Need some help on towing setup
Discussion in 'Towing & Hauling' started by Bappa, Apr 2, 2018.
  1. Apr 2, 2018 at 1:49 PM
    Bappa
    Bappa [OP] Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    I bought a 27 ft travel trailer 6 yrs ago to live in while I built my log home. A buddy towed it up here with his F350, because at the time I had a Tacoma, and that just didn’t cut it.
    Now I want to pull it with my new 2018 Tundra CrewMax, with towing package. I hooked it up and drove down my drive and back and the setup is far from level. Without the trailer, my hitch sits at 17 inches. When hooked up, it is only 12 inches off the ground.
    When hooked up, the trailer is 15 inches from ground in front and 28 inches in the rear.
    I need to get the rear of the truck to ride at least 5-6 inches higher when hooked up.
    I’m a novice at towing. What do I need?
    The trailer weighs 5400 empty and the hitch weight is suppose to be 496 lbs.
    polox40 likes this.
  2. Apr 2, 2018 at 2:11 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
  3. Apr 2, 2018 at 2:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Do you have a weight distribution hitch?
  4. Apr 2, 2018 at 2:30 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    Not yet. I was going to get one this week. I can see where that would help in handling, but it wont affect sag will it?
    Y0TA PR0 likes this.
  5. Apr 2, 2018 at 2:31 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
  6. Apr 2, 2018 at 2:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yes the WDHitch will allow you to level (or nearly) both trailer and truck if correctly set up
  7. Apr 2, 2018 at 2:43 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    You will definitely want this. I towed a 7200lb trailer from Colorado to Arizona with on a 4" drop. Danimal's got you hooked up.
    gosolo likes this.
  8. Apr 2, 2018 at 3:11 PM
    OriginalSwift1
    OriginalSwift1 New Member
    12 CM SR5 4X4
    Fox 2.5 coilovers Total Chaos UCA’s Toytec Boss rear shocks and 1" block. Flowmaster Outlaw exhaust. Debadged
    I'm towing a 7200+lb travel trailer with a 650+lb tongue weight on a Curt TruTrack WD hitch. Everything is perfectly level.
    ColoradoTJ likes this.
  9. Apr 2, 2018 at 3:16 PM
    Danimal86
    Daniel
    Sacramento, CA
    It kicks weight to the front. Start there and see how she sits.
  10. Apr 2, 2018 at 8:13 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    Awesome. Thanks to all. This forum rocks.
    I’ll get the WDhitch and see how that does first. My scheduled trip in not until June, so I have time.
  11. Apr 2, 2018 at 8:18 PM
    Tremor F-250, Roush Mustang, Jeep Crawler
    Some really great advice from the people that actually tow heavier loads.
    You should only need a WDH that is properly set up. Only thing I will add is to make sure you can back up with the WDH you purchase. Not all hitches you can, and trust me, it sucks disconnecting every time or causing damage to the trailer.
    Enjoy and safe travels!
  12. Apr 2, 2018 at 8:20 PM
    Oh, and your gonna love that 38 gallon tank!!! Best thing the tundra has come up with on the 3rd gens.
    Watt maker likes this.
  13. Apr 2, 2018 at 8:49 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    This one is great! It’s a WDH and sway control!
    Love mine, my truck pulls my trailer with ease!
  14. Apr 2, 2018 at 8:49 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    Good to know. I’ll ask about that. Thanks.
  15. Apr 2, 2018 at 8:53 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    Seriously. I just did a 1,000 trip to San Luis Obispo and only had to get gas in CA once.
  16. Apr 2, 2018 at 9:56 PM
    What a convenience isn’t it?
  17. May 1, 2018 at 7:08 PM
    Bappa
    Bo
    Arizona
    2018 Tundra CrewMax
    Last week I got air bags and today I picked up my WD hitch. Can’t wait to get it hooked up and try it.
  18. May 3, 2018 at 11:43 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
  19. May 4, 2018 at 1:21 AM
    That's for sure.
  20. May 4, 2018 at 7:36 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    I 2nd the equalizer. I have this on my car hauler. I tow my crawler on my 24ft car hauler and it’s about an 8-9k combined load, with twin 5k axles.
    Another thing that is critical is tongue weight. Look into investing on a scale if your load will change often. Mine does, whenever I tow random things, and investing the $150 into a scale is well worth the investment to prevent sway or other issues.
    Here is the one I use: eTrailer scale
    Lots of good info on here. I also had sagging issues and was directed towards a WDH on here.
    zeke7681 and Watt maker like this.
  21. May 4, 2018 at 9:32 AM
    Notachickmagnet
    Notachickmagnet New Member
    My camper sits low, and really makes my truck squat. Thinking of lifting my camper a little. The wd hitch arms ride to low for it. My truck seems to have a saggy ass
    Edit:
    not to hyjack anyones thread, but what would I need to cure the saggy ass? I dont need any more height
  22. Sep 23, 2020 at 11:08 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What are the steps to setting up your WDH? Do you need to measure everything first? Gonna be putting one on this weekend and would want it to work correct since I just got it..
  23. Sep 23, 2020 at 11:35 PM
    The LDH will have instructions with it on how to set up.
    Jsena likes this.
  24. Sep 24, 2020 at 1:00 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What’s up bros.. hope all has been well... I bought it from someone so it’s not coming with instructions :cheers:
  25. Sep 24, 2020 at 1:10 AM
    Been doing good bud. Been a minute.
    what brand of hitch is it?
    Jsena[QUOTED] likes this.
  26. Sep 24, 2020 at 1:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yeah bro. Been busy myself . Come on here for the knowledge these days. Thanx guys ᕙ(ツ)ᕗ
    I got a Equalizer set up. I dont know shit about towing besides my tiny jet skis. So I got this set up now for this Little trailer I got recently and almost died coming back from California in my ladies Chevy traverse. Hit a bump and the thing was swinging all over the place. Thought it was over
  27. Sep 24, 2020 at 1:37 AM
    Jsena likes this.
  28. Sep 24, 2020 at 9:08 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
