Rims
Discussion in 'Wheels & Tires' started by Bigmax, Mar 7, 2018.
  1. Mar 7, 2018 at 10:35 PM
    Bigmax
    Bigmax [OP] New Member
    Wilmington, NC
    2017 Sr5 Tundra crew max 5.7L
    Toytec coilovers with Bilsteins, 20x10 Fuel Assualts, 33x12.50 Toyo RT.
    I just bought a 2017 sr5 crew max 4x4 and im planning on wider rims (think I'm the only one). Im going to do the bilesten shock level kit 3 and 1. I was thinking about the fuel lethal d266 they are 20x10 with a -19 offset. Has anyone put 20x10 with a 3 and 1 level kit. I dont want to hack my truck up and would like atleast a 60 on tire height.
  2. Mar 7, 2018 at 10:53 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Someone else with more knowledge than me will probably chime in, but a -19 offset is going to stick out pretty far, which might look interesting with only a 3/1. But it that's the look you're going for then more power to you!
    Bigmax[OP] and GNTundra like this.
  3. Mar 8, 2018 at 1:01 AM
    Bigmax
    Wilmington, NC
    I'm hoping a inch or 2. Not to much but yeah thought about the lift being small also.
  4. Mar 8, 2018 at 2:59 AM
    Bigmax
    Wilmington, NC
    Thanks for all the replys and warm welcome. I did find a site called www.customwheeloffsets.com that helped alot. Thanks again
  5. Mar 8, 2018 at 4:56 AM
    Can't help on whether or not it will rub on that lift but here's a picture of a -24 from the front and a side picture of -19
    TUNDRA375 and Bigmax[OP] like this.
  6. Mar 8, 2018 at 7:37 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is one good looking truck....perfect stance. I would love to have that look but I know it would kill the fuel mileage.
    GNTundra likes this.
  7. Mar 8, 2018 at 7:38 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
    Bigmax[OP] likes this.
  8. Mar 8, 2018 at 7:45 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Why the negative offset? Kind of overkill IMO. +12-25 is the sweet spot on these trucks and sticks out plenty enough for an aggressive look, especially with 295/70/18 or larger tires. Check out the wheel and tire setup thread.
