How to remove Bushings from TRD Tundra Swaybar End Link?
Discussion in 'Suspension' started by Aquanaut, Feb 12, 2016.
  1. Feb 12, 2016 at 6:23 AM
    Aquanaut
    Aquanaut [OP] New Member
    Glenn
    2016 Sunset Bronze Mica Double Cab Limited
    I would like to remove the Bushings from the TRD Tundra Swaybar End Links as I would like to powdercoat the Swaybar and End Links.
    First, can the Bushings be pushed out of the End Links without using a Mechanical Press?
    Does the Metal Sleeve in the center of the Rubber Bushing get pressed out first or is the whole unit (Rubber and Metal Sleeve) pressed out as one unit?
    Any insight? :confused:
    Thanks!
    ...Glenn :)
  2. Feb 12, 2016 at 7:14 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I would imagine its pressed out as one piece and a press would be needed.
  3. Feb 12, 2016 at 7:20 AM
    csuviper
    Broomfield, CO
