How much lift in rear
Discussion in 'Suspension' started by triplej23, Mar 14, 2018.
  1. Mar 14, 2018 at 5:48 PM
    triplej23
    triplej23 [OP] New Member
    2013 Tundra TRD
    I have a 2013 and I’m
    going w Fox 2.5 coil overs w total chaos uca in front looking for about 3 in lift. In rear I got fox 2.0 shocks w a pro comp 1 inch block. My question is with this set up does any one know if I will still have some rake. What I’ve seen a lot of 3/1 lifts on tundras is the rear sag while driving. Do not want that. Should I go w a 2in block and will these shocks work with the extra inch. Any info would be appreciated.
  2. Mar 14, 2018 at 6:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. No, I think you'll end up level if your leafs haven't begun to frown. I'd recommend getting rid of the block and adding Toytec shackles at the 1.5" setting.
    zcarpenter92 and joonbug like this.
  3. Mar 14, 2018 at 7:16 PM
    BenAZ, csuviper and 831Tun like this.
  4. Mar 14, 2018 at 7:19 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    T-Rex266[QUOTED] likes this.
  5. Mar 14, 2018 at 7:23 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Me three!
    831Tun[QUOTED] and T-Rex266 like this.
  6. Mar 14, 2018 at 7:25 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I'm new here but what is the difference in the block and the shackles
  7. Mar 14, 2018 at 7:27 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    A block is literally a block of steel or aluminum placed between the axle and leaf springs to provide lift. A shackle is what connects the frame to the leaf springs, and a longer one lifts the rear end.
  8. Mar 14, 2018 at 7:34 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I'm on ToyTec Boss up front and back with ToyTec shackles set to the middle. I'm considering raising it to the top setting as my truck looks like it MIGHT be a little lower in the back. It's so close, it is hard for my eyes to tell. I believe the middle is 1" and the top is 1.5" if memory serves...
    T-Rex266 likes this.
  9. Mar 14, 2018 at 7:36 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can you post a picture of your truck?
  10. Mar 14, 2018 at 7:39 PM
    boostedtrdpro
    Jeremy
    T-Rex266 and RangerBP like this.
  11. Mar 14, 2018 at 7:40 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what does that setup cost ?
  12. Mar 14, 2018 at 7:42 PM
    boostedtrdpro
    Jeremy
    With the UCA's it was close to $2000 for the suspension. Another $2650 or so for the wheels and tires.
  13. Mar 14, 2018 at 7:44 PM
    triplej23
    2013 Tundra TRD
    I like the fact of using shackles but I was just reading that the fact I have TRD dual exhaust I will need to do some modifications to that. Any one dealt with this
    831Tun likes this.
  14. Mar 14, 2018 at 7:45 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The shackles are pretty inexpensive ~ $125. The block promotes axle wrap from what I read in an article about SUA suspension.
  15. Mar 14, 2018 at 7:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, the pipes will hit. Great opportunity to dump the exhaust.;)
  16. Mar 14, 2018 at 7:47 PM
    boostedtrdpro
    Jeremy
    Which is precisely what I did. BAM TRD replacement 16x5 system with dual dumps. Sounds pretty stellar!
  17. Mar 14, 2018 at 7:51 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Coach builder +3 shackles. Nets about 1.5-1.75” of lift.
    I’m at 3/1.5 lift with my setup.
  18. Mar 14, 2018 at 7:53 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what did you pay ? do they have a 3/2 ?
  19. Mar 14, 2018 at 7:55 PM
    Bill c
    Bill c New Member
    shinglesprings,ca
    08 crewmax
    fabtech 6'' lift with dirt logic coil overs. 20''wheels 35'' tires. dual flow master exhaust, K&N intake, rear air bags.
    tundra.jpg I had the same prob with mine, sat a tad low in the rear, went round and round with the best way to level it. for me it was air bags. its level, rides real nice and helps when I pull the trailer. best all around set up for me, under a 100 bucks for 2,500 lb bags.
    blue16 likes this.
  20. Mar 14, 2018 at 7:56 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    nice looking truck!
  21. Mar 14, 2018 at 8:04 PM
    triplej23
    2013 Tundra TRD
    Can’t replace exhaust. Can I just add another 1 in block (not sure if possible) with the fox 2.0 shocks or will that stretch the shock to much
  22. Mar 14, 2018 at 8:11 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    Do the Coachbuilder Shakles also have conflict with the TRD exhaust? I currently have a 1.25" block in the rear and want to get rid of that, but I like the TRD exhaust. I wanted to get the Toy-Tec since they are local and less than 10 miles from me, but I am not good with pipe modifications and I am on a budget.
  23. Mar 14, 2018 at 8:12 PM
    Bill c
    Bill c New Member
    shinglesprings,ca
    08 crewmax
    I would not add another 1'' block. get a 2'' if that's the way you go, you can get a shock extender, it screws on to the top of the shock pushes the shock back down an inch or so. but not the best way to go.
  24. Mar 14, 2018 at 8:17 PM
    triplej23
    2013 Tundra TRD
    Yeah I just found a 2in block. I haven’t installed shocks yet so do you know if there is a shock that’s longer without using shock extender
  25. Mar 14, 2018 at 8:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  26. Mar 14, 2018 at 8:29 PM
    csuviper
    Broomfield, CO
    Not a huge difference in ride. Bit more travel with the shackle.
  27. Mar 14, 2018 at 8:32 PM
    csuviper
    Broomfield, CO
    Yea don’t do an extender. Check out what is offered here for the rear. Most of not all are extended length made for 1-3” lifts in the rear
    http://toyteclifts.3dcartstores.com/Shocks_c_118.html
    T-Rex266 and boostedtrdpro like this.
  28. Mar 14, 2018 at 8:40 PM
    triplej23
    2013 Tundra TRD
  29. Mar 14, 2018 at 8:41 PM
    triplej23
    2013 Tundra TRD
