TPMS sensors the same between steel and aluminum rim?
Discussion in 'Wheels & Tires' started by Upgrayedd, Feb 20, 2018.
  1. Feb 20, 2018 at 10:10 AM
    Upgrayedd
    Upgrayedd [OP] Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Are the sensors off my 2015 steel SR5 wheels going to work in a set of 2015 TRD aluminum rims?
  2. Feb 20, 2018 at 10:12 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
  3. Feb 20, 2018 at 10:18 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    They are different sensors, but you can flip the ones from your steel rims over when installing into the aluminum wheels. I did mine this way when o upgraded to the trd aluminum wheels and haven't had an issue so far in 20k miles.
    Upgrayedd[OP] likes this.
  4. Feb 20, 2018 at 10:34 AM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    You can buy new sensors, they're relatively cheap these days
  5. Feb 20, 2018 at 10:38 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    I successfully used the sensors from my steel wheels in my aftermarket aluminum alloy wheels
  6. Feb 20, 2018 at 10:42 AM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Thanks, I’m gonna try and flip them and see if that works. Worse case I’ll just run regular valve stems for now. I’m gonna get new tires later this year and can put the correct ones in then.
  7. Feb 20, 2018 at 12:29 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    The tire guy flipped the sensors and was able to get the tires mounted without issue. Thanks for the tip.
    I’m gonna get the correct sensors before I get all terrains later this year.
  8. Feb 20, 2018 at 3:39 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Glad it worked out for you!
