What is the largest wheel setup I can add?
Discussion in 'Wheels & Tires' started by TundraTRD4X4, Jan 19, 2016.
  1. Jan 19, 2016 at 11:30 PM
    TundraTRD4X4
    TundraTRD4X4 [OP] New Member
    Beforehand, I appreciate all your help! I have a '16 TRD Off Road. I'm looking to add the bushwacker fender flares and a 3/1 level lift. I'm looking at some 22" maverick rims with either the Toyo Open Country atII or the Nitto Terra Grapplers. I want the tires to stick out just enough so they will be flush or stick out just a bit more than the fender flares. Preferrably with a negative offset, and with the least rubbing as possible. I will be removing the front mudflaps and the small flaps as-well. Thanks again!
    ps. I will try to add pictures this week of my truck
  2. Jan 21, 2016 at 6:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Ultra Maverick 22x9.5 for Tundra comes with 35 mm offset, it seems. What sort of fender flares do you have? If you have pocket style fender flares, tires will most likely be somewhat tucked in under the fender flares. If you want the tires to stick out, you are looking at zero or negative offset wheels. You will not be able to install large tires with low offset wheels, unless you are willing to cut some serious stuff.
  3. Jan 21, 2016 at 6:39 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Welcome! :hattip:
    Check out the wheel and tire thread - > HERE
    csuviper likes this.
  4. Jan 21, 2016 at 2:29 PM
    TundraTRD4X4
    This is the truck I have. The silver Tundra has the 22 inch ultra motorsports wheels with Toyo ats. I guess I'll have to go ahead without the fender flares if I don't want to do a ton of major cutting. I just wanted to remove the fenders from the front tires only. What do you guys think? I'm thinking about joining the Fuel Maverick team jajaja! That set up looks beastly! Would a 10" rim make the tires rub too much?
  5. Jan 22, 2016 at 7:49 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Definitely check out this link.
    Wheels are up to your taste. Consider the offset in your purchase. Info in the link will help.
    For tires look light since your adding larger heavier wheels.
    What lift?
