Tire pressure 18cm stock wheels and tires?
Discussion in 'Wheels & Tires' started by Rski85, Mar 6, 2018.
  1. Mar 6, 2018 at 6:20 PM
    Rski85
    Rski85 [OP] New Member
    What tire pressure you guys run on stock wheels and stock Bridgestone duelers? The door sticker says 30psi? Can that be right? Seems low and tires look low as well. What should I bump it up too ?
  2. Mar 6, 2018 at 6:34 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    People will tell you to do the chalk test on here. It’s good advice. You can search it and find out how to do it.
    When I ran stock I ran mine at 36 psi.
    15whtrd likes this.
