2018 Tundra payload
Discussion in '2.5 Gen Tundras (2014-2021)' started by Land surveyor, Mar 31, 2018.
  1. Mar 31, 2018 at 10:08 AM
    Land surveyor
    Land surveyor [OP] New Member
    2018 Tundra TRD
    Just bought 2018 tundra trd double cab. Speck sheets on tundra call out pay loads from 1550 to 1660 pounds. When I loaded up the truck with fiber glass topper and survey equipment approx 700 pounds total truck rear is sagging a lot. When I look at the sticker on truck door it says max load with passengers is only 1320 pounds. Looked at several other trucks on the lot and the same 1320 pounds max called out.
    Y0TA PR0 likes this.
  2. Mar 31, 2018 at 10:11 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It's a 3/4 ton truck, so 1500 lbs minus one passenger at 180 lbs is 1320 remaining for gear. Sounds about right and the same as any other 1500 truck.
    JoshuaA likes this.
  3. Mar 31, 2018 at 10:18 AM
    Land surveyor
    2018 Tundra TRD
    We have 3 F-150 trucks also. 2010 states 1560lbs, 2014 states 1490lbs, 2016 states 2050lbs.
  4. Mar 31, 2018 at 10:23 AM
    Land surveyor
    2018 Tundra TRD
    Had the same load in the older f-150's and saw no sagging like I am seeing in the tundra. Looking at the rear leaf springs and they look like an slight S shape. Concerned with this for the longevity of the truck. Dealship wants to send me to an susension shop to get fixed. Not impressed.
  5. Mar 31, 2018 at 10:48 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Anytime I have put a topper or other permanent fixture over 500lbs on a truck, I have taken it down to my local suspension shop and had an appropriate leaf added. Puts the height and ride back to stock. If I am going to have varying loads, I will go with auto-leveling air bags.
    JoshuaA likes this.
  6. Mar 31, 2018 at 11:15 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome
  7. Mar 31, 2018 at 11:16 AM
    In the spec sheets, this is for a bare, no options truck. When people start adding plastic bed liners, step bars, interior options...etc, the limit goes down quickly.
