Engine noise 2004
Discussion in '1st Gen Tundras (2000-2006)' started by Knielsen1981, Mar 7, 2018.
  1. Mar 7, 2018 at 5:12 PM
    Knielsen1981
    Knielsen1981 [OP] New Member
    Kelly
    2004 Toyota Tundra
    None
    Ok sorry if this has been asked before but I have a 04 tundra limited no oil leak but the water pump does leak. The engine makes an intermittent rattle like noise almost like when u attach a playing card to a bike spoke. It happens at different speeds but only when u accelerate. Noticed it the first time when we were reving the engine after doing one of the ac refill cans. It happens more frequent now. Any ideas??? Thank you
    Kelly
    Y0TA PR0 likes this.
  2. Mar 13, 2018 at 6:59 AM
    Knielsen1981
    Kelly
    2004 Toyota Tundra
    None
    Anyone??
  3. Mar 17, 2018 at 7:54 AM
    Rolodetective
    Rolodetective Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    The only thing I can think of is something making contact with your rad fan. Leaf? Stick? :notsure:
  4. Mar 17, 2018 at 8:01 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Do you have a general idea of where the noise is coming from? How many miles on it? If it were my truck I would tackle the water pump first since it's leaking. If it has a lot of miles I would take care of the timing chain and tensioner also.
  5. Mar 21, 2018 at 1:54 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    this^^^ and possible exhaust header cracked/leak (very common w 2004) which can sound like a rapid ticking noise
    landphil likes this.
  6. Mar 21, 2018 at 2:03 PM
    15whtrd
    15whtrd Mr. Blonde
    In the old days that noise meant possible broken motor mount. I don’t know how these motor mounts attach but maybe check it out.
    nk1794 likes this.
  7. Mar 24, 2018 at 8:32 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I would just replace the obvious water pump and do the timing belt. The noise might be something else.....so take some fuel line hose and put one end to your ear and the other end you search around until you can pin point the noise.
  8. Mar 24, 2018 at 9:42 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m thinking cracked exhaust manifold as well.
    Is it worse or better as the engine temperature changes?
  9. Mar 27, 2018 at 3:18 AM
    mooney
    mooney New Member
    2005 Tundra Doublecab TRD 2WD
    My 05 has almost 200k miles on it and since about 150k it has had a slight knocking sound if I start it in cold weather and start driving right away without letting it warm up a little bit first. My dad’s 00 model with almost 300k does the same thing, and has done it for years, but only when it’s cold. He thinks it’s a cracked piston skirt, which sounds alarming, but he’s been doing this a lot longer than me. He says to just let it warm up for a few minutes before driving, which has worked for me thus far.
    To me it sounds like maybe a gas knock or possibly the oil is too thick to reach an internal component in the valvetrain at first. I just tried using a thinner viscosity oil to test this theory, so I can let you know if that works because it’s still dropping below freezing here in Virginia.
  10. Mar 27, 2018 at 4:36 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Take a look underneath for loose exhaust heat shields and worn out hangers.
    The 4.7's are just known for being noisy on a cold start, some claim piston slap others noisy injectors but there doesn't seem to be any adverse effects.
    Mine gets 0w-20 in the winter and still rattles under 40 degrees. I just let it warm up for a minute and it's gone.
  11. Mar 27, 2018 at 5:13 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Most likely it's the exhaust manifold, I have the same issue, but I dont think it sounds like a knock. I highly doubt these engines would have a piston issue. The only way you can pinpoint the noise is with the hose, you can look all you want. I, being a mechanic have a stethoscope hooked to a hose. An exhaust manifold leak can sound like "A playing card on a Bicycle wheel"
  12. Mar 27, 2018 at 5:21 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome! 1981 was a good year! :thumbsup:
