Hairline crack on wheels
Discussion in 'Wheels & Tires' started by Gibzki, Mar 18, 2018.
  1. Mar 18, 2018 at 5:26 PM
    Gibzki
    Gibzki [OP] New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    Attention wheel experts. Should i be worried? I just got new tires installed last Friday (35/12.5r20 ridge grappler). Saturday i decided to polish my wheels (moto metal MO961 20×9) when i noticed hairline crack on one of the spokes. The crack is only at the front and nothing at the back. I'm not loosing air at all. I wash my truck and wheels almost every 2 or 3 weeks and never noticed this. Do you guys think its just paint? Is it possible for the tire dealer to have done this when they installed the new tires?
  2. Mar 18, 2018 at 5:29 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    That is not good. I wouldn't drive it.
  3. Mar 18, 2018 at 5:32 PM
    Gibzki
    I know. I'm taking it back to the installer tomorrow and see what they have to say. I was hoping I can get some opinion from wheel experts here before taking it back.
  4. Mar 18, 2018 at 5:32 PM
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    Could be just a crack in the paint/ outer coating.
    If you wanted to be 100% sure, I’d sand it to metal and check. Then re finish.
    Y0TA PR0 and NewImprovedRon like this.
  5. Mar 18, 2018 at 6:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm no expert by any means and it's hard to tell from a photo but if that were mine I'd replace it. Risks VS rewards. ~$200 for peace of mind and to be certain. BTW, I'd contact Moto Metal to see if they'll replace it.
    Watt maker likes this.
  6. Mar 18, 2018 at 6:43 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    If it is indeed the aluminum that is cracked, and that is what it looks like. 3rd pic down appears to show the crack in the aluminum and not just the paint. Replace it soon! It will spread!
    831Tun likes this.
  7. Mar 18, 2018 at 7:09 PM
    TheBeast
    TheBeast The Beach
    doubt the tire install did that. not much sidewall on 20"s so they take more beating than 18"s. I would get a replacement one. at least it's just the rim, you already got new tires :)
    ColoradoTJ likes this.
  8. Mar 18, 2018 at 7:15 PM
    Cuzican
    Cuzican New Member
    Louisiana
    If you are the original purchaser of the wheels, looks like it should have a lifetime structural warranty.
    Sunnier, ColoradoTJ and 831Tun like this.
  9. Mar 18, 2018 at 11:21 PM
    Great advice on this thread.
    This is a constant reminder to inspect your truck more frequently. Had you not cleaned your truck, and then polished the wheels, it may not have been noticed until failure.
    Google “wheel failure” and select images.
    If you want a bigger jaw dropper, google image “Z06 wheel failure”....
    SouthBoundSteve, 15whtrd and 831Tun like this.
  10. Mar 18, 2018 at 11:34 PM
    Just to add:
    Quality wheels are not cheap, and cheap wheels are not quality.
    Most of the wheels I have seen break are off-road, usually steel beadlocks, and people running big tires on 5/6 lug wheels. My beadlocks were 335.00 each and I got a screaming deal. I should have been up in the 350-375.00 each.
    I just went back to factory 18’s on my truck as of today for the same reason....safety. The 20” factory tires and wheels would not support the maximum capacity of my truck, and why it came with 18’s on the 1 tons regardless of trim package. I didn’t want to spend the money, but I also don’t want to kill someone’s family in oncoming traffic or my own.
  11. Mar 19, 2018 at 12:34 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I have had MM 961 (in chrome) for last 6 years without an issue. The roads around here are horrendous, so the wheels are put through some severe beating.
    I could not tell if these are scratches or cracks from the pictures. If they are indeed cracks, I would definitely check with the manufacturer.
    MM 961 are not cheap wheels. 6 years ago, the cheapest ones I found were in $200's for 18s and in $300s for 20s. I found plenty of wheels for little more than $100 back then. I've read plenty of reviews on them and I do not remember coming across any failure.
  12. Mar 19, 2018 at 1:52 AM
  13. Mar 19, 2018 at 2:33 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  14. Mar 19, 2018 at 4:30 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    Those are obvious signs of microporosity my friend. Complete structural issue based on the casting of the wheel. Im willing to bet those things missed a cooling cycle during manufacturing or the recipe was wrong. Either way. I’d be getting rid of them things ASAP.
  15. Mar 19, 2018 at 5:08 AM
    chphilo
    Western PA
    Some of these reviews I read before. I knew about their skull wheels. That's why I stayed away from them.
    I looked at the overall review of the wheel (961) before going this route. I don't know of any product that doesn't have negative review somewhere (google Tundra problems). When I looked at overall reviews, they seemed to be more positive than negative. But then again, this was several years ago. Product quality seems to change quite a bit from year to year.
    OP, Moto Metal has lifetime warranty on their wheels as far as I know. If you think these are cracks, definitely contact the company. I would not drive on them.
    Sunnier and ColoradoTJ[QUOTED] like this.
  16. Mar 19, 2018 at 10:05 AM
    Exactly @Watt maker
    Just because a wheel is expensive, doesn’t make it a quality one.
    equin and Watt maker like this.
  17. Mar 19, 2018 at 8:53 PM
    Gibzki
    Update:
    So I called manufacturer about the warranty and they told me to go to one of their dealers to check on the wheel. After visually inspecting the crack, dealer told me that it's only the paint and just advised me to keep on eye on it. It has not gotten worse since I noticed it last Saturday thou.
    Guess I have to start saving money for a new wheel now.
    Watt maker, Y0TA PR0 and ColoradoTJ like this.
  18. Mar 19, 2018 at 10:20 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Sure looks like a crack to me. Paint just chipping off does not follow a line without a crack... common sense tells me that.
  19. Mar 20, 2018 at 8:03 AM
    Cuzican
    Cuzican New Member
    Louisiana
    I'd ask the dealer to put that in writing if he's so sure it's just the paint. I bet he won't since it will make him liable if/when things go bad.
    Albertaundra, 831Tun, Sunnier and 5 others like this.
  20. Mar 20, 2018 at 8:58 AM
    TheBeast
    TheBeast The Beach
    yep
    Sunnier and Smiley like this.
  21. Mar 20, 2018 at 10:07 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    I see cracked wheel the pictures. Not just paint.
    landphil and Cuzican like this.
  22. Mar 20, 2018 at 10:16 AM
    Here are two of my Raceline Wheels. They have been beat on, rock rashed, jumped, and abused like only one can imagine. See any flaking powder coat?
    I couldn’t imagine what might happen if a wheel came apart at 75 mph, nor do I ever want to find out.
  23. Mar 20, 2018 at 10:35 AM
    Fixed it for you.
    Just because someone sells wheels, doesn't make them an expert. I would have asked to see their Metallurgy Degree specializing in stress fractures, along with their physics degree.
    I'm not really sure why companies put themselves out there like this. If I were the owner of MM, I would just replace the wheel.
  24. Mar 20, 2018 at 12:33 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Word! I'm looking at this on a phone and I can still see a crack in the 3rd pic. I'd go to another shop that sells their wheels and get a second person to look at it.
  25. Mar 20, 2018 at 12:51 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    True. My Dad thought he got a good deal on a used Mercedes. He later discovered an OE rim cost over $500 to replace a cracked one. While looking for better pricing, we discovered a slew of complaints about Mercedes OEM wheel cracks. I believe those are Mercedes-Benz AMG branded wheels manufactured in Europe. I guess that just goes to show even high-end wheels can develop cracks.
  26. Mar 20, 2018 at 1:37 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    THIS, ^^^ I would go to another dealer until I found one that agrees with you.
    Sunnier and ColoradoTJ like this.
  27. Mar 20, 2018 at 3:25 PM
    Same with Corvette Z06 wheels. Have to watch the early ones.
    Watt maker and equin[QUOTED] like this.
  28. Mar 20, 2018 at 3:32 PM
    equin
    Ed
    DFW, TX
    Yeah, I heard about those, too.
  29. Mar 20, 2018 at 5:55 PM
    Which one are you referring to? :rofl:
  30. Mar 20, 2018 at 5:56 PM
    Sunnier
    Sunny
    San Diego, CA
    All of this. The "scratch" coming off both sides of that spoke looks like a crack to me. If something "scratched" from one side toward the spoke, it would be knocked aside by the spoke and so would not be in contact with the wheel to continue scratching from the base on the other side. Just doesn't happen like that.
