Need help confirming my setup
Discussion in 'Wheels & Tires' started by T.Durden13, Mar 30, 2018.
  1. Mar 30, 2018 at 11:16 AM
    T.Durden13
    T.Durden13 [OP] New Member
    Tyler
    Iowa
    2019 Voodoo Blue TRD Pro
    Hey everyone! I’ve probably spent close to 10 to 12 hours scouring this site and the various wheel/tire threads before finally settling on my new wheel, tire, and lift setup.
    I’ve decided to go with the Toytec 3/1 leveling kit as I don’t plan to haul anything or do any off-roading. I’ve also decided to go with some 18” Method Wheels and some Nitto Ridge Grapplers.
    Since this is a substantial purchase, I’d like to get one final confirmation from the experts here that my setup will work together. Possible mudflap rubbing issues aside, does anyone see any reasons why I’d have issues with the following setup? Planning to keep my stock UCAs for now.
    Lift: Toytec 3/1
    Wheels: Method 306 Mesh wheels, 18”, 5x150 bolt pattern, +18 offset, part number MR30689058518
    Tires: Nitto Ridge Grapplers, 295/70R18.
    I’ll be sure to post follow up pics in the appropriate threads once the setup is installed. Thanks in advance!
    (Truck is ‘17 CM in the fastest color, white ;))
  2. Mar 30, 2018 at 5:23 PM
    You should be fine if you remove the flaps, and a little bit of trimming.
    GAknight likes this.
  3. Mar 30, 2018 at 8:40 PM
    T.Durden13
    Tyler
    Iowa
    Thanks Sean! Good to know the setup will work out.
