Question for those who have or have seen the plastic OEM bed-liner.
Discussion in 'General Tundra Discussion' started by jp_over, Feb 24, 2018.
  1. Feb 24, 2018 at 8:35 AM
    jp_over
    jp_over [OP] New Member
    Joe
    East TX
    2017 CrewMax SR5 4x4, white
    Friends,
    For those who have or have experience with the plastic OEM bed liner (as pictured below) - would this be a deal-breaker if you were purchasing used?
    I've always used (and prefer) the spray on liner (Rhino Lining or similar). However, I've heard (but not seen) that the plastic liners trap water and cause rust.
    Thanks for any advice!
    lc69hunter likes this.
  2. Feb 24, 2018 at 12:17 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    As a dealer, I would pull that sucker out, get it sprayed and throw in a non slip mat.
    I avoid those plastic liners like the plague and offer spray ins for the same price.
    My person take however.
  3. Feb 24, 2018 at 12:20 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    My '10 has had a factory liner since new when I bought it, no issues, the rust from liners chafing is something that happened to the trucks in the '80s and '90s, not an issue with current trucks. The drop in liners do a better job of protecting the bed than a spray in can.
    Backslider and jp_over[OP] like this.
  4. Feb 24, 2018 at 12:29 PM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    I had the liner removed and opted for Linex.
    jp_over[OP] likes this.
  5. Feb 24, 2018 at 1:05 PM
    jp_over
    Joe
    East TX
    Thanks for all the feedback!
    I've never heard of a BedRug but it sounds like I need to check them out.
    NewImprovedRon likes this.
  6. Feb 24, 2018 at 1:18 PM
    TheBeast
    TheBeast The Beach
    i removed the liner and had mine line x
  7. Feb 24, 2018 at 3:39 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Mine will be sprayed soon and a thick rubber mat added for extra protection and ease of me crawling around in it...hate the plastic liner
    Sunnier likes this.
  8. Feb 24, 2018 at 4:11 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    BS on what? that I have a '10 with a bed liner and no issues?
    Can you show me some damage on a 10 year old or newer Tundra caused by a bed liner?
    kingsxjt likes this.
  9. Feb 24, 2018 at 4:25 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Just pulled the bed-liner out of my month old 2018 this morning. I have an appointment for a Premium Line-X application this coming Monday @ 1:00.
    jp_over[OP] and 757TUNDRA like this.
  10. Feb 24, 2018 at 5:21 PM
    Azblue
    The Dirty T ( ^_^)_且
    Probably depends where you live. Here in AZ, we have 0 problems with rust. I prefer the drop in because it really does offer more protection from impacts and dents. Yes, I can see paint being rubbed off if I lift it up and can understand how in some climates it could accelerate rust. But in a dry climate, like here, a drop in provides greater protection from dents and dings.[/QUOTE]
    Sunnier and Backslider like this.
  11. Feb 24, 2018 at 5:52 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Lift up the front and shine your flashlight between the bed and liner. I have a tri fold cover and a bed mat so there’s no leaking in mine
  12. Feb 24, 2018 at 5:54 PM
    DalTee
    DalTee New Member
    Dal
    I have no issues on my 11
  13. Feb 24, 2018 at 6:13 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I had a plastic liner in my 2002. I kept rust at bay by spraying oil under it once a year. A couple of years ago I pulled it out, cleaned it up and had Line-x spray the bed. I am much happier with the Line-x premium spray than I was with the drop in.
    Furthermore, Rowdy Ron is cool!
    Sunnier and NewImprovedRon like this.
  14. Jan 26, 2021 at 6:57 PM
    amajack
    amajack New Member
    Is this the same type of Bedliner you are saying to get rid of? 707CF432-35BE-4D90-AE0D-AD3466073AA7.jpg707CF432-35BE-4D90-AE0D-AD3466073AA7.jpg
  15. Jan 27, 2021 at 4:12 AM
    Bammer
    Monroe, CT
    I roll Herculiner on first, then drop in a liner. Prevents chaffing and the liner is perfect for impact resistance ! Done that to the past 3 trucks I've owned and it works like a charm.
  16. Jan 27, 2021 at 5:03 AM
    Black
    2014 Tundra Limited CrewMax
    I bought my Tundra with a plastic liner. I removed it and inspected the bed before purchasing. It was 6 years old and no signs of rust but there were numerous spots of bare metal. I had it sprayed 2 days after purchase.
    Could not even give away the plastic liner.
    Just last week I just pulled the factory plastic liner out of the 2000 Silverado we have owned since new. Though it has had a camper top on it all these years.
    I pulled the plastic and was honestly pretty nervous. There was not a lick of rust. And only one tiny spot of bare metal.
    Had the camper top not been on it for 20 years the result may have been different.
    I had it sprayed as well.
    The liner is still under my deck.
    GODZILLA and NewImprovedRon like this.
  17. Jan 27, 2021 at 6:02 AM
    amajack
    amajack New Member
    For those who got rid of their liner and sprayed. Did u get rid of the gaurd on the tailgate or did u put it back on , post spray.
    And if u didn't put it back on, did u keep the bolts in while they sprayed? Selling the liner and just want to be sure. Thanks
  18. Jan 27, 2021 at 7:34 AM
    Black
    That went in the trash with the rest of the plastic liner.
  19. Jan 28, 2021 at 9:18 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Pulled my liner out about 3 months ago. 2016 tundra in CA. Lots of bare metal due to the liner shifting around. Leaves dirt and all kinds of debris were under it also. Didn’t want to wait for rust so had it sprayed with line-x and dropped in a OEM rubber mat. So much happier with the durability. There was also plenty of dents under the cover due to the fact that stuff slides around on the hard plastic when braking turning and accelerating. Not an issue with the rubber mat or linex. I can put item on the mat and they stay put. Huge plus not hearing everything slam into the front of the bed after a quick stop.
  20. Jan 29, 2021 at 2:10 PM
    lc69hunter
    lc69hunter New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    I have a 2001 that still has the original bedliner in it, but it is about to come out. It is warped and ugly and traps stuff under it. I bought it with it in about a year or so ago.
  21. Jan 29, 2021 at 2:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I can show you on an almost 14 year truck with some really bad rust spots. Give me a moment to find my posts. I'm leaving the liner in so I don't have to look at the rust reminding me. I'm not spending the money to try to fix it either.
  22. Jan 29, 2021 at 2:17 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
  23. Jan 29, 2021 at 10:53 PM
    A lot of the rust issues with Tundras come from on the underside of the bed eating it's way into the bed, not starting from between the plastic liner and bed. I can attest to that with my truck.
    D4x4TRD and MacCTD like this.
  24. Nov 20, 2021 at 7:52 PM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Probably have made up your mind but I have an 08 with a factory plastic bedliner and let me tell you it has been through a lot. All kinds of hydraulic oil, air compressors that trap wet leaves all summer, and only taken it out once to clean under it. That’s 13 years! No rust of course which is amazing to me because in this part in Arkansas, the mud is about 99.99% clay, therefore it sticks and doesn’t come off. To make a long story short, I wouldn’t worry about a plastic bedliner. Just make sure to keep that engine howlin to knock all the water out every once in a while!:mudding::burnrubber:
    WVI likes this.
