Front blinkers
Discussion in 'Lighting' started by gregfocker77520, Mar 1, 2018.
  1. Mar 1, 2018 at 8:00 PM
    gregfocker77520
    gregfocker77520 [OP] New Member
    luis
    2018 Graphie tundra crewmax sr5
    none yet!!
    I have the new 2018 headlights with pnp harness, and motor control. Question is if I change out the blinker bulbs to led switchbacks will I need to add resistors?
  2. Mar 1, 2018 at 8:09 PM
  3. Mar 1, 2018 at 8:10 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  4. Mar 1, 2018 at 10:27 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Yes LEDs need resistors to work properly as turn signal bulb. Just remember now is a 7444NA for 2018 LED Headlights
  5. Mar 1, 2018 at 11:58 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Just a reminder, make sure you get blinker bulbs for an 18, because the bulbs changed from 3157ck on the 14-17's to 7444 on the 18 Led headlights.
    1UPPER likes this.
  6. Mar 2, 2018 at 4:21 AM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I have VLEDS nice kit easy hook up
  7. Mar 2, 2018 at 6:47 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    I would recommend the LED turns, I have found the 2018 lights really outshine the turn signals and people don't see them very easily. Not the best idea on Toyotas part, nice bright LED's and a incandescent turn signal buried in the interior corner.
  8. Mar 2, 2018 at 1:49 PM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    My truck came with the factory installed LED headlights and it did not need the resistors at least in the front turn signals, I have yet to do the rear blinkers but front ones did not need them. I'm assuming because it came with factory LED's and the wiring must be ready for them. I installed these lights from Amazon.
    https://www.amazon.com/gp/product/B077P5CDSX/ref=od_aui_detailpages00?ie=UTF8&psc=1
    NCinCO likes this.
  9. Mar 2, 2018 at 1:57 PM
    Dmas
    Dmas New Member
    FTL, FL
    NCinCO likes this.
  10. Mar 2, 2018 at 6:45 PM
    gregfocker77520
    luis
    none yet!!
    will the 7443 switchbacks from the retro fit source work?
  11. Mar 2, 2018 at 7:09 PM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    I have the HP24/7443 bulb will it fit?
  12. Mar 2, 2018 at 7:20 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    I was curious about this as well,to get my 18 lights full led when i install them, vleds has none listed for the 18,says there the same as the 17
  13. Mar 2, 2018 at 7:21 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    You have any pics of yours by chance?
  14. Mar 2, 2018 at 7:22 PM
    gregfocker77520
    luis
    none yet!!
    Vleds too pricey for me, the retrofit source ones much more in my range
  15. Mar 2, 2018 at 8:02 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Yeah 7443 is xcompatible with 7444NA
  16. Mar 7, 2018 at 2:47 PM
    gregfocker77520
    luis
    none yet!!
    @iHacker
    Installed the 7443 switchbacks but they only function as turn signal and when I arm or disarm the truck.
    Not sure why the white part of it doesn’t turn on. Is it cause the led headlights and harness?
  17. Mar 7, 2018 at 3:04 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Ohh wait a minute looking at your profile say your truck is a 2018 SR5, so you never had the Amber DRL signal, that’s why no white LEDs in your 7443 LED bulbs
  18. Mar 7, 2018 at 3:05 PM
    Dmas
    Dmas New Member
    FTL, FL
    What he said, ^^^, only the orange blinkers work on the 2018’s
  19. Mar 7, 2018 at 3:07 PM
    gregfocker77520
    luis
    none yet!!
    No I haven’t! How do I do that? Also like to note that I have the nsv light bar on the way. Any of this going to affect that install?
  20. Mar 7, 2018 at 3:11 PM
    gregfocker77520
    luis
    none yet!!
    I have the the new led 2018 head lights. Truck originally came with the drl lights with led strip on the bottom, I got the harness from ihacker for the install. Only wire that I moved was the one that went from #2 spot to #3 spot based on instructions.
  21. Mar 7, 2018 at 3:52 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Maybe this is possible but no one have shared something like this for Platinum/1794 before, your 2018 SR5 basically have the same wiring with a LED strip in the bottom. Maybe I’m not sure or saying this is the way to go but you could try with a jumper between violet wire and adding a terminal in the center MT spot in turn signals socket
  22. Mar 7, 2018 at 4:35 PM
    gregfocker77520
    luis
    none yet!!
    Can you hook me up with the two terminals to put in the plugs and I’ll try the jumper.
  23. Mar 9, 2018 at 3:05 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    I can but honestly not sure if go to work I been looking the 7443 bulb diagram but I don’t recommend it, may cause issues or popping fuses
    Beesta likes this.
  24. Mar 9, 2018 at 3:15 PM
    gregfocker77520
    luis
    none yet!!
  25. Mar 14, 2018 at 3:48 PM
    gregfocker77520
    luis
    none yet!!
    @iHacker, i installed the NSV light bar and after the install the drivers side switchback function works white he lights on and orange when turnsignal engaged but not the passengers side? wondering what happened and if i could do something wiring wise to get the other one to work. im not good with the schematics but i can follow directions. lol.
  26. Mar 14, 2018 at 10:35 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Not sure about it but definitely is for the NSV bar t-harness you used in driver side, no experience with the NSV bar wiring but I guess you had to t-tap something to the side marker in driver side, is this correct?
    And I guess this is only with first click of headlights switch, because that’s the only way to get 12V for the MT spot in turn signals
  27. Mar 14, 2018 at 10:44 PM
    gregfocker77520
    luis
    none yet!!
    I did the jumper from the blue wire on the t harness to purple wire
  28. Mar 15, 2018 at 4:53 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    Yes that’s why, doing same thing in the passenger side, a jumper from purple wire to the same blue wire location
  29. Mar 15, 2018 at 7:14 AM
    gregfocker77520
    luis
    none yet!!
    I need a pin to put in the passenger side plug the cause that spot is empty in passenger side plug
  30. Mar 15, 2018 at 9:48 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    I can do a jumper for passenger side and send it to you if you like, it’s gonna be a 2 piece wire can you measure the wire length needed to connect turn signal socket center MT spot to side maker
