Mounting bracket
Discussion in 'Lighting' started by Stulloh, Feb 25, 2018.
  1. Feb 25, 2018 at 4:45 AM
    Stulloh
    Stulloh [OP] New Member
    Dallas
    18 Tundra TSS
  2. Feb 25, 2018 at 6:27 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Fuse box cover seems easy and clean.
    boardude likes this.
  3. Feb 25, 2018 at 6:45 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I mounted mine on top of the fuse box cover, inside a separate plasitc box. I drilled through the cover and fed the wires into the fuse box to be protected.
    porkitt, 14burrito and Stulloh[OP] like this.
  4. Feb 25, 2018 at 9:15 AM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    Same Above but I did Velcro so I can pull it off if needed.
  5. Feb 25, 2018 at 9:43 AM
    Stulloh
    Dallas
    18 Tundra TSS
    Any issue with the Velcro over time?
  6. Feb 25, 2018 at 9:43 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I ran a 4 gauge main power wire so I could mount my fuse block on the passenger side. Then mounted my relays on the side closest to the firewall. I have my firewall grommet next to my relays. Just my personal preference for mounting. IMG_6998.jpg
    BOBONTUESDAY likes this.
  7. Feb 25, 2018 at 10:01 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I used the Blue Sea compact and put a separate ground bus under the trim that that's just above the fuse block. Here the trim is removed and you can see the ground bus and the wires being pulled to their various locations.
  8. Feb 25, 2018 at 6:30 PM
    BOBONTUESDAY
    2016 Limited Trd
    I put it in around 25k I'm at 124k with no issues I used the heavy duty Velcro. I've taken it off several times with no issues.
