IIHS crash tests
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blueline, Apr 5, 2018.
  1. Apr 5, 2018 at 12:24 PM
    Blueline
    Blueline [OP] New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Having been a first responder, I’ve seen, and removed, bodies pinned behind the wheel and dash. Crash worthiness of a vehicle is a serious consideration, and I made a mistake when buying this Tundra TRD Pro; I didn’t check the IIHS website to check ratings on this truck. I just assumed it would be as good as the ‘12 F150 Super Crew that this truck was replacing.
    http://www.iihs.org/iihs/ratings/vehicle/v/toyota/tundra-crew-cab-pickup/2016
    The small overlap head on test is marginal on the Tundra. That means you may not walk after a frontal collision. A full frontal, headlight to headlight, who knows, but so many frontal collisions are small overlap.
    All that above to say this: I still peruse the F150 forum to see if maybe there will be a 7 liter V8 Raptor is in the pipeline. While on the site the other day, there’s a thread on a guy that was involved in a full frontal collision with his F150 vs Suburban, and the Suburban lost (driver killed). The F150 took the hit as designed, and the engine dropped beneath the drivers compartment and everything was pushed away from the driver. This rig performed like a Volvo I had at one time that went up against a BMW 740. Impressive Protection. After reading the thread and viewing all the pics, I decided to check out the Tundra at IIHS. Not impressed.
    Like they say: beauty is only skin deep, and the looks of the PRO overtook my thoughts about the crash worthiness in the event of the worst.
    Have any of you ever given thought to how safe your vehicle is? Lesson learned: don’t assume anything!
  2. Apr 5, 2018 at 12:39 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You seem to have a valid point. Will you be selling your Tundra and replacing it with a Ford?
  3. Apr 5, 2018 at 12:40 PM
    NewImprovedRon likes this.
  4. Apr 5, 2018 at 12:46 PM
    17inferno
    17inferno New Member
    All things considered...these trucks are safe. There is a safety standard for everything, and my confidence is high driving my truck. Virtually all accidents involve another vehicle I'd think, and have give (as in not a 10 foot thick concrete wall).
    This doesn't nor wouldnt sway me in the least.
    Boerseun, Watt maker and mudslinger79 like this.
  5. Apr 5, 2018 at 12:48 PM
    driverdog, Watt maker and 15whtrd like this.
  6. Apr 5, 2018 at 12:49 PM
    Blueline
    Jeb
    Temecula, CA
    Bakflip MX4
    Well, maybe. If the Raptor gets the rumored 427 cu in engine, it will be tempting.
    Watt maker and Black Wolf like this.
  7. Apr 5, 2018 at 3:22 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Too bad that they can’t factor in the risk to Ford owners of being hit while walking home on the road and freeways.
  8. Apr 5, 2018 at 4:33 PM
    Tundra9831
    Tundra9831 New Member
    If you're considering a Raptor, then keep in mind it doesn't have the same crash ratings as the regular F150 because they remove the crash bars (and other stuff that is different). As far as I know the IIHS doesn't crash test the Raptor, but before you spend the money don't assume it's the same as the F150. This is discussed on some Raptor forums and was one reason I decided to go with the Tundra. Likely similar crash ratings, but way more reliable.
  9. Apr 5, 2018 at 7:21 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I had a 1999 Ford F-150, I think I am safer in a 2018 Tundra.
    Boerseun likes this.
  10. Apr 5, 2018 at 7:29 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
  11. Apr 6, 2018 at 4:37 AM
    Stig
    Stig New Member
    I'm surprised you didn't take the 30 seconds to look at the crash ratings before you bought a new vehicle.like, especially with your background. I did over a year of research before I decided between the Tundra and one other. Then I did another 6 months of research just between those two and decided on the Tundra in the end.
    Lesson learned, do your research before beforehand.
    I think what you want is a volvo.
  12. Apr 6, 2018 at 5:29 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Welp guess we all better sell our Tundras and buy a Ford before we crash and die.
    Thanks OP.
  13. Apr 6, 2018 at 5:51 AM
    tundraj
    tundraj New Member
    Thanks for the insights. My son and I were discussing the design of the Tundra and I showed him how flimsy the metal structure was around the grill. We all think trucks are bombproof, but the Tundra front end is nothing but a bunch of thin plastic and aluminum foil. The engine is the only solid piece that will be of any protection in a front-end crash.
    So how do we combine the safety of the Ford with the longevity and reliability of the Tundra?
    ZiaTundra likes this.
  14. Apr 6, 2018 at 6:02 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Accident avoidance is a wonderful thing.
    Ps3udonymous, gosolo, Ike74 and 2 others like this.
  15. Apr 6, 2018 at 6:03 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    For sale: 2017 Black Tundra 4x4...
    Goodbye Tundra, hello Volvo
    Ps3udonymous and Black Wolf like this.
  16. Apr 6, 2018 at 6:16 AM
    tundraj
    tundraj New Member
    Tundracollector likes this.
  17. Apr 6, 2018 at 6:24 AM
    Rex Kramer
    Georgia
  18. Apr 6, 2018 at 8:58 AM
    tundraj
    tundraj New Member
    ColoradoTJ likes this.
  19. Apr 6, 2018 at 9:22 AM
    Hoologan
    Hoologan New Member
    California
    18 Cement Limited Crewmax TRD
    Anyone know where I can get some yellow disco slippers like the crash test dummies are wearing?
    ColoradoTJ and T500 like this.
  20. Apr 6, 2018 at 2:01 PM
    So much this^^^
    One could be in the safest vehicle in the world, but one of the most mechanically unreliable, and unlucky as some people are, get eaten up by a pack of wolves trying to walk out to get help. At this point, the difference between a 4 Star and 5 Star crash test rating matter?
    My IS350 doesn’t have the best rating for front overlap. I knew and understood that before I purchased this car. I also understood this little sports saloon has huge, powerful brakes, awesome traction control, point and shoot steering, and just a blast to push hard. When this “beater with a heater” commuter car becomes unreliable to drive....I’m getting another Lexus. Most likely something along the lines of an RC350. I may see if there are any IS F sleepers around as well.
    Toyota’s have me sold on safety and reliability.
    Here is a 65 mph front collision.
    Toyota
    http://www.iihs.org/iihs/ratings/vehicle/v/toyota/4runner-4-door-suv/2006
    Suburban
    For some reason, these mid-90’s Suburbans were not evaluated.
    2014 Tacoma
    30 mph into embankment and rather large tree. The vehicle was sliding on ice, so I assume speed increased 5-10 mph. USAA acident investigator agreed.
    Both accidents, my family walked away with no injuries.
    blue16, Wrongside, Watt maker and 2 others like this.
  21. Apr 6, 2018 at 2:46 PM
    Very fortunate. Your Taco looks more like a "toast"ada now..
  22. Apr 6, 2018 at 4:04 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Until they show me an offset crash between an F-150 and a Tundra, I'm not buying this safer idea.
    Rex Kramer and Watt maker like this.
  23. Apr 6, 2018 at 4:06 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Well, if you do buy a F-150 probably better to skip the Raptor.......don´t they have fiberglass front fenders instead of military grade aluminum? If so I wonder how that holds up.
  24. Apr 6, 2018 at 6:38 PM
    LOL!!!!
    Touche sir.
    Yeah, it took a hard hit. The ass end of the truck came up quite a bit when I watched it happen. It was such a nice truck, and now it is more ugly than a handful of smashed assholes.
    Watt maker likes this.
  25. Apr 6, 2018 at 7:46 PM
    I hope you never do Ron. Good feeling to know the engineering is there to keep everyone safe. Trucks are cheap in comparison.
  26. Apr 6, 2018 at 9:00 PM
    Blueline
    Jeb
    Temecula, CA
    Bakflip MX4
    My nomex flame suit has had enough...I’ll wait for a 2020 or 2021 Tundra, and I’ll check IIHS FIRST!
    Watt maker and gosolo like this.
  27. Apr 6, 2018 at 10:01 PM
    Blueline
    Jeb
    Temecula, CA
    Bakflip MX4
  28. Apr 7, 2018 at 11:29 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Curious.
    Do you think an aftermarket bumper would improve these results?
  29. Apr 7, 2018 at 12:59 PM
    Blueline
    Jeb
    Temecula, CA
    Bakflip MX4
    Don’t think so, and it may make things worse. The bumper may not crumple and absorb energy thus applying more force back onto the frame. The frame then collapses into the drivers compartment. Chain reaction of bad s*hit happening. The small offset crash test has only been around since maybe 2012 or 13, and though Toyota added knee air bags, the actual frame structure design was not changed. If we are ever hit, let’s hope for a small car, and that they dive under the truck. Maybe a lift would help? With all the distracted drivers out there, our probability has increased.
    big_jarv[QUOTED] and Rex Kramer like this.
  30. Apr 7, 2018 at 1:14 PM
    Rex Kramer
    Georgia
    I would like to see that.
