Light bar Install - need ignition source
Discussion in 'Lighting' started by 4Runner, Feb 8, 2018.
  1. Feb 8, 2018 at 11:54 AM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Searched but didn't find exactly what I was looking for. This is not in my wheelhouse so want to make sure I get it right. I have a Headlight Revolution stealth light bar that came with a GTR halo switch. I have everything hooked and the switch turns on and off the LB without issue. I'm now need power to light up the halo switch at night when my other factory switches light up. To do this I want to add a circuit to my fuse box and I'm looking for recommendation on which fuse to use. I was thinking either the 7.5 ACC or Panel but the inline fuse they gave was 10A. Since I'm adding a circuit I'm not using the inline fuse but wasn't sure if that meant I should add my circuit to a 10A fuse. Thanks for any advise.
    fuse panel
  2. Feb 8, 2018 at 11:58 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
  3. Feb 8, 2018 at 12:20 PM
    4Runner
    Columbia, SC
    Thanks for the link. That worked but not exactly what I was looking for....I might just leave it as is. Right now, the halo lights up whenever the key is turned to ACC or ON as opposed to the other factory switch lights illuminate when the headlights come on. Still, looks cool. Thanks again for the quick reply.
  4. Feb 8, 2018 at 1:44 PM
    4Runner
    Columbia, SC
    Good idea. Thanks
  5. Mar 16, 2018 at 10:15 AM
    4Runner
    Columbia, SC
    I purchased this boost gauge and it needs a 12v source. Would it be okay to just tap into my positive and negative wires from my halo switch instead of adding a circuit on the fuse box? The halo switch wires are right there and readily available. Appreciate any advice.
    http://www.p3cars.com/subaru/brz-fr-s-ft86-p3-boost-gauge/
  6. Mar 16, 2018 at 12:50 PM
    4Runner
    Columbia, SC
    Just did it. Worked out well. Just don’t know where to plug into the SC now. Thanks for the boost of confidence.
    NewImprovedRon likes this.
  7. Mar 16, 2018 at 2:42 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  8. Mar 16, 2018 at 6:08 PM
    ZPMAN
    Minnesota
    Thanks Ron...
  9. Mar 17, 2018 at 1:52 PM
    4Runner
    Columbia, SC
  10. Nov 12, 2019 at 10:28 AM
    15DCLB Tundra
    15DCLB Tundra New Member
    Jerry
    2015 Tundra SR DoubleCab LongBed 5.7
    I like the P3 gauge. I want to do one for my Tundra to read the MPH. Have you tried your gauge for speed? I was wondering if it changes rapidly (flickers between numbers) or if it is pretty stable to use as an actual speedo. I'm assuming you got the OBDII version, if not then you won't have the speedo option. Either way, clean install!
    Jerry
  11. Nov 12, 2019 at 10:50 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    yep that is what I did. piece of cake
