Mirror Swap
Discussion in '2nd Gen Tundras (2007-2013)' started by heatha9, Jan 16, 2016.
  1. Jan 16, 2016 at 6:49 AM
    heatha9
    heatha9 [OP] New Member
    2007 Crewmax SR5
    I have a 07 with power mirrors but they are not heated. Is it possible to swap out for heated powered mirrors or for power folding towing mirrors? If so, what is the process?
  2. Jan 16, 2016 at 8:16 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sure, you could mount the mirrors, but chances are that your truck isn't wired for any of the additional options if it isn't currently wired for heated mirrors.
  3. Jan 16, 2016 at 8:17 AM
    heatha9
    2007 Crewmax SR5
    That's what I'm afraid of, is it possible to wire it and if so has anyone ever attempted it?
  4. Jan 16, 2016 at 9:37 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    Maybe a salvage yard and pull the harness from one? Or search ebay. If it was a model that came with the option that year then the fuse box should be designed to receive it I would think.
  5. Jan 16, 2016 at 9:39 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I installed a limited sport mirror with power fold, puddle light, heat and turn signal on my 2012 RW.
    The functions that worked were power adjust, heat and turn signal.
    The power fold and puddle light did not work. With some additional wiring and upgraded switch you can get these to function. I will be adding a how to at some point for this one.
    It's on the list when I find time.
  6. Jan 16, 2016 at 2:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've done this on my truck too, including the auto dimming. It was kind of a nuisance. The OP would need to do more and would need to decide if it's worth it. In most cases it's not simply plug and play. He may be able to get the harness, but that doesn't mean there's power for it, I discovered that with mine.
