Lower half of controls not illuminating
Discussion in '2nd Gen Tundras (2007-2013)' started by Whocares, Mar 17, 2018.
  1. Mar 17, 2018 at 5:44 PM
    Whocares
    Whocares [OP] Member
    Hello all,
    Recently had remote start and security (Viper) installed and now the lower half of controls (thermostat dials, tow/haul, info buttons) will not light up. Install shop tried everything they could but to no avail. Anybody have any tips or suggestions? Thanks.
  2. Mar 18, 2018 at 10:29 AM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    my guess is the install shop accidentally broke a ground fore the lower controls, since its a whole bank of controls and not one you will have to track the connections for said controls till you find the break.
    15whtrd likes this.
  3. Mar 18, 2018 at 6:17 PM
    Whocares
    Thanks. I'm not well versed in electrical components. How would I go about fixing it?
  4. Mar 19, 2018 at 7:56 AM
    Thee_Oddball
    Eric
    Chicago
    see if you can find a schematic for the dash online and see where all the connections are for the components.
  5. Mar 19, 2018 at 8:47 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    That sucks. What year and trim? I’ll see if I can find a schematic for you when I get home tonight. Cant promise but I’ll try.
    15whtrd likes this.
  6. Mar 19, 2018 at 8:50 AM
    Whocares
    Thank you
  7. Mar 19, 2018 at 8:51 AM
    Whocares
    2012 5.7. Thank you.
  8. Mar 19, 2018 at 8:52 AM
    nk1794
    San Jose, CA
    What’s the trim?
  9. Mar 19, 2018 at 8:55 AM
    Whocares
    4x4 double cab rock warrior
  10. Mar 19, 2018 at 8:59 AM
    nk1794
    San Jose, CA
    Thanks
  11. Mar 19, 2018 at 9:52 AM
    Whocares
    Thank you
  12. Mar 19, 2018 at 10:14 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Id drive it back to the shop and make them fix it correctly,thats just shoddy workmanship IMO
    NewImprovedRon and nk1794 like this.
  13. Mar 19, 2018 at 10:48 AM
    Whocares
    Completely agree and that's what I did initially. 5 hours later, they still had no idea what was wrong. Rather not go back there.
    nk1794 likes this.
  14. Mar 19, 2018 at 12:38 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Then they will be paying the bill from the dealer,if you let them slide on it they will keep messing up other peoples stuff and not caring, but thats just me
    15whtrd and nk1794 like this.
  15. Mar 19, 2018 at 12:56 PM
    nk1794
    San Jose, CA
    Is it save to assumed that they check to make sure there are no blown fuses?
  16. Mar 19, 2018 at 2:59 PM
    Whocares
    Yes they are fronting the bill.
  17. Mar 19, 2018 at 3:00 PM
    Whocares
    Technician told me that he hooked it up to a different power source and it lit up. Confusing to say the least. I'm not familiar with electrical components so I'm wondering why he couldn't have just kept it with the power source that worked.
    Everything had been working properly prior to the installation of the alarm.
  18. Mar 19, 2018 at 3:07 PM
    Whocares
    The initial install went great; everything worked but I wanted to customize it so I went back. Increase glass break sensor sensitivity, 1 click unlock only drivers door, disable Toyota factory lock/unlock chirps (disabling vipers chirps wouldn't allow the 1 click unlock), and integrate truck horn with alarm.
    I guess in the process of doing all this, something or someone messed up. On the 5 hour visit, I believe they pretty much reinstalled the entire system but found nothing.
  19. Mar 19, 2018 at 3:07 PM
    nk1794
    San Jose, CA
    So it’s all good now?
  20. Mar 19, 2018 at 3:10 PM
    Whocares
    No, I believe it was an external power source just to check to see if there wasn't an issue with the thermostat knobs themselves. Like I said, it's confusing.
  21. Mar 19, 2018 at 3:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe I’m stating the obvious but there is also another fuse panel by the drivers left knee above the emergency brake.
    nk1794 and Thee_Oddball like this.
  22. Mar 19, 2018 at 6:08 PM
    nk1794
    San Jose, CA
    PM me your email and I'll send you the diagram. It's about 10 pages long so you will have to print them out and stitch them together. I think if you take it back to the shop they should be able to trace it out for you.
