Flyinryank’s White 15 CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Flyinryank, Dec 5, 2017.
  1. Jan 9, 2018 at 7:38 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Yes it does help. And ya I know you can't make that decision just one I'm trying to learn as much as I can prior to making a decision. So your tires would fall right between the 2 sizes I'm looking at height wise. And yours are definitely wider. Are you happy with the tire size u went with? @Flyinryank
  2. Jan 9, 2018 at 8:10 PM
    Tundra4us
    Tundra4us New Member
    "D"
    Flyinryank, did you get a true 1.5" at the rear when installed and have you noticed any settling? Ifs, how much settling? I am trying to get info on these as I am looking to dump
  3. Jan 9, 2018 at 8:12 PM
    Tundra4us
    "D"
    Oops, what the hell happened? any way, dump the 3" block and add that leaf pack + shackles. Thanks.
  4. Jan 9, 2018 at 9:04 PM
    Flyinryank
    Flyinryank [OP] New Member
    Las Vegas, NV
    White 2015 CM 4x4
    ~1” now
  5. Jan 9, 2018 at 9:06 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Considering the lift I currently have and the fact that the full size spare fits in he stock location I’m pretty happy.
    When they wear out I will have to make the tough choice to buy the same size, 295-70s or go with 35s
  6. Jan 10, 2018 at 2:57 PM
    Tundra4us
    "D"
    Thank youRyan! Scanned your build page, are still you on stock shackles?
  7. Jan 11, 2018 at 3:22 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Yessir stock shackles with the icon leaf pack 51200
  8. Feb 20, 2018 at 3:12 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Was shooting for a Toyota voodoo blue match
    Wallygator, TheBeast and Smiley like this.
  9. Apr 8, 2018 at 7:38 PM
    Ret_Soldier
    Ret_Soldier New Member
    Andy
    '17 Tundra Platinum
    After seeing your truck, I have finally decided.
    Suspension will be set at 2-ish f/ 1.5 rear with topper and rack.
    Method Roosts arrive Monday
    Tires: 305/65r18
    Thanks dude. Your pic angles helped.
    Flyinryank[OP] likes this.
  10. Apr 11, 2018 at 3:30 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I’ve gotten request(s) to see my nfab rkr “rock” rails. They mount using the factory body holes and do not mount to the frame itself. They are not sliders but do offer a level of protection.
    Here are a few pics. Hope they help.
    Recently removed all badging and maxed out the 6112s up front with one cb shim on the driver side. Still running the icon(51200) add a leaf expansion pack in the rear.
    equin, georgiey22 and Bannock452 like this.
  11. Apr 8, 2019 at 3:46 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Got that $255 trd intake in after that 40% one day deal lol
    equin likes this.
  12. Apr 8, 2019 at 3:56 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Just noticed it’s been a year since I update my build thread. Haven’t done anything to crazy but I did also get a new battery.
    X2 Power 27F along with some grounding cables upgrades :thumbsup:
    That is an Amazon bracket. It works only ok because it isn’t very snug on the sides of the battery.
    Update on battery bracket. It shifted while off roading :facepalm:
    Wallygator and equin like this.
  13. Apr 8, 2019 at 4:02 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    I have also had to replace a rear 5160 shock that tore through a seal. I was under the impression that these were covered by the bilstein “lifetime warranty”. I was wrong!
    Rather than pony up for two new shocks of another brand I just found a good deal on a replacement.
  14. Apr 23, 2019 at 11:46 AM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Colosseum Mine Trail
  15. Apr 23, 2019 at 5:24 PM
    _bm27
    _bm27 New Member
    Los Angeles
    21 Tundra aka Tank
    sweet build
  16. May 13, 2019 at 8:43 AM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Finally got around to installing the rear diff breather mod when I was putting in some bed stiffeners. I chopped about 2.25 inches off my factory bedliner in these pics btw
  17. Aug 13, 2019 at 4:31 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    MCM Fab UCAs
    Won them in the raffle at the Sin City Tundras meet Saturday :D
  18. Sep 12, 2019 at 12:57 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Baker NV hunting trip. Hunting pic(s) posted in other thread
  19. Oct 9, 2019 at 10:01 PM
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Mule deer hunt
  20. Dec 2, 2019 at 7:40 PM
    #50
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    2019 Trd Pro Led assemblies with harness from headlight revolution
  21. Dec 2, 2019 at 7:40 PM
    #51
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Fishing with my pup Arya at Cold Creek Pond, NV
    Wallygator, equin and 316KS_Runner like this.
  22. Dec 22, 2019 at 8:28 PM
    #52
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    ESP plastic storage w husky liner
    Toyota wireless phone charger. Easy and clean install!
    zcarpenter92 and georgiey22 like this.
  23. Mar 15, 2020 at 5:03 PM
    #53
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Updated pic from 2020 Mint400:
    Changed out the brake fluid since I just hit 50k miles. Bled the brakes by myself with this bottle from Amazon that has a one way valve.
    Allstar Performance ALL11017 Bleeder Bottle with Magnet and Check Valve https://www.amazon.com/dp/B00F9XHVKA/ref=cm_sw_r_cp_api_i_o6RBEb1700Q86
    Used a turkey baster to get out about 75% of the old fluid from the reservoir and then adding the new fluid, topping it off, before I started bleeding. You’ll also need a 8mm wrench for the back bleeders and 10mm wrench for the front bleeders.
    Be sure to have the hose on the bleeder before loosening it. Then be sure to keep the hose on the bleeder until the process and it’s tightened. Not doing so could increases your chance for air in the line
    I started in the passenger rear with 30 pumps once the bottle hose was attached. Then I moved to the driver rear giving it 25 pumps. Then the passenger front with 15 pumps. Finally the driver front with 10 pumps of the brake pedal.
    **While doing this process you must make sure that to keep adding the new fluid making sure it never goes below the min line**
    Doing this process used almost exactly one quart of new fluid leaving only a little left in the can for me. Your results may vary. I got two cans cuz I wasn’t sure. Now I have another can to do my ladies Lexus lol
  24. Apr 18, 2020 at 7:15 PM
    #54
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Sdhq battery terminals and trigger 4 plus accessory controller along with some
    Kc cyclones for under hood lighting
    Wallygator, equin, TheBeast and 2 others like this.
  25. Apr 19, 2020 at 12:36 AM
    #55
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Mod list updated.
    35s coming soon!
    TheBeast and zcarpenter92 like this.
  26. Apr 19, 2020 at 1:03 AM
    #56
    QAT1991
    QAT1991 New Member
    Alkhelaifi
    Houston , Tx
    2016 grey Tundra limited
    nice
  27. Apr 19, 2020 at 2:32 AM
    #57
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Thanks man. Welcome to the forum
  28. Apr 20, 2020 at 10:21 PM
    #58
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    Did a quick turn around fishing trip in Utah today. Little tuckin on the rough shoreline :thumbsup:
    Wallygator, equin and TheBeast like this.
  29. Apr 20, 2020 at 11:16 PM
    #59
    TheBeast
    TheBeast The Beach
    let us know how you like the trigger controller. been thinking of getting one.
  30. Apr 27, 2020 at 5:14 PM
    #60
    Flyinryank
    Las Vegas, NV
    White 2015 CM 4x4
    So far so good!
    Wish the 4 had the features of the 6 shooter though. Specifically the battery monitor and safety voltage cut off. The 6 is typically $100 more though.
    TheBeast[QUOTED] likes this.
