High Speed Off Road Brake "Failures" - aka Ice Mode
Discussion in 'General Tundra Discussion' started by KevinK, Mar 27, 2018.
Have your brakes "failed" off road? What Generation is your Tundra?
  1. Yes - I have dirty underwear to prove it.
    27.3%
  2. I'm not sure - Something happened but I don't know what.
    4.5%
  3. Nope - My brakes hit harder than Tyson.
    65.9%
  4. First Gen
    4.5%
  5. Second Gen
    25.0%
  6. Third Gen
    40.9%
Multiple votes are allowed.
  1. Mar 28, 2018 at 8:25 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Don't really want to read 2 pages of responses, but first impression based on the statement made of the the pedal not vibrating and not moving at all makes me think master cylinder/pedal problem? I'm confused on the pedal feel when this happens tho. Literally rock hard or soft to the floor? Or a bit in between?
    KevinK[OP] likes this.
  2. Mar 28, 2018 at 8:49 PM
    Personally, and what others have said, ABS system would be my first look. As a close second like Gino pointed out, maybe a bad master cylinder...but it sounds like more people are having this issue than a bunch of faulty MS.
    We do totally different off-roading, but what we do have in common is wheels off the ground (sometime multiple), hard throttle, tight turns, and big tires. There is no way in hell I could possibly even think about having a functioning ABS system on my Jeep...ever. Just to put in perspective, I have 40" MTRs, one ton axles, one ton dodge master cylinder for a 2002 dodge 3500. I can be going 40 mph and mash the brakes and lock up all four. I don't use my brakes often, but when I do, it really matters. If I know a tough obstacle is coming that I need maximum braking power, I will ride the brakes a bit to clean all the rust off and warm them up a little.
  3. Mar 28, 2018 at 9:31 PM
    KevinK
    KevinK [OP] SGU - High Speed Overlander
    Back in Arizona. Again.
    Tundras to Sedona
    Pedal is rock solid as though there’s no vacuum in the booster. And release and reapply on the pedal gets the same solid pedal feel for several seconds. I’m not stabbing the pedal on initial application either.
    I’ve been trying figure out if I’m coming off a stretch of WOT where the engine may not produce vacuum for a short period, but the booster should still have enough vacuum unless it has a leak. But I’ve tested the pedal after the truck is shut off for a couple hours and I still have boost without turning it on (the pedal goes to the floor without the engine on) so I don’t think it’s leaking.
    I’m leaning pretty heavily towards the pribability that we’re just going outside the bounds of what the abs can handle.
    I do the same brake drag technique in the track car before a hard braking corner. Just to avoid pad knock back and make sure I have booster pressure. Keeps me from shitting my pants.
    I can’t really do that on the trail though because I’m usually running trails I’ve never been on so I can’t predict an obstacle far enough in advance. Usually it’s a couple seconds before impact and I just need to drop anchor immediately. All four locked up on the Tundra would be a dream come true.
  4. Mar 28, 2018 at 10:02 PM
    n2deep
    n2deep Pavement Princess
    But why is it not happening on Gen2. Less sophisticated ABS? I have never had my brakes do that. If it was the ABS system then it should do it for everyone the same. I know Dragos has missed turns before and taken out some vegetation but I don't think it was the brakes. It was most likely coming into a corner to hot. #shouldhaveboughtaraptor .
  5. Mar 28, 2018 at 10:29 PM
    KevinK
    Tundras to Sedona
    Yeah I now think the abs systems (code) are different between gen2 and 3.
    I know about 7 3rd gens now who have seen this but no 2nd gens.
    Watt maker likes this.
  6. Mar 28, 2018 at 10:35 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Hmm. Not sure but I think you’re just fubar’d. Mental note made to give you plenty of distance should a Baja excursion come to fruition...
    831Tun and Sunnier like this.
  7. Mar 28, 2018 at 10:37 PM
    KevinK
    Tundras to Sedona
    :eek::mudding:
  8. Mar 28, 2018 at 11:24 PM
    OcotilloSR5
    OcotilloSR5 New Member
    Southern California
    2013 Double Cab 4x4
    - 37x12.50r18 Yokohamas - Body Mount Chop - Hitch plug relocate - White Knuckle Rock Sliders - Fog Light Anytime Mod & HID kit - Energy Suspension Poly Rack & Pinion bushings - Sway Bar Delete - Coachbuilder leaf spring bushings - Coachbuilder strut spacers - Rear lift shackles - Wheeler's Superbumps - Limit straps - Diamond Eye 3.5" Cat-back - Aluminum Oil Filter Housing Mod
    On my 2nd Gen i had enough close calls and obstacles smashed into, I just pulled the ABS fuse. 4wd still works perfect, but it does disable the "limited slip" function. Also kills stability control and traction control. I've never looked back and haven't had any more close calls because of my safety systems.
    And i can lock all 4 tires.
  9. Mar 29, 2018 at 2:45 AM
    Adam New Member
    I have had it happen in both my 10 and 14 tundras. Same spot interestingly enough when I come off hard surface road on to washed out gravel/dirt while in a corner. I always just figured it was the abs not being able to keep up with my crazy driving
    KevinK[OP] and osidepunker like this.
  10. Mar 29, 2018 at 5:11 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I've had it happen. But It's extremely rare, maybe only 3 times in the 5 years I have had The Truck. Usually happens when I mash the brake on very loose surface. 99% of the time I can panic stop without any problems.
    WTF man!? You have selective hearing??? I have already told you several times that I have had it happen.
    Dude! you are the first 2nd gen I have heard from who has said this works. Which EXACT fuse did you pull?? I heard there were two different ABS fuses and I also heard you lose 4wd and go into limp mode. Also, what year is your truck? they made some significant changes mid-way through the cycle.
  11. Mar 29, 2018 at 8:05 AM
    KevinK
    Tundras to Sedona
    So that’s both good and bad news right? Bad news is it’s happened to you. Good news is pulling ABS fuse makes it go away.
    And yeah. All the other sustems that use the ABS will not work. That’s fine by me, I prefer an analog truck anyway. One thing I would like to try is a switch where I can cut or return power to the fuse from inside the truck. There are times on the trial I’d like to have A-Trac on in 4lo for climbing obstacles. I imagine it will require the truck be turned off and back in though so the abs can do it’s startup test.
    I don’t believe you.
    :boink:
    I remember you saying it happened to you, but I thought you said you could back off the pedal and reapply. I definitely can’t do that. It stays rock solid for several seconds.
  12. Mar 29, 2018 at 8:30 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    hmm. i think i remember hacking my FJ to be able to do that. not sure if it would be the same on the tundra but let me dig a little and see what i can remember.
    equin and KevinK[QUOTED][OP] like this.
  13. Mar 29, 2018 at 8:39 AM
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    Yeah I'd like a switch too but then I'm lazy. If you do one with a writeup, I would probably do it haha.
    And yeah, I remember not being able to modulate the pedal, like even lifting off the brake completely would not return the brake option. Usually it would happen in sand whoops.
    KevinK[QUOTED][OP] likes this.
  14. Mar 29, 2018 at 8:49 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    What exact fuse did you pull?
  15. Mar 29, 2018 at 10:34 AM
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    Red 50A one that's pulled up.
  16. Mar 29, 2018 at 10:50 AM
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    I keep it in one of my door cubbies in case i feel like restoring it at any time on the road. Which I never have. I miss it zero.
  17. Mar 29, 2018 at 10:51 AM
    OcotilloSR5
    Southern California
    2013 Double Cab 4x4
    The ABS, traction control, and parking brake light stay on but i just live with it.
  18. Mar 29, 2018 at 11:34 AM
    n2deep
    I am gonna pull my fuse next weekend to test it out. Putting a switch on it would be simple
    Sunnier, osidepunker and OcotilloSR5 like this.
  19. Mar 29, 2018 at 2:18 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Thx homie! I appreciate it
    OcotilloSR5[QUOTED] likes this.
  20. Mar 29, 2018 at 2:19 PM
    #50
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @KevinK said he was gonna do it last month :rolleyes:
    831Tun and KevinK[OP] like this.
  21. Mar 29, 2018 at 2:42 PM
    #51
    KevinK
    Tundras to Sedona
    can't believe a thing that asshat says...
    831Tun likes this.
  22. Mar 29, 2018 at 2:49 PM
    #52
    n2deep
    He was probably drunk and forgot he even said it.
    osidepunker[QUOTED] likes this.
  23. Mar 29, 2018 at 2:49 PM
    #53
    KevinK
    Tundras to Sedona
    more than likely
    osidepunker likes this.
  24. Mar 30, 2018 at 4:49 AM
    #54
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I actually like the nannies. I never disable them. VSC has saved me on the trail more times than I can count and 4hi A-TRAC works well in 90% of the situations I encounter.
  25. Mar 30, 2018 at 5:54 AM
    #55
    Years ago, when I had my Tacoma, it sent me across two lanes of traffic with a posted speed limit of 55mph. Now that was scary. I was livid with the damn sensitivity of the truck.
  26. Mar 30, 2018 at 7:18 AM
    #56
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    Ive had this happen a few times on my other 2010 tundra. 100% pucker moments.
    KevinK[OP], ColoradoTJ and T-Rex266 like this.
  27. Mar 30, 2018 at 1:03 PM
    #57
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I wonder if a call or email to some desert truck companies like camburg, down south, TC, sdhq would be worth it. They build some sick trucks and work them hard. Maybe they know of this?
    OcotilloSR5 likes this.
  28. Mar 30, 2018 at 2:15 PM
    #58
    KevinK
    Tundras to Sedona
    I was out Saturday night with SDHQ which kinda prompted this thread. They hit the same situation in their Tundra while I was in the passenger seat. I offered to pay the cleaning bill for the seat I was sitting in.
    I'd for sure be interested in hearing others' solutions. At this point I'm planning to put a relay inline with the ABS1 fuse and control it with a momentary switch. ABS should be active every time you start the truck for safety. If I want to disable it, press the momentary switch to kill ABS, and when the truck turns off, the relay returns to closed so ABS is active the next time the truck turns on.
    I don't want someone to end up driving our truck without ABS by accident. Myself included.
  29. Mar 30, 2018 at 5:08 PM
    #59
    osidepunker
    Alex
    2013 Tundra DC 4x4
    How bout you pull the damn fuse first and test it??
  30. Mar 30, 2018 at 6:53 PM
    #60
    Help New Member
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    But then he's gonna have to come up with some other plan to dream/talk about for several weeks before actually doing anything about.
