Center console firearm/flashlight build mod
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 25, 2014.
  1. Apr 29, 2017 at 1:51 PM
    #121
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Now there is a real use for Lefty holsters :)
    4x4_Angel and NewImprovedRon like this.
  2. May 23, 2017 at 3:32 AM
    #122
    StormtrooperTK624
    StormtrooperTK624 New Member
    Sugar Land, TX
    2014 Tundra SR5 TSS Edition
    3" level kit
    I like that setup. Is there enough clearance to where your leg doesn't touch the mount?
  3. May 23, 2017 at 5:03 AM
    #123
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    That's going to hurt when the airbag goes off!
    NewImprovedRon likes this.
  4. Jul 7, 2017 at 2:40 PM
    #124
    ScottTN
    ScottTN New Member
    2003 White Access Cab
    Just bought, so I have only mounted a holster under the steering wheel, disabled the DRLs and plasticoated the grill. But I am open to ideas!
    I have a 1st Gen Tundra that I bought recently. I mounted a custom kydex holster under the steering wheel, in that cut out space to the right. All I did was take off the panel, get the holster where I wanted it, mark where the holes needed to be and drill. Bolted the holster on loosely, put my (unloaded) 1911 in, then used a heat gun to finish molding the holster to the panel as I tightened it down. Retention is great, it's out of sight, doesn't interfere with anything, plenty of clearance for my legs, and perfectly legal here in Tennessee with OR without a permit. I can post a pic or two if anyone is interested.
    The Juice and Bob like this.
  5. Aug 4, 2017 at 10:12 AM
    #125
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    :cheers: post some pics man!
  6. Aug 4, 2017 at 10:16 AM
    #126
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    What type of velcro are you using?
  7. Aug 4, 2017 at 10:25 AM
    #127
    4x4_Angel
    Bree
    Funky Town, Texas
    Heavy duty velcro should work fine. I've used it for all sorts of things in a DPS squad car and it's always held up
  8. Aug 4, 2017 at 10:36 AM
    #128
    ktharbour6
    ktharbour6 New Member
    2016 Toyota Tundra TRD Pro MGM
    It's not the Velcro that fails... the sticky fails due to the summer heat.
    2016 Toyota Tundra TRD Pro CM MGM
    IG: @kt_harb.protundra
    Wharf-Rat likes this.
  9. Aug 4, 2017 at 10:41 AM
    #129
    4x4_Angel
    Bree
    Funky Town, Texas
    I understand that....Texas is a hot state and I've used velcro on the inside of the squad car and in the trunk of the squad car....it held up in the extreme heat and cold
  10. Aug 4, 2017 at 10:42 AM
    #130
    ktharbour6
    That's impressive then. I tried using it to hold a holster and it failed within a couple days. With the handgun in it.
  11. Aug 4, 2017 at 10:43 AM
    #131
    4x4_Angel
    Bree
    Funky Town, Texas
    This is actually what i used. It never failed.
    Sunnier and ktharbour6[QUOTED] like this.
  12. Aug 16, 2017 at 12:48 PM
    #132
    stripperclip
    stripperclip New Member
    COS
    2016 White Tundra DC SR5 TRD
    Caveat: Your statement only applies to handguns in Colorado. Rifles and shotguns fall under the hunting laws so they can not be loaded (In the chamber.)
  13. Oct 24, 2017 at 6:24 PM
    #133
    907Tundra
    907Tundra New Member
    2015 Double Cab SR5 Magnetic Gray Metallic
    Great thread - I’ll be doing this set up for my Glock 23. Another reason why I love Alaska - no need for a CCL, we can own as many guns as we want, and we can open carry if we so choose
  14. Oct 25, 2017 at 1:04 AM
    #134
    caboose
    caboose -1
    somewhere in the USA
    tundra dc trd
    ride rites w/ air compressor, trd pro grille, decked bed storage, nfab rkr rails w/steps, remote start.
    what kind of pistol is that?
    rons23 likes this.
  15. Oct 25, 2017 at 2:24 AM
    #135
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Just what I have been looking for. Nice set up. How did dock mount? Thanks for the post Backslider.
    Backslider[QUOTED] likes this.
  16. Oct 25, 2017 at 3:46 AM
    #136
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    There are screws specifically for plastic and a provided template for drilling pilot hole. I opted to use bolts with a washer and nuts on the inside. I drilled using the template and then removed the center console to mount. A lot of people just use the provided screws for plastic and don't secure from the back and report that It A still completely stable. If you go that route 5 minutes. If you secure from the rear 1 hour.
    rons23[QUOTED] likes this.
  17. Oct 25, 2017 at 3:47 AM
    #137
    Backslider
    Tooele, UT
    CZ P01 with some CGW upgraded and g10 grips.
  18. Oct 25, 2017 at 3:57 AM
    #138
    rons23
    Ron
    Kill Devil Hills
    Gotcha, options are always good. Thanks again
  19. Oct 25, 2017 at 4:49 AM
    #139
    Nice, clean setup Ron. See you have some easy listening Pink Floyd in your music selection. :thumbsup:
    NewImprovedRon and 4x4_Angel like this.
  20. Oct 25, 2017 at 4:57 AM
    #140
    Well, at least you could effectively defend the start of WW3. I say add the rest of the 3 empty spots in the foam and another box of ammo, just to be safe. :D
    I’m just like you, I have a “few” spare magazines placed....everywhere.
    Nice out of the box setup you designed. :thumbsup:
    viha22 and 4x4_Angel like this.
  21. Oct 25, 2017 at 6:55 AM
    #141
    rons23
    Ron
    Kill Devil Hills
    X2 on that Ron. 2 Ron's definitely make it right in this instance
    NewImprovedRon and ColoradoTJ like this.
  22. Oct 26, 2017 at 10:33 AM
    #142
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    I don't like keeping a weapon out in the open so I keep my "throw away" PF9 up in one of the sunglass holders, with a couple of extra mags in another.
    Access is just as quick, if not quicker, than having it in the console, which I did try for a bit.
    EDC is a PPS but I don't always have that on me due to work restrictions.
    TXDrifter and NewImprovedRon like this.
  23. Oct 26, 2017 at 11:21 AM
    #143
    Backslider
    Tooele, UT
    I don't like the idea of it flopping around in there, or the fact that it's not going to always be in exactly the same spot/orientation if I need it in a hurry.
    Mine isn't kept in the open, just when driving. When I am out of the car it transfers to my person and travels with me, or when appropriate, gets locked in the truck.
  24. Oct 26, 2017 at 1:32 PM
    #144
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    Just installed this console safe and I think it’s going to serve me well.
    Before:
    After:
  25. Oct 27, 2017 at 12:59 PM
    #145
    rons23
    Ron
    Kill Devil Hills
    Well I decided to do something with the void in front of my console. I don't know what they intended for this space to do. Maps perhaps, don't know. Anyway I took some of my pick and pluck left over and cut it to fit . I made 3 cut outs , 2 for my Walther PPS mags and 1 for my Canik 18 rd mag. Fits pretty good and very quick access.
    e283234d23672a624e9c3e575f300df2_b4c6f875990ef7d462a663a9cc1d30d618f802df.jpg03b43931a82fc604dc7dc06e4b6c39de_e46709d2e1edf3ba03723bffaa9e04ccbc73414e.jpg2d24ebf622a4633beba4def2c910e267_a458da750c690c4faf7b2c0e6cbb7909d909fa75.jpg14ddc0661c0c590ffcf745debcabfd7c_d842c4ee7003e74a4588f9bd62d455f4ddd1440c.jpg
  26. Oct 28, 2017 at 7:47 PM
    #146
    JTP
    The Big Black Moose
    Had to FFL my handguns up from Texas to Alaska, NO FRICKEN WAY are they allowed in Canada.
  27. Oct 28, 2017 at 7:55 PM
    #147
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Thats brillant! Now I have somewhere to put my backup gun into considering my sunglasses do not fit the sun glass holder.
    JTP likes this.
  28. Mar 27, 2018 at 10:39 AM
    #148
    scharring100
    scharring100 New Member
    Houston, Texas
    2016 Tundra Limited 4X4 Crewmax
    2016 Crewmax, Bronze 4X4
    Maglite has a rechargeable flashlight that I wired into the electrical system, mounted it on the left side of my counsel, just had to make sure that the seat adjustment doesn't affect it. Looks great and always has power, it recharges every time I turn on the key
    TundraDude18 likes this.
  29. Mar 27, 2018 at 4:33 PM
    #149
    Taco-Blender
    AZ
    2010 DC 4x4
    :worthless:
    TundraDude18 and aguilara19 like this.
  30. Mar 28, 2018 at 11:06 AM
    #150
    scharring100
    Houston, Texas
    IMG_4130.jpg IMG_4129.jpg Rechargeable Maglite
