Rock warrior woes.....
Discussion in 'New Member Introductions' started by Disguntled Rock W. Owner, Mar 22, 2018.
  1. Mar 22, 2018 at 3:14 PM
    Disguntled Rock W. Owner [OP] New Member
    Robert
    2011 rock warrior 3ur-fe
    TRD air intake, leveling kit
    Hello, long time reader first time poster. Took my Rock Warrior in for service at 80050 Miles and they were more than happy to point out my oil leak. I explain to them that they have been the only people that have been servicing my vehicle since I purchased it how could this oil leak possibly go unnoticed you are the only ones that have changed the oil in my vehicle. It lives in a clean garage and never shows sign of any leaks. I check my oil couple times a month have never added oil. But Toyota knows it drips onto the manifold and the owner will never see it. They started at $2,700 now they are giving me a deal at $2,100 I told them to pound sand. Fortunately I have Grease Monkey Buddies. Took two of us 9 hours to replace valve cover gaskets, thermostat , serpentine belt , belt tensioner, water pump.(Water pump was on last leg,surprisingly wasn't dropping it's water yet ) between the Chilton book and this website it wasn't that difficult. Cam Tower seals sure sounds expensive. It's just a valve cover gasket. This is my third new Toyota pickup I have purchased. The first two were Tacomas,great trucks, kept them servced only at Toyota. Not one problem with either. Trade in at 150 k and go again. Was planning the same for this Tundra but if I'm going to have to turn wrenches on my rig at 80 k will be purchasing different brand next time....raptor time.....
  2. Mar 22, 2018 at 3:26 PM
    Welcome from CO. Dealer work is expensive, but at times it can be a piece of mind. Where was it leaking from? I havent heard of any 2nd gen Tundras with the cam tower oil leak- usually just 3rd gen which is a hit and miss per vehicle.
  3. Mar 22, 2018 at 3:26 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Welcome. So when you were wrenching, did you find the oil leak?
    Not to be an ehh-hole, but you had an under $3k repair bill and you are about to jump ship to ford.....buy the longest extended warranty available.
    Prostar 190 and zcarpenter92 like this.
  4. Mar 22, 2018 at 3:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So you drove 380,000 miles with Toyotas and had $2100 in repair costs and you want to jump ship to Ford? You'll beat that in the first month out of warranty on a Ford.
  5. Mar 22, 2018 at 3:35 PM
    Robert
    Passenger side ,extended warranty does no good unless YOU find the problem before end of warranty
    Black Wolf and Thegr8punkin like this.
  6. Mar 22, 2018 at 3:47 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Robert. If you get the Ford get some really good wrenches too.:thumbsup: It's kinda like milk and cookies. They go together.
  7. Mar 22, 2018 at 3:50 PM
    n2deep
    n2deep Pavement Princess
    There are Gen2 with Cam Tower leaks. Mine has been leaking since 45k but dealer wouldn't fix it. Know of other Gen2's with the same issue - one was fixed, leaked again and fixed again.
  8. Mar 22, 2018 at 4:06 PM
    Grumpy Uncle
    Pat
    CO
    List of unscheduled maintenance on my F150
    4 COIL PACKS AT ONCE, 1, 3, 5, AND 7 @11700 miles, no explanation $938
    C-CLIP REAR DIFF, again no explanation @ 26000 miles, $1100
    FUEL PUMP@38000 miles another $1100
    Water pump @42000 miles $688
    It sure looked good though!!!
  9. Mar 22, 2018 at 4:30 PM
    I love my local Grease Monkey guys. Been using them since my Taco. 7 years now. Trust them totally..
  10. Mar 22, 2018 at 4:37 PM
    TheBeast
    TheBeast The Beach
    well now that it is fixed you should be good. I have a gen 2 and the dealer fixed it under warranty. I had both sides done.
    Black Wolf, 15whtrd and 831Tun like this.
  11. Mar 22, 2018 at 4:54 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    More importantly, before you trade it, can we swap wheels?
  12. Mar 22, 2018 at 5:06 PM
    blizz86
    blizz86 New Member
    Dealerships aren't your babysitter, they are a money making business and its up to you to ensure your truck is in tip top condition. Having that warranty holds them liable to fix your truck IF you find something wrong. Despite you paying for their maintenance and "inspections", businesses will cut corners wherever they can.
    15whtrd likes this.
  13. Mar 22, 2018 at 5:18 PM
    15whtrd
    15whtrd Mr. Blonde
    Good call!
    Black Wolf likes this.
  14. Mar 22, 2018 at 5:25 PM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Knew this was gonna be :popcorn: worthy thread when I saw the OP username.
    Sounds like your gripe should be with the dealership not the brand.
  15. Mar 22, 2018 at 6:23 PM
    Welcome from Ohio!
    :popcorn:
  16. Mar 22, 2018 at 6:38 PM
    Found On Road Dead
    Fix Or Repair Daily
    Fucked Over Returning to Dealer
    "anyone else can chime in"....haha.
    Marty McFly and 15whtrd like this.
  17. Mar 22, 2018 at 6:43 PM
    15whtrd
    15whtrd Mr. Blonde
    Fucker only runs downhill
    Pudge likes this.
  18. Mar 22, 2018 at 7:39 PM
    Robert
    To follow up a little here. I had a leaking valve cover. Have only driven it for 50 miles since. No oil leaks. Could possibly still have cam tower seal problem if any oil is noticed just below valve cover....creeper, flashlight,mirror....no problem. I am diligent now
  19. Mar 22, 2018 at 7:49 PM
    blizz86
    blizz86 New Member
    You should be able to see the cam tower leak from under the front fenders .. if it’s leaking
  20. Mar 22, 2018 at 7:53 PM
    Robert
    True, but that mini mud flap right in way
  21. Mar 22, 2018 at 8:10 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I say get the Raptor. Come back in 6 years and let us know how that decision worked out.
    blizz86, 15whtrd, Marty McFly and 2 others like this.
