturday and they said the plate was installed wrong. They reinstalled and she is quiet again.
  7. Apr 16, 2018 at 2:29 PM
    pinellasjoe
    Seminole, FL
    2017 TRD Pro
    Thanks guys! I was hoping that was the problem. When I take it to the dealer I’ll let you know what the result is.
  8. Apr 16, 2018 at 3:52 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Had similar occasional creaking. I took off the skid, looked where the plate rubbed the frame. Then cleaned and applied neversieze to all contact areas. Re-torqued, and has been silent since... about 2500 miles.
    Watt maker likes this.
  9. May 11, 2018 at 9:31 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    How hard is it to take the plate off? I don't have torq wrench to tighten to spec. Mine started today, made it 11,000 miles before it started.
  10. May 11, 2018 at 11:09 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Mine started a few week ago as well, 14,000 miles. I did some heavy towing and off roading in the last 6,000 or so miles so I figured I loosened something up.
    Doing my oil change this weekend and will pull the skid to see if that's it. Mine is more of a popping, and it did it to me today when I hopped in the truck. Engine wasn't even running. Just putting my fat ass in the seat caused it.
    Toyotoholic likes this.
  11. May 12, 2018 at 6:09 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    You have to go slow and loosen 1-2 turns each bolt until they release. There are locking washers on the ends of the bolts that need to remain on(they hold the spacer tubes), and if you spin one bolt all the way out, these will come off and make your 15 min project much longer. The rear bolts have tapered shims and nuts on top, so you'll need to put a wrench on the top to get that off. Once off, clean everything, take your time and it's easy. And any Home Depot should have a torque wrench in the tool corral. BUY ONE. I don't know the torque specs off hand, but I think they were around 25#. Maybe someone here has the exact numbers.
  12. May 12, 2018 at 6:47 AM
    alpinepro4
    Pat
    Mine more of a pop to, happens under uneven terrain. Was off roading last month. So much fun to drive fast off road with this suspension.
    Where are the LCA cam bolts located?
    ChrisTRDPro likes this.
  13. May 12, 2018 at 7:02 AM
    alpinepro4
    Pat
    Want to make sure I tighten the right bolts. Lower control arm bolts right?
  14. May 12, 2018 at 9:03 AM
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
    My last Pro had a similar sound early on. The sound was traced back to a defective driver’s side shock that was covered under warrantee.
  15. May 12, 2018 at 9:31 AM
    Kilos
    Kilos YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    Same, dealer fixed it while doing a normal service.
  16. May 13, 2018 at 7:00 AM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    Mine was making the noise also. Found out there was a service bulletin from Toyota on the skid plate rubbing. Fixed for free.
